wek
PostPosted: Jun 09, 2010 - 08:18 PM
Programs contain sequences of statements, and a naive compiler would execute them exactly in the order as they are written. But an optimizing compiler is free to reorder the statements - or even parts of them - if the resulting "net effect" is the same. The "measure" of the "net effect" is what the standard calls "side effects", and is accomplished exclusively through accesses (reads and writes) to variables tagged as volatile. So, as long as all volatile reads and writes are to the same addresses and in the same order (and writes write the same values), the program is correct, regardless of other operations in it. (One important point to note here is, that time duration between consecutive volatile accesses is not considered at all.)
Unfortunately, there are also operations which are not covered by volatile accesses. An example of this in avr-gcc/avr-libc are the cli()/sei() macros defined in <avr/interrupt.h>, which convert directly to the respective assembler mnemonics through the __asm__() statement. These don't constitute a variable access at all, not even volatile, so the compiler is free to move them around. Although there is a "volatile" qualifier which can be attached to the __asm__() statement, its effect on (re)ordering is not clear from the documentation (and is more likely only to prevent complete removal by the optimiser), as it (among other) states:
Note that even a volatile asm instruction can be moved relative to other code, including across jump instructions. [...] Similarly, you can't expect a sequence of volatile asm instructions to remain perfectly consecutive.
There is another mechanism which can be used to achieve something similar: memory barriers. This is accomplished through adding a special "memory" clobber to the assembler statement, and ensures that all variables are flushed from registers to memory before the statement, and then re-read after the statement. The purpose of memory barriers is slightly different than to enforce code ordering: it is supposed to ensure that there are no variables "cached" in registers, so that it is safe to change the content of registers e.g. when switching context in a multitasking OS (on "big" processors with out-of-order execution they also imply usage of special instructions which force the processor into "in-order" state (this is not the case of AVRs)).
However, memory barrier works well in ensuring that all volatile accesses before and after the barrier occur in the given order with respect to the barrier. However, it does not ensure the compiler moving non-volatile-related statements across the barrier. Peter Dannegger provided a nice example of this effect:
Code:
#define cli() __asm volatile( "cli" ::: "memory" )
#define sei() __asm volatile( "sei" ::: "memory" )
unsigned int ivar;
void test2( unsigned int val )
  val = 65535U / val;
  cli();
  ivar = val;
  sei();
compiles with optimisations switched on (-Os) to
Code:
00000112 <test2>:
 112:   bc 01          movw   r22, r24
 114:   f8 94          cli
 116:   8f ef          ldi   r24, 0xFF   ; 255
 118:   9f ef          ldi   r25, 0xFF   ; 255
 11a:   0e 94 96 00    call   0x12c   ; 0x12c <__udivmodhi4>
 11e:   70 93 01 02    sts   0x0201, r23
 122:   60 93 00 02    sts   0x0200, r22
 126:   78 94          sei
 128:   08 95          ret
where the potentially slow multiplication is moved across cli(), resulting in interrupts to be disabled longer than intended. Note, that the volatile access occurs in order with respect to cli()/sei(); so the "net effect" required by the standard is achieved as intended, it is "only" the timing which is off. However, for most of embedded applications, timing is an important, sometimes critical factor.
Unfortunately, at the moment, in avr-gcc (nor in the C standard), there is no mechanism to enforce complete match of written and executed code ordering - except maybe of switching the optimization completely off (-O0), or writing all the critical code in assembly.
To sum it up:
  • memory barriers ensure proper ordering of volatile accesses
  • memory barriers don't ensure statements with no volatile accesses to be reordered across the barrier
[This article was written as a supporting documentation for related items in avr-libc - the sei()/cli() macros in <avr/interrupt.h>, the ATOMIC_BLOCK mechanism in <utils/atomic.h> and the newly being introduced _MemoryBarrier() in <avr/cpufunc.h>. It also drew from http://www.avrfreaks.net/index.php?name ... ighlight=.
Comments please. Thanks.
Jan Waclawek
[edit] fixed the last link
theusch
PostPosted: Jun 09, 2010 - 08:34 PM
10k+ Postman
I cannot agree with this, especially the "exclusively" part. The optimization situations that you allude to existed long before microcontrollers and "volatile". You start with basic blocks first, mix well with a portion of sequence points, and add a dash of register lifetime. Volatile is like the sprinkles on the top of the cupcake icing. (generalizations based on past live(s) doing compilers and the like)
However, I can certainly see your point as you expand on the particular situation(s) being addressed.
Bingo600
PostPosted: Jun 09, 2010 - 09:20 PM
@Jan
Tell the poor compiler that you insist on using val "NOW ....."
Code:
unsigned int ivar;
  val = 65535U / val;
  asm volatile ("" : : "b"(val): "memory");
  cli();
  ivar = val;
  sei();
Code:
test2:
/* prologue: function */
/* frame size = 0 */
   movw r22,r24
   ldi r24,lo8(-1)
   ldi r25,hi8(-1)
   rcall __udivmodhi4
   movw r30,r22
/* #APP */
 ;  23 "testw.c" 1
   cli
 ;  0 "" 2
/* #NOAPP */
   sts (ivar)+1,r23
   sts ivar,r22
/* #APP */
 ;  27 "testw.c" 1
   sei
 ;  0 "" 2
/* epilogue start */
/* #NOAPP */
   ret
Some hints here
http://blog.regehr.org/archives/28
http://www.cs.utah.edu/~regehr/papers/e ... eprint.pdf
And i think Dean or Danni also mentioned this trick.
Btw: I'm not 100% sure about the "b" in
Code:
: "b"(val):
I used b to get it to shut up Smile
And you doesnt access the var at all , you just tell the compiler that you want to use/access it.
/Bingo
Ps: If you complain about the
Code:
 movw r30,r22
Then "Put the beast out of it's misery" and go buy an IAR compiler Smile
Wonder where it came from ... Smile
Was it the "b" access ... ?
wek
PostPosted: Jun 09, 2010 - 09:50 PM
Well, some form of "volatilisation" should help (btw. "b" is not a particularly good choice in this case, standing for "Base pointer register (r28–r31)", the register allocator might feel pressed in a more convoluted situation and move things around unnecessarily... or not, as it's a pretty unpredictible beast... Smile ). Danni's solution is also a form of "volatilisation", except he did it on the other side of barrier, involving C-ish cast magic, http://www.avrfreaks.net/index.php?name ... 85#672085.
But my point is slightly different: the article is NOT intended to provide a solution, it is intended to WARN about the effect. Once you KNOW this may happen, you will be aware of it when hunting down the subtle bugs it may cause.
Jan
Bingo600
PostPosted: Jun 09, 2010 - 09:55 PM
@Jan
Well im not an assembler guru , but i take it that you get the hint ...
Tell gcc that you want to use the variable as in the above , but maybe with the right "magic" instead of "b".
Then it will deliver it at that point.
But you are right that it would be optimal if the plain ::: memory , could have done it.
But i do think a volatile would help see below link.
There was a previous issue here
http://www.avrfreaks.net/index.php?name ... mp;t=89378
/Bingo
Bingo600
PostPosted: Jun 09, 2010 - 10:01 PM
Seems like the "r" aka. any register will get rid of the extra code.
Code:
  val = 65535U / val;
  asm volatile ("" : : "r"(val): "memory");
  cli();
  ivar = val;
  sei();
Code:
test2:
   movw r22,r24
   ldi r24,lo8(-1)
   ldi r25,hi8(-1)
   rcall __udivmodhi4
/* #APP */
 ;  23 "testw.c" 1
   cli
 ;  0 "" 2
/* #NOAPP */
   sts (ivar)+1,r23
   sts ivar,r22
/* #APP */
 ;  27 "testw.c" 1
   sei
 ;  0 "" 2
/* #NOAPP */
   ret
Could any of the "C" gurus make a TOUCH(val) macro out of this one : asm volatile ("" : : "r"(val): "memory");
Could come in handy ....
/Bingo
wek
PostPosted: Jun 09, 2010 - 10:05 PM
That's just a fancy word... Wink
This all comes from C99 5.1.2.3. Sure, I've committed (over)simplification, but I don't think the description of the problem needs to go to further details (which I think the same what you said in the following:)
You are free to suggest different wording, of course.
Jan
Bingo600
PostPosted: Jun 09, 2010 - 10:11 PM
Jan
Ahh... I get it (now...)
It was a "warning/info" not a "how to avoid" question ..
Sorry ... But a "TOUCH" macro could come in handy anyways.
Even though one prob still has to check if "the beast" does what "You think/expect you have told it to do" Smile
/Bingo
ArnoldB
PostPosted: Jun 10, 2010 - 06:54 AM
Do I get it right, you are trying to move an age-old avr-libc discussion to avrfreaks, to build up some pressure on the decision makers there?
wek
PostPosted: Jun 10, 2010 - 07:48 AM
Well, there are no real decisions made there, as far as substantial issues of gcc are concerned.
I'm just trying to document the status quo.
JW
dl8dtl
PostPosted: Jun 10, 2010 - 10:47 AM
I've asked Jan to discuss this here, so his contribution can go into
the avr-libc documentation, as what's currently there might be a
little terse if you never thought about all those details.
Jörg Wunsch
Please read the `General information...' article before.
 View user's profile Send private message Send e-mail Visit poster's website
anders_m
PostPosted: Jun 10, 2010 - 01:50 PM
One thing I've though about is a new "reorder_barrier" GCC function attribute. The intended effect would be to prevent the compiler from moving any code across a call to a function with that attribute, ie. from the programmer's point of view basically the same effect as a memory clobber but not quite as expensive.
However, I'm not enough of a language lawyer to judge just how bad an idea this would be.
theusch
PostPosted: Jun 10, 2010 - 04:10 PM
10k+ Postman
I haven't dug into the internals, but if the volatile accesses were made a "sequence point"--or the equivalent in the GCC approach--then the code couldn't be moved outside of it's "area". The shortest analogy I can think of is a label in assembler that is the target of a branch/jump/call/... . One must be careful on placing code before/after this destination. This doesn't affect register contents at the "fall though" so may not be as brutal as the memory clobber mentioned.
ArnoldB
PostPosted: Jun 10, 2010 - 07:33 PM
And what is wrong with first starting to support the build-ins GCC already has? Or, in case they are already reasonably supported for AVRs, spread the news about them?
In particular I am talking about
http://gcc.gnu.org/onlinedocs/gcc-4.3.5 ... ltins.html
For those asking for just a memory barrier, let me point you to __sync_synchronize() on the above mentioned page.
I really don't see the point of inventing new syntax, new attributes or new semantic. Get the __sync_*() stuff running and you are in business. No point in letting the not invented here syndrome take over.
And if you don't like the function names, wrap them in convenience macros.
And I hate it when things that are named like an assembler opcode (e.g. cli(), sbi(), or nop()) do even a iota more than the corresponding opcodes.
wek
PostPosted: Jun 10, 2010 - 09:41 PM
Good point. Do you know of any timeline of when will this appear in avr-gcc, more precisely, in WinAVR/its sucessor?
JW
theusch
PostPosted: Jun 10, 2010 - 10:02 PM
10k+ Postman
Hmmm--my amateur reading of the C standard says to me that if the sei() and cli() are considered volatile (I'd think they should be as it is the same as modifying the SREG volatile sfr, right?), then the following should never get out of order:
Code:
cli();
frog = dog;
sei();
I use this draft for reference:
http://www.open-std.org/jtc1/sc22/wg14/ ... /n1124.pdf
Searching for sequence point, especially as related to volatile, I find:
5.1.2.3 Program execution
The semantic descriptions in this International Standard describe the behavior of an abstract machine in which issues of optimization are irrelevant.
Accessing a volatile object, modifying an object, modifying a file, or calling a function that does any of those operations are all side effects, which are changes in the state of the execution environment. Evaluation of an expression may produce side effects. At certain specified points in the execution sequence called sequence points, all side effects of previous evaluations shall be complete and no side effects of subsequent evaluations shall have taken place. (A summary of the sequence points is given in annex C.)
As the cli() is an access of a volatile object (at least I'd think that) things look pretty clear as "frog = dog;" is an "expression statement" and Appendix C lists
the expression in an expression
statement (6.8.3);
lists 6.8.3 as a sequence point, and 6.8.3 is the expression statement.
ArnoldB
PostPosted: Jun 10, 2010 - 10:04 PM
The __sync_*() buildins appeared in the GCC around v4.1.
I pointed to 4.3.5 documentation, because that is a current GCC version for Linux avr-gcc, and WinAvr is for sure not much different.
So the buildins are in GCC for some time now. I don't know if they have been implemented for the AVR target. If they have, why not use them? If they haven't avr-libc could implement those that make sense under the corresponding __sync_*_n names.
ArnoldB
PostPosted: Jun 10, 2010 - 10:27 PM
I just ran
Code:
int a;
void f() {
   a = 1;
   __sync_synchronize();
   a = 2;
void g() {
   a = 1;
   a = 2;
Through a 4.3.3 avr-gcc with -Os optimization and no other options.
Code:
   .file   "a.c"
__SREG__ = 0x3f
__SP_H__ = 0x3e
__SP_L__ = 0x3d
__tmp_reg__ = 0
__zero_reg__ = 1
   .global __do_copy_data
   .global __do_clear_bss
   .text
.global   g
   .type   g, @function
g:
/* prologue: frame size=0 */
/* prologue end (size=0) */
   ldi r24,lo8(2)
   ldi r25,hi8(2)
   sts (a)+1,r25
   sts a,r24
/* epilogue: frame size=0 */
   ret
/* epilogue end (size=1) */
/* function g size 7 (6) */
   .size   g, .-g
.global   f
   .type   f, @function
f:
   ldi r24,lo8(1)
   ldi r25,hi8(1)
   sts (a)+1,r25
   sts a,r24
   ldi r24,lo8(2)
   ldi r25,hi8(2)
   sts (a)+1,r25
   sts a,r24
   ret
/* function f size 15 (14) */
   .size   f, .-f
   .comm a,2,1
/* File "a.c": code   22 = 0x0016 (  20), prologues   0, epilogues   2 */
Looks like __sync_synchronize(); is implemented.
wek
PostPosted: Jun 10, 2010 - 10:45 PM
Sounds like a good news.
Is that avr-gcc which comes with WinAVR20100110?
Could you please try it also on the example above (I am not at a computer with avr-gcc)?
Are the other __sync_xxx() function also implemented? If yes, how do they achieve atomicity - through cli()/sei()?
JW
ArnoldB
PostPosted: Jun 10, 2010 - 11:37 PM
That is an avr-gcc build with the Bingo scripts on Linux.
Regarding the original example, it doesn't work. I think the reason is the same as for the version without sync, the compiler just doesn't consider cli or sei to be memory operands, so it doesn't care.
Code:
test2:
        mov r22,r24
        mov r23,r25
/* #APP */
        cli
/* #NOAPP */
        ldi r24,lo8(-1)
        ldi r25,hi8(-1)
        rcall __udivmodhi4
        sts (ivar)+1,r23
        sts ivar,r22
/* #APP */
        sei
/* #NOAPP */
        ret
/* function test2 size 16 (15) */
        .size   test2, .-test2
        .comm ivar,2,1
/* File "b.c": code   16 = 0x0010 (  15), prologues   0, epilogues   1 */
Lets see what __sync_add_and_fetch() does
Code:
int a;
void f() {
   a = 1;
   __sync_add_and_fetch(&a, 4);
   a = 2;
void g() {
   a = 1;
   a += 4;
   a = 2;
int main() {
   return 1;
Code:
   .file   "c.c"
__SREG__ = 0x3f
__SP_H__ = 0x3e
__SP_L__ = 0x3d
__tmp_reg__ = 0
__zero_reg__ = 1
   .text
.global   g
   .type   g, @function
g:
   ldi r24,lo8(2)
   ldi r25,hi8(2)
   sts (a)+1,r25
   sts a,r24
   ret
   .size   g, .-g
.global   main
   .type   main, @function
main:
   ldi r24,lo8(1)
   ldi r25,hi8(1)
   ret
/* function main size 3 (2) */
   .size   main, .-main
.global   f
   .type   f, @function
f:
   ldi r24,lo8(1)
   ldi r25,hi8(1)
   sts (a)+1,r25
   sts a,r24
   ldi r22,lo8(4)
   ldi r23,hi8(4)
   ldi r24,lo8(a)
   ldi r25,hi8(a)
   rcall __sync_add_and_fetch_2
   ldi r24,lo8(2)
   ldi r25,hi8(2)
   sts (a)+1,r25
   sts a,r24
   ret
/* function f size 18 (17) */
   .size   f, .-f
   .comm a,2,1
/* File "c.c": code   28 = 0x001c (  25), prologues   0, epilogues   3 */
So they aren't implemented in GCC 4.3.3 for the AVR. And the called function is also not in the library:
Code:
c.c:(.text+0x28): undefined reference to `__sync_add_and_fetch_2'
There is some opportunity for avr-libc to provide them. And to convince the GCC programmers to include cli/sei when considering memory operations.
