damien_d
PostPosted: Nov 01, 2009 - 02:53 AM
Resident
Hello all,
Today I attempted to build the agv-gcc toolchain for Ubuntu 9.10 (Karmic) - file is build-avr-gcc-4.3.3-libc-1.6.7-insight6.8-arch25-fix.zip from thread http://www.avrfreaks.net/index.php?name ... mp;start=0
When executing ./buildavr-no-insight.sh , I get the following build error:
Code:
../../../source/avarice-2.10/src/jtag2.h: In constructor ‘jtag2::jtag2(const char*, char*, bool, bool, bool, bool)’:
../../../source/avarice-2.10/src/jtag2.h:155: warning: large integer implicitly truncated to unsigned type
mv -f .deps/jtag2misc.Tpo .deps/jtag2misc.Po
g++ -DHAVE_CONFIG_H -I. -I../../../source/avarice-2.10/src     -g -O2 -MT jtag2prog.o -MD -MP -MF .deps/jtag2prog.Tpo -c -o jtag2prog.o ../../../source/avarice-2.10/src/jtag2prog.cc
In file included from ../../../source/avarice-2.10/src/jtag2prog.cc:43:
../../../source/avarice-2.10/src/jtag2prog.cc: In member function ‘virtual void jtag2::downloadToTarget(const char*, bool, bool)’:
../../../source/avarice-2.10/src/jtag2prog.cc:250: warning: deprecated conversion from string constant to ‘char*’
mv -f .deps/jtag2prog.Tpo .deps/jtag2prog.Po
g++ -DHAVE_CONFIG_H -I. -I../../../source/avarice-2.10/src     -g -O2 -MT jtag2run.o -MD -MP -MF .deps/jtag2run.Tpo -c -o jtag2run.o ../../../source/avarice-2.10/src/jtag2run.cc
In file included from ../../../source/avarice-2.10/src/jtag2run.cc:39:
../../../source/avarice-2.10/src/jtag2run.cc: In member function ‘bool jtag2::eventLoop()’:
../../../source/avarice-2.10/src/jtag2run.cc:130: warning: ignoring return value of ‘ssize_t write(int, const void*, size_t)’, declared with attribute warn_unused_result
mv -f .deps/jtag2run.Tpo .deps/jtag2run.Po
g++ -DHAVE_CONFIG_H -I. -I../../../source/avarice-2.10/src     -g -O2 -MT jtag2rw.o -MD -MP -MF .deps/jtag2rw.Tpo -c -o jtag2rw.o ../../../source/avarice-2.10/src/jtag2rw.cc
In file included from ../../../source/avarice-2.10/src/jtag2rw.cc:38:
mv -f .deps/jtag2rw.Tpo .deps/jtag2rw.Po
g++ -DHAVE_CONFIG_H -I. -I../../../source/avarice-2.10/src     -g -O2 -MT jtag2usb.o -MD -MP -MF .deps/jtag2usb.Tpo -c -o jtag2usb.o ../../../source/avarice-2.10/src/jtag2usb.cc
../../../source/avarice-2.10/src/jtag2usb.cc: In function ‘usb_dev_handle* opendev(const char*, emulator, int&)’:
../../../source/avarice-2.10/src/jtag2usb.cc:98: error: invalid conversion from ‘const char*’ to ‘char*’
../../../source/avarice-2.10/src/jtag2usb.cc: In function ‘void childhandler(int)’:
../../../source/avarice-2.10/src/jtag2usb.cc:249: warning: ignoring return value of ‘ssize_t write(int, const void*, size_t)’, declared with attribute warn_unused_result
make[2]: *** [jtag2usb.o] Error 1
make[2]: Leaving directory `/usr/local/avr/build/avarice-2.10/src'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/usr/local/avr/build/avarice-2.10/src'
make: *** [all-recursive] Error 1
It appears that it is building as C++, and therefore has the following two prototypes:
Code:
const char * strchr ( const char * str, int character );
      char * strchr (       char * str, int character );
Since jtagDeviceName is a const char*, it expects that serno is also a const char*l which is isn't, hence the error.
The following trivial patch makes it build. I have no idea if it introduces any bugs:
Code:
damien@damien-desktop:~$ sudo diff -u /root/jtag2usb.cc /usr/local/avr/build/avarice-2.10/src/../../../source/avarice-2.10/src/jtag2usb.cc
--- /root/jtag2usb.cc   2009-11-01 12:21:42.000000000 +1000
+++ /usr/local/avr/build/avarice-2.10/src/../../../source/avarice-2.10/src/jtag2usb.cc  2009-11-01 12:23:52.000000000 +1000
@@ -95,7 +95,7 @@
    * right-to-left, so only the least significant nibbles need to be
    * specified.
-  if ((serno = strchr(jtagDeviceName, ':')) != NULL)
+  if ((serno = strchr(const_cast<char*>(jtagDeviceName), ':')) != NULL)
       /* first, drop all colons there if any */
       cp2 = ++serno;
Recently, I built the same script for 9.04 without issue on another box.
-- Damien
js
PostPosted: Nov 01, 2009 - 04:38 AM
10k+ Postman
Location: Sydney, Australia (Gum trees, Koalas and Kangaroos, No Edelweiss)
Using "Bingo's Script" can be a bit of a gamble... Wink
Bingo600
PostPosted: Nov 01, 2009 - 06:39 PM
@OP
Are you using GCC 4.4.1 (native ubuntu gcc) to build the toolchain ?
Someone did hit a similar thing here
http://www.avrfreaks.net/index.php?name ... 640#629640
/Bingo
Bingo600
PostPosted: Nov 01, 2009 - 07:21 PM
@OP (or others) would it be possible to try out this new buildscript
http://www.avrfreaks.net/index.php?name ... 369#634369
I don't have a ubuntu 9.10 (gcc 4.4.1) install
/Bingo
damien_d
PostPosted: Nov 01, 2009 - 10:08 PM
Resident
Bingo600 wrote:
@OP
/Bingo
Yes, the native gcc for Ubuntu 9.10:
Code:
damien@damien-desktop:~/code$ gcc --version
gcc (Ubuntu 4.4.1-4ubuntu8) 4.4.1
Copyright (C) 2009 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Bingo600
PostPosted: Nov 02, 2009 - 07:25 AM
damien_d wrote:
Bingo600 wrote:
@OP
/Bingo
Code:
@damien_d
Did you try the new buildscript ?
/Bingo
damien_d
PostPosted: Nov 02, 2009 - 07:51 AM
Resident
/Bingo
Just got home from work... yep, it built fine Smile
Thank you very much.
-- Damien
Bingo600
PostPosted: Nov 02, 2009 - 08:39 AM
damien_d wrote:
/Bingo
-- Damien
Thanx
The script is now updated in the first post in the "sticky"
/Bingo
gottymann
PostPosted: Dec 18, 2009 - 05:17 PM
Newbie
http://freewebcontents.blogspot.com/200 ... oblem.html
clawson
PostPosted: Dec 18, 2009 - 05:23 PM
10k+ Postman
gottymann wrote:
http://freewebcontents.blogspot.com/2009/11/ubuntu-910-display-problem.html
What on God's green earth has an ATI radeon graphics problem in Ubuntu got to do with the subject of this thread?
Or are you just joining fora and grapeshotting any mention of "Ubuntu" however irrelevant in the hope of finding someone with ATI experience?
