edwardchuajh
PostPosted: Feb 26, 2010 - 02:16 PM
Newbie
I understand that we can provide 5V power to the AVR chip by using e.g. a 9V wall supply through a 7805 chip and supporting capacitors etc.
However, if I have a high quality handphone charger, e.g. original Samsung or Motorola chargers which states itself as 5V, do I still need the 7805 circuitry?
If possible, how do I test if the voltage is indeed "safe" for the avr chip?
MBedder
PostPosted: Feb 26, 2010 - 02:19 PM
Resident
Just measure the output voltage of your "high quality handphone charger" BEFORE applying it to your AVR - I bet you'll get surprised Very Happy
Personman
PostPosted: Feb 26, 2010 - 02:33 PM
Have a look at this tutorial;
http://www.sparkfun.com/commerce/tutorial_info.php?tutorials_id=103
Plons
PostPosted: Feb 26, 2010 - 02:41 PM
There is another thing to be aware of with switching powersupplies: the leakagecurrent through the Y-cap. See this thread: http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=82257&start=0
Problems with Parallel Port Programmers ? Read this:
http://www.aplomb.nl/TechStuff/PPPD/PPPD%20English.html
edwardchuajh
PostPosted: Feb 26, 2010 - 04:06 PM
Newbie
Thanks!
Which means it'd still be advisable to get a linear voltage regulator and not cut corners.. hmm
However if in the case I'm running a series of 17 normals LEDs each drawing 30mA for a total of 510mA, and they're drawing power from the AVR chip, will it overheat the (regular) 7805 chip too much with an input voltage of 9V?
I am actually trying out a binary clock, and will hope it to run 24/7.
Sorry if it sounds off-topic, I am pretty new to this and if required I will promptly move this topic elsewhere.
Thanks!
P.S. If using the 7805 and AVR to run everything is not feasible, are there any obvious solutions?
MartinM57
PostPosted: Feb 26, 2010 - 04:17 PM
Resident
Although new to this, you need to get to be able to read and understand data sheets...
Power dissipated in regulator = 4 x 0.51 watts = 2.04 watts - yes it will get extreeemely hot without a good heatsink. Look at the 7805 data sheet for the thermal characteristics of a 7805 (a little bit complex to understand - Google can probably find somewhere where someone explains how to deal with the thermal characteristics of a regulator...)
510ma through the AVR will almost certainly destroy it - see the Electrical Characteristics section for your AVR. There is normally a limit to:
- amount of current for the whole chip
- amount of current for each output pin
I'll leave others to describe alternative solutions...
Personman
PostPosted: Feb 26, 2010 - 07:47 PM
Transistor as a switch switch.
http://www.ermicro.com/blog/?p=423
Though this links to the transistor as a switch section of this site, there is a lot of good info there.
http://www.allaboutcircuits.com/vol_3/chpt_4/2.html
Plons
PostPosted: Feb 26, 2010 - 09:48 PM
If you check the outputvoltage with a voltmeter as suggested by MBedder, and the result is OK, you *can* use that mobile phone charger for your final, enclosed clock, but with a big BUT during development: when everything is open on the table, you need to be aware of the leakage current mentioned in the thread posted earlier. Also note the voltages that come as a bonus with that leakage.
To get rid of those, connect the groundlead (or negative) of the secundary side of the powersupply, to safety ground of the mains.
If you are unsure about what I wrote, do use a traditional transformer-based wallwart .... at least during development.
theusch
PostPosted: Feb 26, 2010 - 10:05 PM
10k+ Postman
And be sure to check it with no-load, minimal app load (e.g., AVR in reset and no power suckers active), normal load, and max load. A lightly-loaded unregulated wallwart can have way-high voltages.
For demo rigs and the like, we keep a small stock of >>regulated<< wall-warts on hand in common voltages such as 5, 12, and 24 VDC.
Lee
edwardchuajh
PostPosted: Feb 28, 2010 - 12:09 PM
Newbie
thanks!
I think I will go with using Darlingtons,
was very useful =)
Thanks all!
