Posted: Mar 11, 2010 - 07:19 AM |
I've tried to find the answer, how to program two or more AVR uC (ATmega especially) on one board using only one ISP connector.
Would jumper linking RST (SPI) with Reset pin of ATmega (which is going to be programed) is a solution? Is it better way to do it?
Thanks, for answers. |
Posted: Mar 11, 2010 - 07:55 AM |
| It's best to jumper the clock signal. That way all devices is held in reset while one is programmed. |
Posted: Mar 11, 2010 - 08:07 AM |
So, if I understand you right, I should insert jumper to all uC (for example on their XTAL1 pin).
While programming only one is inserted, and while running all are inserted, right? |
Posted: Mar 11, 2010 - 08:08 AM |
I had only troubles doing the same in the past. Maybe because the SPI line was also used for communication between ATmegas.
You have to put a jumper between each reset pin and the shared ISP connector anyway so what is the space difference between a jumper and a small 6 pin ISP connector ? Not too much considering you don't have to route traces between the shared pins of ATmegas.
I would use a 2x3 pin header with 1.25 or 2mm pitch for each ATmega. Other idea is to leave the pin header unsoldered if you have a PTH board. Another idea is to use a 4x1 pin small header for each ATmega for SCK, RESET, MISO, MOSI and take the power from a common place.
No, he is talking about the SPI clock (SCK) |
Posted: Mar 11, 2010 - 08:27 AM |
No, the ISP clock signal, SCK. |
Posted: Mar 11, 2010 - 09:25 AM |
Thanks for quick response.
I'll try to do SCK jumper.
Rest SPI lines can be common? What about RST can it be common too? Maybe I ask silly questions but I would like to be 100% sure before making a PCB.
Thanks |
Posted: Mar 11, 2010 - 09:40 AM |
| It depends a bit on what you are your AVRs are going to do. Do they communicate with each other, or with their own SPI slaves? If they all use the SPI bus, you must implement some kind of bus mastering system technique. |
Posted: Mar 11, 2010 - 10:47 AM |
Well, I'm going use SPI only for programming, there will be no SPI communication between them.
In these case SCK will be separated (jumper), other SPI (MISO, MOSI) will be common. (right?)
But my question is do I have to separate the RST form ISP too. The other AVR may stop working for the time of programming the first one.
Or maybe the idea of making two 3x2 pins for ISP is better idea? |
Posted: Mar 11, 2010 - 11:04 AM |
The RST line must be common too to ensure that software in uC2 won't interfere with uC1 programming.
Otherwise while programming uC1, any bug in uC2 software might interfere with the common lines (MISO, MOSI). The uC1 might be loaded with corrupted software and you might search the cause for days.
Keep things simple and everybody will be happy. |
Posted: Mar 11, 2010 - 12:17 PM |
| OK, thank you for the answers. |
