| Author |
Message |
Posted: Feb 09, 2010 - 12:15 PM |
Hello!
It´s me again. I want to confirm that when an End device is sleeping in the WSNDemo application (in Zigbit Development Kit), he wakes up and does the next sequence:
Transmit - Wait for acknowledge - Read acknowledge - Sleep
I send you the consumption curve to see what I mean. Is it true my theory?
In that case, if I put the node in no acknowledge mode, how can it knows that the network has or hasn´t fallen?
Thank you |
Posted: Feb 09, 2010 - 01:43 PM |
What exactly this image shows?
You can't. |
Posted: Feb 09, 2010 - 03:53 PM |
The image is the power consumption of a Zigbit Development Kit board during a transmission of a message by a end device. It´s like a castle, where the first peak should be the busy_tx state, the valley the "waiting for ack" state, and the second peak the busy_rx state. Am I right?
alexru, you are helping me a lot, I have to invite you to something (I´m kidding) |
Posted: Feb 09, 2010 - 04:31 PM |
alejandrofdelhierro wrote:
Am I right?
I don't think levels would be so distinctive. Power consumption differs not so much in RX and TX states (and radio is in RX mode when waiting for ack). Also there are IEEE ack frames transmitted (and received) for every frame automatically.
Why do you need to know the exact power consumption figure? |
Posted: Feb 09, 2010 - 06:46 PM |
Because I want to know what parameters in the program code affect the power consumption curve and how they affect.
What I´ve done is to put a 1 ohm resistance between CM- and CM+ terminals to see how the voltage changes in the resistance and so with the current (they are equivalent because of the 1 ohm value). So, what I see is in the next image (bigger than previous), are these three levels. If you say that after the first peak the node is in RX mode, what does the second peak mean?
Remember that the curve is for all BOARD, not only the module. |
Posted: Feb 09, 2010 - 08:36 PM |
Ok. If I recall correctly then wakeup sequence is:
1. MCU wakes up.
2. Radio wakes up.
3. Data request frame is sent (to get data from parent).
4. Rx mode to get possible data.
5. Application is notified about wakeup.
6. Application enables sensors (possible source of power consumption).
7. Application reads sensors data.
8. Application sends data frame.
9. Rx mode to get APS ack.
10. Application closes sensors.
11. Application puts MCU & radio to sleep.
Steps 3 and 4 are executed only if CS_AUTO_POLL is true (default value).
Before every transmission there is reception stage for clear channel assessment algorithm.
After any unicast transmission there is reception stage to receive MAC ack.
Possible sources of extra power consumption are sensors.
I will try to reproduce your experiment when I'll get to work after business trip (next week probably) and I'll try to time power consumption with actual transmissions. |
Posted: Feb 10, 2010 - 12:41 PM |
Mmmmmmmm, that changes a lot my point of view... Now I don´t know what´s influencing power consumption values!
But it has more sense.
How can I time and measure the power consumption of the communication process (not considering other processes like sensing)? Is it possible with the experiment I´m doing? At least the times would be fine cause I could model the power values with the theorical ones in the datasheets (MCU and transceiver ones).
It would be grate you to do the experiment also (although it´s not necessary if you want). Another possibility it´s to make more experiments to see if we discover something. I can have some tests with the sniffer to see some timings. If you have some other idea tell me. |
Posted: Feb 10, 2010 - 03:32 PM |
| I'll look into it when I'll be back at work. |
Posted: Feb 11, 2010 - 10:25 AM |
| OK, perfect, thank you very much. |
Posted: Feb 15, 2010 - 11:53 AM |
I´ve made a model with your information of the wakeup sequence and the timings of the steps with my sniffer, and everything is OK except when I change the CS_AUTO_POLL value to false.The end device doesn´t do steps 3 and 4(that´s expected) neither 9 or 10 and it resends the data all the time. As it is seen in the timings the end device usually sends a data request for the APS ack, and when CS_AUTO_POLL is false it doesn´t: it sends the data, waits for a while, and resends the data. I´ve tried to change the value just before sending the data (only to avoid steps 3 and 4) by CS_WriteParameter(CS_AUTO_POLL_ID, &autopoll), but it happens to me like with tx power (I couldn´t change the value with CS_Write function only with ZDO_SetTxPowerReq. In this case there is no ZDO_Set... function, so it doesn´t work).
How can I avoid only steps 3 and 4?
Do you know how can I change AUTO_POLL value in runtime? |
Posted: Feb 15, 2010 - 03:30 PM |
1. With autoPoll == false you should call NWK_SyncReq() by yourself.
2. CS_AUTO_POLL should be writable at runtime.
3. Task for investigating this is planned and should be done in couple weeks (lots of tasks with higher priorities). |
Posted: Feb 16, 2010 - 03:53 PM |
I have tried to change CS_AUTO_POLL at runtime and it works when changing from true to false but not the other way around. Neither using NWK_SyncReq() cause I know how to include this function in the code(reading stack´s network h files) but not how it works: I have the auto poll with true, send the first message, and before sleeping I change autopoll to false. Then in the next message I try to call NWK_SyncReq() or CS_WriteParameter(CS_AUTO_POLL_ID, &autopoll) but they don´t do anything and the message is resent all the time and the node doesn´t go to sleep.
Can you explain me how to use correctly the NWK_SyncReq()??
It would be fantastic to avoid steps 3 and 4 for our wake up sequence. |
Posted: Feb 16, 2010 - 06:15 PM |
What do you mean by "works"? Functions CS_{Read|Write}Value() do not check parameters or perform any actions on them, so value must be written successfully at all times.
Ok. I'll explain all this in a more detailed way.
1. When device wakes up it looks on a value of csAutoPoll variable. If it is true then stack calls NWK_SyncReq()
2. Correct way of working with NWK_SyncReq():
Code:
NWK_SyncReq_t syncReqParams;
syncReqParams.track = false;
syncReqParams.NWK_SyncConf = NWK_SyncConf;
NWK_SyncReq(&syncReqParams);
You should have function with prototype "void NWK_SyncConf(NWK_SyncConf_t *conf)"
Most interesting values of conf->status (in general it is any NWK and MAC status code):
MAC_SUCCESS_STATUS - request was sent and data was available (on this message you should immediately poll if new data available).
MAC_NO_DATA_STATUS - request was sent and no data available. Here you may want to go to sleep or poll again after some time.
Any other codes should be treated as errors.
3. To avoid implementation of this complex logic by user there are two functions available ZDO_StartSyncReq() and
ZDO_StopSyncReq().
If you call ZDO_StartSyncReq() stack will start to do what I described in item 2. You should call ZDO_StopSyncReq() before sleep in this case.
In your case you should set CS_AUTO_POLL to false (always). On wakeup call ZDO_StartSyncReq(), before sleep call ZDO_StopSyncReq().
The problem with this solution is that you don't know when all data was received to call ZDO_StopSyncReq(). To workaround this you may try to call NWK_SyncReq() manually.
CS_AUTO_POLL parameter was added later and API is not as clear as it could be. I'll try to do something about this. |
Posted: Feb 17, 2010 - 10:59 AM |
Thanks for that info. Now, a short question, how do I poll the new data? |
Posted: Feb 17, 2010 - 11:02 AM |
Call NWK_SyncReq() again. |
Posted: Feb 17, 2010 - 02:48 PM |
OK, with CS_AUTO_POLL = false, I´ve tried to put NWK_SyncReq() after waking up and before sleeping and the program blocks retrying to send the data message. It seems that it doesn´t recuperate the synchronism.
If I use only ZDO_StartSyncReq() when I wake up, the application recovers the control and send the messages correctly.
But if I put ZDO_StartSyncReq() when I wake up and ZDO_StopSyncReq() just before sleep, it goes to sleep and when it wakes up(see from the red light on) it stops sending messages even when in APP_WOKEUP is the ZDO_StartSyncReq().
Can you explain this? |
Posted: Feb 17, 2010 - 03:01 PM |
I'll need to see your source code. But what exactly you are trying to achieve? You are basically doing what stack will do by itself with CS_AUTO_POLL = true. |
Posted: Feb 17, 2010 - 03:26 PM |
These are the parts of the code I´ve changed:
Code:
case SENDING_DEVICE_STATE:
switch (event)
case APP_PROCESS:
visualizeAirTxStarted();
APL_WRITE_LOG(0x70)
[b]ZDO_StartSyncReq();[/b]
APS_DataReq(&messageParams);
appDeviceState = WAITING_DEVICE_STATE;
break;
default:
break;
break;
case SLEEPPING_DEVICE_STATE:
switch (event)
case APP_PROCESS:
[b]ZDO_StopSyncReq();[/b]
APL_WRITE_LOG(0x7C)
visualizeSleep();
if (!isVisualizerReadyToSleep())// Wait for Visualizer ready
appDeviceState = WAITING_VISUALIZER_STATE;
appPostSubTaskTask();
ZDO_SleepReq(&sleepReq);
break;
case APP_WOKEUP:
visualizeWakeUp();
APL_WRITE_LOG(0x7F)
appDeviceState = READING_SENSORS_STATE;
break;
default:
break;
break;
case WAITING_VISUALIZER_STATE:
switch (event)
case APP_PROCESS:
break;
default:
break;
break;
What I want to achieve for my application is:
1. MCU wakes up.
2. Radio wakes up.
(I don´t want to get possible data from parent)
3. Application is notified about wakeup.
4. Application enables sensors.
5. Application reads sensors data.
6. Application sends data frame.
7. Rx mode to get APS ack.
(Here I think I have to activate syncrhonism to get APS ack)
8. Application closes sensors.
9. Application puts MCU & radio to sleep.
(I don´t want to poll again any data from parent as it´s programmed, just go to sleep)
It´s possible handling it with ZDO_Start and Stop Sync functions? |
Posted: Feb 17, 2010 - 03:40 PM |
Code looks ok,it is possible that there are some bugs in ZDO_Start/StopSyncReq(), but it does not matter right now.
The first thing that ZDO_StartSyncReq() does is send poll frame to parent, so your code still behaves like original stack.
Not polling for data is dangerous (not to mention standard incompatible) - ZDO commands are also passed to device via polling, so you MUST poll to get ALL data (and commands) available, otherwise you won't be ZigBee compatible any more.
For extremely low power application consider simple proprietary protocol. |
Posted: Feb 17, 2010 - 03:52 PM |
OK, but you told me that steps 3 and 4 in the original wake up sequence were avoidable maintaing standard compability didn´t you?
At least, is it possible to do only one poll at the beginning or the end of the active stage and not both?
I just want to know how to do that, to force the possibilities of the Zigbee without escaping from it. |
Last edited by alejandrofdelhierro on Feb 18, 2010 - 10:30 AM; edited 1 time in total
