suzyq
PostPosted: Jun 30, 2009 - 03:04 PM
Rookie
I have to implement access to a 32bit SPI device.
The atmel_spi driver is only supporting 8 and 16bit devices.
I have to use the bit-banging SPI driver therefore Shocked
Does anybody have experience with this bit-banging driver?
How do I have to change board setup?
How do access the driver from userspace?
Gerhard
rmelizalde
PostPosted: Jun 30, 2009 - 03:50 PM
Wannabe
Hi guy,
Upgrade your kernel to 2.6.29. In this version, spi-gpio driver has been added. It uses common gpio framework, which is harware independent.
Take a look at thread (mine Smile ) " Example code to initialize new spi-gpio driver", dated 2nd of June.
I left default word-width (not sure, 8 bits). It is much slower than atmel_spi. I set clock to 500KHz and worked really well for writing to SPI flash in NGW100.
BR
Ricardo
suzyq
PostPosted: Jul 01, 2009 - 09:51 AM
Rookie
Hi Ricardo,
thanks for you hint! Very Happy
500kHz bit frequency is OK for my application ...
Gerhard
savenlid
PostPosted: Jul 10, 2009 - 11:58 AM
Wannabe
Why doesent atmel fix a decent spi driver that can be accessed from user-space ?
or have they allready ?
I am confused how this can be a problem, why force customers into bit-banging instead of providing a decent driver ?
Or have I missunderstood all this.
I also need to drive a small lcd-display over spi.
/Nicholas
leon_heller
PostPosted: Jul 10, 2009 - 01:39 PM
Just send two or three lots of 8-bit data, there shouldn't be any need for bit-banging. It usually works.
Leon
Leon Heller
G1HSM
 View user's profile Send private message Send e-mail Visit poster's website
suzyq
PostPosted: Jul 10, 2009 - 07:20 PM
Rookie
the problem is, that some devices don't like it, if the SPI-CS line goes high (inactive) between multi-byte/multi-word transfers.
I have to read 32bit words from an ADC.
The atmel-spi driver definitely puts SPI-CS high during two 16bit transfers.
Since SPI-CS is controlled via GPIO in the atmel-spi driver, it shouldn't be that big problem to implement 32bit transfers ...
Gerhard
mw1987
PostPosted: Jul 10, 2009 - 08:23 PM
Newbie
I think nobody will prevent you from adapting the atmel-spi-driver. find the line of code and add your adaption for 32-bit-words.
This should be easier than changing to the bit-banging-driver and it is more efficient.
greetings
rmelizalde
PostPosted: Jul 13, 2009 - 09:17 AM
Wannabe
But RDR & TDR registers are 16 bits-wide...
Receiving 32 bits into RDR continously might be problematic? Who knows? I don't.
Ric
