zerok
PostPosted: Feb 20, 2013 - 02:21 PM
I have just got a RZUSBSTICK and I am trying to get it to work on a windows 7 64 bit machine. I am using the RZUSBSTICK with the firmware out of the box.
The hardware is good because when I connect is to a virtual windows xp machine with avrstudio 4.18 with SP1&SP2 it works and I can capture packets.
When I install it under win 7 it finds a RZUSBSTICK device but no network adapter or virtual com port. The rfservicesserver crashed when I try to connect to it. I can enter the command "rfservicesserver.exe 127.0.0.1 27000" in cmd and it is waiting for a connection. When I start avrwirelessservices and connect rfservicesserver crashes.
Is there a firmware, driver upgrade so I can use this with win 7? I saw several posts in this forum about this but I did no find a good solution.
kind regards,
