In AVRStudio 4.19-730 with Winavr 20100110 when I do "Build" in build window i don't see the "memory use summary" but only:
Build succeeded with 0 Warnings...
how i can set on this linker option ?
Just run avr-size separately. Use the -C and an -mcu option to get the "best" style of output.
To be honest you might be better off simply upgrading to AS6.1 which includes avr-gcc 4.7.2.
Fail to see any relations to AVR Software Framework :roll: moving to AS4 forum.
Nothing.... with avrstudio 4.17.666 works,
with avrstudio 4.19.730 nothing
Atmel broke some things in AVR Studio 4.19. This might be one of them.
As I said above - just run it separately.
I've seen that it's better ma AS4 is lighter and faster, and i must do only 8bit MC :roll:
You have three options:
1. Run AS 4.19 as you do now. Accept that Atmel has broken the memory report. They will not fix it. AS4.* is a dead product and has not been maintained for several years, and will not be in the future. Run avr-size separately.
2. Downgrade to AS4.18 which was before Atmel broke the memory report. Live with the ancient-ness of this version.
3. Upgrade to AS6.1 (which does 8-bit AVRs just fine). The download is huge, and requires substantial disk space. You will have to re-learn some things, since AS6 is different from AS4 but for the AVR code there are very small differences, most all to AS6's advantage.
These are you options. Pick one. Be done with it.
I try to compile with AS6 but i have this error
terminal2.elf section .text will not fit in region textregion text overflowed by 1006 bytes make: *** [terminal2.elf] Error 1
but with AS4 compiler was right.
Where is the difference with old compiler?
After a build, switch over to the Output tab in AS6. There is the complete build output. Mark it all, copy it and paste it in a post here. That way we have a good chance of catching what went wrong.
Did you set the AS6 project up for the correct AVR model?
Have you set the compiler to optimize?
Are you using floating point math without linking with libm.a?
If you can't answer those questions we can if we get to see the build output.
------ Build started: Project: terminal2, Configuration: default AVR ------ Build started. Project "terminal2.cproj" (default targets): Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!=''). Target "CoreBuild" in file "C:\Programmi\Atmel\Atmel Studio 6.1\Vs\Compiler.targets" from project "C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\terminal2.cproj" (target "Build" depends on it): Using "RunCompilerTask" task from assembly "C:\Programmi\Atmel\Atmel Studio 6.1\Extensions\Application\AvrGCC.dll". Task "RunCompilerTask" C:\Programmi\Atmel\Atmel Studio 6.1\shellUtils\make.exe all Building file: .././Inits.c Invoking: AVR/GNU C Compiler : 20100110.0 "C:\WinAVR-20100110\bin\avr-gcc.exe" -funsigned-char -funsigned-bitfields -DF_CPU=16000000UL -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=atmega8 -c -gdwarf-2 -std=gnu99 -MD -MP -MF "Inits.d" -MT"Inits.d" -MT"Inits.o" -o "Inits.o" ".././Inits.c" .././Inits.c: In function 'Init_EEprom': C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Inits.c(64,1): passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Inits.c(65,1): passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Inits.c(66,1): passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Inits.c(68,1): passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Inits.c(69,1): passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Inits.c(71,1): passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Inits.c(75,1): passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Inits.c(76,1): passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Inits.c(79,1): passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Inits.c(83,1): passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Inits.c(84,1): passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast Finished building: .././Inits.c Building file: .././lib_lcd.c Invoking: AVR/GNU C Compiler : 20100110.0 "C:\WinAVR-20100110\bin\avr-gcc.exe" -funsigned-char -funsigned-bitfields -DF_CPU=16000000UL -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=atmega8 -c -gdwarf-2 -std=gnu99 -MD -MP -MF "lib_lcd.d" -MT"lib_lcd.d" -MT"lib_lcd.o" -o "lib_lcd.o" ".././lib_lcd.c" Finished building: .././lib_lcd.c Building file: .././Routines.c Invoking: AVR/GNU C Compiler : 20100110.0 "C:\WinAVR-20100110\bin\avr-gcc.exe" -funsigned-char -funsigned-bitfields -DF_CPU=16000000UL -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=atmega8 -c -gdwarf-2 -std=gnu99 -MD -MP -MF "Routines.d" -MT"Routines.d" -MT"Routines.o" -o "Routines.o" ".././Routines.c" .././Routines.c: In function 'inout': C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Routines.c(162,1): unused variable 'j' Finished building: .././Routines.c Building file: .././Terminal.c Invoking: AVR/GNU C Compiler : 20100110.0 "C:\WinAVR-20100110\bin\avr-gcc.exe" -funsigned-char -funsigned-bitfields -DF_CPU=16000000UL -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=atmega8 -c -gdwarf-2 -std=gnu99 -MD -MP -MF "Terminal.d" -MT"Terminal.d" -MT"Terminal.o" -o "Terminal.o" ".././Terminal.c" .././Terminal.c: In function 'lettura_rpm_background': C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(75,1): passing argument 1 of 'atoi' discards qualifiers from pointer target type .././Terminal.c: In function 'write_pos_attuale': C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(85,1): passing argument 2 of 'ultoa' discards qualifiers from pointer target type C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(86,1): implicit declaration of function 'put_string_lcd' .././Terminal.c: In function 'main': C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(296,1): passing argument 1 of 'atoi' discards qualifiers from pointer target type C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(359,1): suggest parentheses around comparison in operand of | C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(359,1): suggest parentheses around comparison in operand of | C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(359,1): suggest parentheses around comparison in operand of | C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(359,1): suggest parentheses around comparison in operand of | C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(367,1): implicit declaration of function 'isdigit' C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(435,1): passing argument 1 of 'atoi' discards qualifiers from pointer target type C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(448,1): passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(448,1): passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(449,1): passing argument 2 of 'itoa' discards qualifiers from pointer target type C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(478,1): passing argument 1 of 'atoi' discards qualifiers from pointer target type C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(479,1): passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(479,1): passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(488,1): passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(489,1): passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(505,1): passing argument 1 of '__eerd_dword_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(506,1): passing argument 2 of 'ultoa' discards qualifiers from pointer target type C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(535,1): passing argument 1 of 'atol' discards qualifiers from pointer target type C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(536,1): passing argument 1 of '__eewr_dword_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(553,1): passing argument 1 of '__eerd_dword_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(555,1): passing argument 2 of 'ultoa' discards qualifiers from pointer target type C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(577,1): passing argument 2 of 'itoa' discards qualifiers from pointer target type C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(584,1): passing argument 1 of 'com1_str' discards qualifiers from pointer target type C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(598,1): passing argument 2 of 'ultoa' discards qualifiers from pointer target type C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(607,1): passing argument 1 of 'com1_str' discards qualifiers from pointer target type C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(637,1): passing argument 1 of 'com1_str' discards qualifiers from pointer target type C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(667,1): passing argument 1 of '__eerd_dword_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\Terminal.c(680,1): passing argument 2 of 'utoa' discards qualifiers from pointer target type Finished building: .././Terminal.c Building file: .././TimerRTC.c Invoking: AVR/GNU C Compiler : 20100110.0 "C:\WinAVR-20100110\bin\avr-gcc.exe" -funsigned-char -funsigned-bitfields -DF_CPU=16000000UL -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=atmega8 -c -gdwarf-2 -std=gnu99 -MD -MP -MF "TimerRTC.d" -MT"TimerRTC.d" -MT"TimerRTC.o" -o "TimerRTC.o" ".././TimerRTC.c" .././TimerRTC.c: In function 'Keyboard': C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\TimerRTC.c(143,1): passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\TimerRTC.c(157,1): passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\TimerRTC.c(171,1): passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\TimerRTC.c(185,1): passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast C:\Documents and Settings\icio\Desktop\progetti sul desktop\PROTEL DXP\AZIONAMENTI\BRUSHLESS PCB E FIRMWARE\firmware\Nuova cartella\terminal2\TimerRTC.c(199,1): passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast Finished building: .././TimerRTC.c Building file: .././Usart.c Invoking: AVR/GNU C Compiler : 20100110.0 "C:\WinAVR-20100110\bin\avr-gcc.exe" -funsigned-char -funsigned-bitfields -DF_CPU=16000000UL -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -Wall -mmcu=atmega8 -c -gdwarf-2 -std=gnu99 -MD -MP -MF "Usart.d" -MT"Usart.d" -MT"Usart.o" -o "Usart.o" ".././Usart.c" Finished building: .././Usart.c Building target: terminal2.elf Invoking: AVR/GNU Linker : 20100110.0 "C:\WinAVR-20100110\bin\avr-gcc.exe" -o terminal2.elf Inits.o lib_lcd.o Routines.o Terminal.o TimerRTC.o Usart.o -Wl,-Map="terminal2.map" -Wl,--start-group -Wl,--end-group -Wl,--gc-sections -mmcu=atmega8 -Wl,-u,vfprintf terminal2.elf section .text will not fit in region textregion text overflowed by 1006 bytes make: *** [terminal2.elf] Error 1 Done executing task "RunCompilerTask" -- FAILED. Done building target "CoreBuild" in project "terminal2.cproj" -- FAILED. Done building project "terminal2.cproj" -- FAILED. Build FAILED. ========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
with as4 :
Build started 9.12.2013 at 01:31:41 avr-gcc -mmcu=atmega8 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=16000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT Terminal.o -MF dep/Terminal.o.d -c ../Terminal.c ../Terminal.c: In function 'lettura_rpm_background': ../Terminal.c:75: warning: passing argument 1 of 'atoi' discards qualifiers from pointer target type ../Terminal.c: In function 'write_pos_attuale': ../Terminal.c:85: warning: passing argument 2 of 'ultoa' discards qualifiers from pointer target type ../Terminal.c:86: warning: implicit declaration of function 'put_string_lcd' ../Terminal.c: In function 'main': ../Terminal.c:299: warning: passing argument 1 of 'atoi' discards qualifiers from pointer target type ../Terminal.c:362: warning: suggest parentheses around comparison in operand of | ../Terminal.c:362: warning: suggest parentheses around comparison in operand of | ../Terminal.c:362: warning: suggest parentheses around comparison in operand of | ../Terminal.c:362: warning: suggest parentheses around comparison in operand of | ../Terminal.c:370: warning: implicit declaration of function 'isdigit' ../Terminal.c:438: warning: passing argument 1 of 'atoi' discards qualifiers from pointer target type ../Terminal.c:451: warning: passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast ../Terminal.c:451: warning: passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast ../Terminal.c:452: warning: passing argument 2 of 'itoa' discards qualifiers from pointer target type ../Terminal.c:481: warning: passing argument 1 of 'atoi' discards qualifiers from pointer target type ../Terminal.c:482: warning: passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast ../Terminal.c:482: warning: passing argument 1 of '__eewr_byte_m8' makes pointer from integer without a cast ../Terminal.c:491: warning: passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast ../Terminal.c:492: warning: passing argument 1 of '__eerd_byte_m8' makes pointer from integer without a cast ../Terminal.c:508: warning: passing argument 1 of '__eerd_dword_m8' makes pointer from integer without a cast ../Terminal.c:509: warning: passing argument 2 of 'ultoa' discards qualifiers from pointer target type ../Terminal.c:538: warning: passing argument 1 of 'atol' discards qualifiers from pointer target type ../Terminal.c:539: warning: passing argument 1 of '__eewr_dword_m8' makes pointer from integer without a cast ../Terminal.c:556: warning: passing argument 1 of '__eerd_dword_m8' makes pointer from integer without a cast ../Terminal.c:558: warning: passing argument 2 of 'ultoa' discards qualifiers from pointer target type ../Terminal.c:580: warning: passing argument 2 of 'itoa' discards qualifiers from pointer target type ../Terminal.c:587: warning: passing argument 1 of 'com1_str' discards qualifiers from pointer target type ../Terminal.c:601: warning: passing argument 2 of 'ultoa' discards qualifiers from pointer target type ../Terminal.c:610: warning: passing argument 1 of 'com1_str' discards qualifiers from pointer target type ../Terminal.c:640: warning: passing argument 1 of 'com1_str' discards qualifiers from pointer target type ../Terminal.c:670: warning: passing argument 1 of '__eerd_dword_m8' makes pointer from integer without a cast ../Terminal.c:683: warning: passing argument 2 of 'utoa' discards qualifiers from pointer target type avr-gcc -mmcu=atmega8 -Wl,-u,vfprintf -Wl,-Map=terminal2.map Inits.o lib_lcd.o Routines.o Terminal.o TimerRTC.o Usart.o -o terminal2.elf avr-objcopy -O ihex -R .eeprom -R .fuse -R .lock -R .signature terminal2.elf terminal2.hex avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" --change-section-lma .eeprom=0 --no-change-warnings -O ihex terminal2.elf terminal2.eep || exit 0 avr-objdump -h -S terminal2.elf > terminal2.lss Build succeeded with 31 Warnings...
So setup AS6 to uses the 4.3.3 in WinAVR user the "Toolchain Flavours" feature.
