t0mmy
PostPosted: Aug 20, 2009 - 11:37 AM
Newbie
Hello to all Win7 users Very Happy
I did not expect any problems while switching from Vista x64 to Win7 x64, but with the JTAGICE mkII I had some.
So here is a short step-by-step driver installation tutorial:
  1. As you may remember, there where always 2 devices in the Jungo-folder in the Device Manager. By right clicking on the computers name in the Device Manage, selecting "Add legacy hardware" you can install an extra driver.
  2. click next
  3. select "Install the hardware, that I manually select from a List (Advanced)"
  4. select "Show All Devices"
  5. click on "Have disc" and point to "C:\Program Files (x86)\Atmel\AVR Tools\usb64\windrvr6.inf"
  6. select WinDriver an continue by clicking "next" and "install" many times Wink
  7. now you can install the JTAGICE mkII driver. Reinstall it, if you have tried it already, it should work now. If you let Windows search on the Internet, it will find the correct one.
  8. when it looks like this, it should work:
Tell me if there are some errors here...
Student at the University of Applied Sciences Ulm, Germany
dak664
PostPosted: Aug 20, 2009 - 09:07 PM
Resident
Worked for my Dragon. Brilliant!
madwizard
PostPosted: Aug 28, 2009 - 06:18 PM
Wannabe
Thanks, worked great with my AVRISP mkII on Win7 64-bit as well!
ratn9ne
PostPosted: Sep 02, 2009 - 03:37 AM
Newbie
you sir are the king of the internets Smile
Svuppe
PostPosted: Sep 13, 2009 - 02:47 PM
Two thumbs up from me as well. Worked perfectly for my Dragon.
Now I will try the same trick with the driver for my Xilinx FPGA dev board, which up until now has failed just like this one. Worth a try.
Eviltelm
PostPosted: Sep 21, 2009 - 03:51 PM
Rookie
Thanks, did the trick with my avrisp mkII Smile
Chupa
PostPosted: Sep 27, 2009 - 11:20 PM
Wannabe
works for stk600 as well! thanks!
Ekkeri
PostPosted: Oct 06, 2009 - 12:47 AM
Newbie
Thank you! I think my Dragon might work now. Smile
klaly
PostPosted: Oct 25, 2009 - 07:16 PM
Newbie
Thanks a lot,
your methode works fine.
I use the AVRISP mkII with Windows7 64bit
best regards from germany
klaly
basil|
PostPosted: Oct 26, 2009 - 03:49 AM
Rookie
Spectacular! My ISP mkII now works with Win7 32bit; I was just about to throw it in the back of a drawer...
Many thanks.
RRRoamer
PostPosted: Oct 26, 2009 - 03:15 PM
I just want to add that it is critical to use the "Add legacy hardware"! I had previously installed Windows 7 64bit on my laptop and got everything working thanks to this guide. When I finally decided to upgrade my main system to Windows 7 64bit, the avrisp mkii was already in the device manager as an unknown device, so I simply updated the driver and pointed it to the correct driver.
It appeared to install correctly and the USB LED lite up like it should when I plugged in my avrisp mk ii. But, when I went to connect to it via AVR Studio, it could never connect and would time out and go back to the connection screen.
After playing with a a bit, I FINALLY remembered the "Add legacy hardware" bit and uninstalled the device, then reinstalled it correctly. Needless to say, it worked perfectly the first time when I installed it via the legacy hardware method.
Just something to keep in mind.
Clint
j0nk13
PostPosted: Oct 31, 2009 - 08:21 PM
Newbie
THANKS! dragon working on win 7 64bit
justinmreina
PostPosted: Nov 01, 2009 - 02:07 AM
Newbie
Thanks! This worked great for my mkII. Looks like I learned something new about Win7 Smile
This forum is great for stuff like this!
-Justin
ChristoffF
PostPosted: Nov 06, 2009 - 11:53 AM
Newbie
Yay ! It worketh again ! Thank you for the clear and detailed guide.
implor
PostPosted: Nov 07, 2009 - 02:56 AM
Newbie
This do not work for me. Step 1-6 works (I get winDriver installed) but then how do I install the JTAGICE mkII driver ? I reinstall Avr studio 4 but that doesen't work it can't find the driver. Any ides? Can you download the JTAGICE mkII driver?
t0mmy
PostPosted: Nov 07, 2009 - 07:55 PM
Newbie
As far as I remember, I just let Windows search automatically for the Driver and that's all. But maybe you will find it at the same place as step 5.
EDIT: Step5 is not the correct answer. I can't say where to find it.
But as I said, Win7 will find it by itself.
clawson
PostPosted: Nov 08, 2009 - 02:03 PM
10k+ Postman
Just to note that it's been reported that Studio 4.18 RC3 has been reported to work with without needing this mod. Future readers of this thread may well be reading this after the official release of Studio 4.18 so maybe try upgrading to that first?
Mr_CookiePants
PostPosted: Dec 23, 2009 - 08:14 PM
Newbie
So i have a problem.... my avrisp mkII doesnt work because the drive message is Device couldnt start (CODE 10) so whats the problem and how can i solve it?
i have the Windows 7 32-bit OS
Thanks for all useful answers
oitguy
PostPosted: Jan 16, 2010 - 06:49 AM
Newbie
success! thank you... using AVRISP mkII with Win 7 x64
vivapaco
PostPosted: Jan 19, 2010 - 11:04 AM
Newbie
Wow, thanks so much! I got tired of haveing to switch to my XP laptop just to use the jtagice.
