byunsangho
PostPosted: Aug 05, 2010 - 09:12 PM
Newbie
Hi
Thanks everyone for answering my question earlier regarding simple push button, I'd like to fire away my second question.
I'm using the following code to test ADC. I'm using ATTINY13 for this simple project and using the following diagram for input to the ADC0.
(+5V)
620 ohm
Var Resistor(20 kOhm) ---> into ADC0
620 ohm
(GND)
Currently, LED2 turns, on while the LED1 off, when the input to the ADC0 is below 2.5V and vice versa. However, I am experiencing LED2 going off if I keep turning the pot below 2.18 V. The LED2 stays on between 2.5V to 2.18V but not below 2.18V.
Code:
// Source: http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=56429
#include <avr/interrupt.h>
   DDRB |= (1 << 2); // Set LED1 as output
      DDRB |= (1 << 0); // Set LED2 as output
   ADCSRA |= (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0); // Set ADC prescaler to 128 - 125KHz sample rate @ 16MHz
   //ADMUX |= (1 << REFS0); // Set ADC reference to AVCC
   ADMUX &= ~(1 << REFS0); // Set ADC reference to VCC
   ADMUX |= (1 << ADLAR); // Left adjust ADC result to allow easy 8 bit reading
   // No MUX values needed to be changed to use ADC0
   ADCSRA |= (1 << ADEN);  // Enable ADC
   ADCSRA |= (1 << ADIE);  // Enable ADC Interrupt
   sei();   // Enable Global Interrupts
   ADCSRA |= (1 << ADSC);  // Start A2D Conversions
   //ADCSRA |= (1 << ADFR);  // Set ADC to Free-Running Mode
   ADCSRA |= (1 << ADATE);
   for(;;)  // Loop Forever
ISR(ADC_vect)
   // Code to be executed when ISR fires
    if(ADCH < 128)
       PORTB |= (1 << 2); // Turn on LED1
        PORTB &= ~(1 << 0); // Turn off LED2
       PORTB &= ~(1 << 2); // Turn off LED1
        PORTB |= (1 << 0); // Turn on LED2
What am I doing wrong? Any suggestions?
byunsangho
PostPosted: Aug 06, 2010 - 05:04 PM
Newbie
Is there something wrong with my question format? I need help on this. I don't have debugger tool to debug where the logic error is coming from.
clawson
PostPosted: Aug 06, 2010 - 05:08 PM
10k+ Postman
Suggest you wire up the UART (or perhaps an LCD) and actually print out the raw ADCH readings to see what's going on.
nvaghasana
PostPosted: Aug 07, 2010 - 05:53 AM
Rookie
Check reference voltage pin
byunsangho
PostPosted: Aug 07, 2010 - 06:24 AM
Newbie
thanks for your replies.
I'm using VCC as my reference voltage, am I not?
I think by observing that the transition of LED occur at around 2.5V, VCC is being used for reference voltage . Comment on this?
nvaghasana
PostPosted: Aug 07, 2010 - 06:48 AM
Rookie
Yes you are.
I'm not that much expert but it is look like issue with reference voltage, try to vary reference voltage using potentiometer and check the results.
Nilesh
Simonetta
PostPosted: Aug 07, 2010 - 08:02 AM
Posting Freak
Try variations of the program. For example, do a single conversion (instead of free running) 50 times a second.
What is the VCC of the Tiny13 when the pot goes below 2.18V? What is the resistor value on the LED?
Try removing the LEDs and see if the logic on PortB 0 and 2 works correctly. Does VCC voltage stay on PortB2 when the pot is less than +2.1 when the LED is removed?
In a simple situation like this the first troubleshooting approach is to determine if the problem is in the program or in the hardware wiring.
Are you using a crystal on the Tiny13? Your code says ADPS2_0 is 125KHz from a 16MHz system clock. The Tiny13 can not use a crystal and can only get a 16MHz system clock from an external clock source. Try changing the fuses for the internal 9.6MHz or 4.8MHz clock.
KitCarlson
PostPosted: Aug 07, 2010 - 05:24 PM
Posting Freak
With the Tiny13, a debug method might be to setup a PWM and feed the ADC to it. This is very simple to do. A scope can then be used to read the ADC value via a duty-cycle measurement. If a scope is not available used a led and resistor and view intensity.
It all starts with a mental vision.
jfiresto
PostPosted: Aug 07, 2010 - 06:26 PM
Or if you can find one, hook up one of those old-fashioned, mechanical meters and let its inertia integrate the pulse train for you. Or create an RC filter and substitute a DVM.
theusch
PostPosted: Aug 07, 2010 - 06:50 PM
10k+ Postman
Yes you are.
Well, assuming that the value of REFS1 is immaterial.
I >>always<< fail to see the fascination with bit-fiddling ADMUX. Just build it ans set it. It is more efficient in terms of cycles and code space, avoids any RMW situations, and makes most of the discussion in this thread moot.
Here is one link to a prior spouting of my opinion on this, that links to another thread which has 3 more links...
http://www.avrfreaks.net/index.php?name ... =admux+rmw
http://www.avrfreaks.net/index.php?name ... ux+rebuild
Koshchi
PostPosted: Aug 07, 2010 - 07:53 PM
10k+ Postman
Since the tiny13 doesn't have a REFS1, I would say that it is immaterial.
Steve A.
theusch
PostPosted: Aug 07, 2010 - 08:50 PM
10k+ Postman
LOL. [Yet another reason I use the Tiny25, I guess.]
byunsangho
PostPosted: Aug 12, 2010 - 06:42 PM
Newbie
VCC of Tiny13 stays at 5.1 V regardless of whether I have LEDs or not. I am using internal clock (Int. RC OSc. 9.6 MHz; Start-up time: 14 CK + 64 ms) but I see CKDIV8 bit checked. Does this mean the actual clock I will be using is 9.6 Mhz divided by 8 and the final clock will be that number divided by prescaler?
I haven't tried using single conversion technique and would like to leave it till I ran out of possible solution.
clawson
PostPosted: Aug 12, 2010 - 06:45 PM
10k+ Postman
Yes 1.2MHz
byunsangho
PostPosted: Aug 12, 2010 - 06:56 PM
Newbie
Just read manual regarding debug wire. I've check off DWEN and when I clicked program, AVR Studio warned me about losing ISP. Does this mean, after clicking OK, I will not be able to program the ATTINY13?
clawson
PostPosted: Aug 12, 2010 - 07:00 PM
10k+ Postman
If all you have is ISP then yes you have lost the chip. If you buy a debugWire interface (Dragon, JTAGICEmkII, AVR One!) then you will be able to contact it via dW and while in that mode get it switched back to ISP.
Only thing is those debuggers cost respectively:
$50
$299
one kidney or your grandmother
byunsangho
PostPosted: Aug 12, 2010 - 07:05 PM
Newbie
Yes 1.2MHz
I've changed the prescaler to 4 so that my clock speed will be 300 KHz. Nonetheless, I still have the same issue.
clawson
PostPosted: Aug 12, 2010 - 07:22 PM
10k+ Postman
Which prescaler? Are you talking about CLKPR. When the CKDIV8 fuse is set it just arranges for that register to default to /8 and 9.6MHz becomes 1.2MHz. If you have changed that to /4 you have changed the CPU frequency to 2.4MHz
byunsangho
PostPosted: Aug 12, 2010 - 08:07 PM
Newbie
I mean the prescaler that i set with the following code
Code:
ADCSRA |= (1 << ADPS1);
ADCSRA &= ~((1 << ADPS2) | (1 << ADPS0));
Will it not be 300 KHz after all this? /8 from CKDIV8 and /4 from ADPS bits? so 9600 Khz / 32 = 300 kHz
byunsangho
PostPosted: Aug 12, 2010 - 09:21 PM
Newbie
I've moved the ADC input port to ADC2. I am not sure why it did not work with ADC0 but I think it has something to do with RESET. Can you guys please explain why this is happening?
This is where I've got the idea:
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=65484&highlight=adc+attiny13
