nackmasm
PostPosted: Jun 19, 2009 - 10:32 AM
Newbie
I am using an at90usb1287 and working in asm. Currently, my program collects 256 data points (1 byte each) and stores them to SRAM. I would like to add a block to my program that takes these 256 data points and finds all of the frequencies in the signal. FFT comes to mind, but I am open to other ideas. I have looked at some FFT code in asm and cannot seem to figure it out. I am very new to all of this stuff, so maybe someone with more experience could help me figure out how to implement some FFT code. Also, at this point, I am not particularly concerned with accuracy or optimization...I just want something that works.
Sam
clawson
PostPosted: Jun 19, 2009 - 10:56 AM
10k+ Postman
http://elm-chan.org/works/akilcd/report_e.html
leon_heller
PostPosted: Jun 19, 2009 - 10:58 AM
The FFT is the usual technique, I don't think you will find anything else unless you know the frequencies in advance. Experiment with it on the PC before you try getting it to run on an AVR.
Leon
Leon Heller
G1HSM
 View user's profile Send private message Send e-mail Visit poster's website
nackmasm
PostPosted: Jun 19, 2009 - 12:43 PM
Newbie
Clawson, I went to the url you provided and looked at the code. Some of it seems to be for using the adc and some seems to be for output to the lcd. I don't really even understand where the data points are loaded. Can someone explain where the raw data goes in, and where the transformed data comes out? Could someone send me a stripped-down version of this code (only containing the actual fft) so that I can start to understand what is going on? Maybe fft is just too complicated for me to understand in asm given my level of experience. Any help would be appreciated.
clawson
PostPosted: Jun 19, 2009 - 01:21 PM
10k+ Postman
Sounds like it.
leon_heller
PostPosted: Jun 19, 2009 - 01:33 PM
Here is a very well commented FFT function from the Microchip dsPIC library:
Code:
;                       Software License Agreement                   *
;   The software supplied herewith by Microchip Technology           *
;   Incorporated (the "Company") for its dsPIC controller            *
;   is intended and supplied to you, the Company's customer,         *
;   for use solely and exclusively on Microchip dsPIC                *
;   products. The software is owned by the Company and/or its        *
;   supplier, and is protected under applicable copyright laws. All  *
;   rights are reserved. Any use in violation of the foregoing       *
;   restrictions may subject the user to criminal sanctions under    *
;   applicable laws, as well as to civil liability for the breach of *
;   the terms and conditions of this license.                        *
;   THIS SOFTWARE IS PROVIDED IN AN "AS IS" CONDITION.  NO           *
;   WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING,    *
;   BUT NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND    *
;   FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE     *
;   COMPANY SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL,  *
;   INCIDENTAL OR CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.  *
;   (c) Copyright 2003 Microchip Technology, All rights reserved.    *
; This Complex DIF FFT implementation expects that the input data is a
; complex vector such that the magnitude of the real and imaginary parts
; of each of its elements is less than 0.5. If greater or equal to this
; value the results could produce saturation.
; Also, the program performs an implicit scaling of 1/2 for every stage
; to the intermediate values, so that the output values are scaled by a
; factor of 1/N, with N the length of the FFT.
; NOTE: input is expected in natural ordering, while output is produced
; in bit reverse ordering.
   ; Local inclusions.
   .nolist
   .include   "dspcommon.inc"      ; fractsetup,CORCON
                  ; PSVPAG, COEFFS_IN_DATA,
   .list
   .section .libdsp, code
; _FFTComplexIP: Complex (in-place) DIF FFT.
; Operation:
;   F(k) = 1/N*sum_n (f(n)*WN(kn)), WN(kn) = exp[-(j*2*pi*k*n)/N],
; n in {0, 1,... , N-1}, and
; k in {0, 1,... , N-1}, with N = 2^m.
; Input:
;   w0 = number stages in FFT (log2N)
;   w1 = ptr to complex source vector (srcCV)
;   w2 = ptr to complex twiddle factors (twidFactors)
;   w3 = COEFFS_IN_DATA, or memory program page with twiddle factors.
; Return:
;   w0 = ptr to source vector (srcCV)
; System resources usage:
;   {w0..w7}   used, not restored
;   {w8..w13}   saved, used, restored
;    AccuA      used, not restored
;    AccuB      used, not restored
;    CORCON      saved, used, restored
;    PSVPAG      saved, used, restored (if factors in P memory)
; DO and REPEAT instruction usage.
;   2 level DO intruction
;   no REPEAT intructions
; Program words (24-bit instructions):
;   60
; Cycles (including C-function call and return overheads):
;   transform   factors      factors
;      size      in X-mem   in P-mem
;    32-point      1664         1827
;    64-point      3802         4189
;   128-point      8612         9511
;   256-point     19310        21361
;   512-point     42872       47483
   ; Local equates.
   ; Commented to avoid IAR assembler problems...
;   .equ   oTwidd,w3
;   .equ   pTwidd,w8
;   .equ   nGrps,w9
;   .equ   pUpper,w10
;   .equ   pLower,w11
;   .equ   groupCntr,w12
;   .equ   buttCntr,w13
   ; The symbols have been replaced in the code by the corresponding
   ; working registers; the comments maintain the symbols for clarity.
   .global   _FFTComplexIP   ; export
_FFTComplexIP:
   ; Save working registers.
   push.d   w8            ; {w8,w9} to TOS
   push.d   w10            ; {w10,w11} to TOS
   push.d   w12            ; {w12,w13} to TOS
   ; Prepare CORCON for fractional computation.
   push   CORCON
   fractsetup   w7
   ; Prepare CORCON and PSVPAG for possible access of data
   ; located in program memory, using the PSV.
   push   PSVPAG
   mov   #COEFFS_IN_DATA,w7      ; w7 = COEFFS_IN_DATA
   cp   w7,w3            ; w7 - w3
   bra   z,_noPSV         ; if w3 = COEFFS_IN_DATA
                  ; no PSV management
                  ; else
   psvaccess   w7         ; enable PSV bit in CORCON
   mov   w3,PSVPAG         ; load PSVPAG with program
                  ; space page offset
_noPSV:
   push   w1            ; save return value (srcCV)
   ; FFT proper.
   mov   #0x1,w9            ; to be shifted...
   sl   w9,w0,w9         ; w9 = N (1<<log2N)
   mov   #0x1,w3            ; initialize twidds offset,
                  ; also used as num butterflies
   mov   w2,w8            ; w8-> WN(0) (real part)
   ; Preform all k stages, k = 1:log2N.
   ; NOTE: for first stage, 1 butterfly per twiddle factor (w3 = 1)
   ; and N/2 groups  (w9 = N/2) for factors WN(0), WN(1), ..., WN(N/2-1).
   mov   w0,w13            ; w13= num stages
                  ; w0 available for reuse
_doStage:
   ; Perform all butterflies in each stage, grouped per twiddle factor.
   ; Update counter for groups.
   lsr   w9,w9            ; w9 = N/(2^k)
   sl   w9,#2,w12         ; w12= lower offset
                  ; nGrps+sizeof(fractcomplex)
                  ; *2 bytes per element
   ; Set pointers to upper "leg" of butterfly:
   mov   w1,w10            ; w10-> srcCV (upper leg)
   ; Perform all the butterflies in each stage.
   dec   w3,w4            ; w4 = butterflies per group
   do   w4,_endBflies      ; {   ; do 2^(k-1) butterflies
   ; Set pointer to lower "leg" of butterfly.
   add   w12,w10,w11         ; w11-> srcCV + lower offset
                  ; (lower leg)
   ; Prepare offset for twiddle factors.
   sl   w3,#2,w0         ; oTwidd*sizeof(fractcomplex)
   ; Perform each group of butterflies, one for each twiddle factor.
   dec   w9,w4            ; w4 = nGrps-1
   do   w4,_endGroup      ; {   ; do (nGrps-1)+1 times
                  ; no more nested do's...
.ifdef YMEM_ERRATA
    nop
.endif
   ; Butterfly proper.
   clr   a,[w8]+=2,w6,[w10]+=2,w4   ; a  = 0 (for dual fetch only)
                  ; w6 = Wr
                  ; pTwidd-> Wi
                  ; w4 = Ar
                  ; pUpper-> Ai (=Ci)
   sub   w4,[w11++],w4         ; w4 = Ar - Br
                  ; pLower-> Bi (=Di)
   mpy   w4*w6,a,[w8]-=2,w7,[w10]-=2,w5   ; a  = (Ar - Br)*Wr
                  ; w7 = Wi
                  ; pTwidd-> Wr
                  ; w5 = Ai
                  ; pUpper-> Ar (=Cr)
   ; Update twiddle pointer.
   add   w0,w8,w8         ; pTwidd-> for next group
   mpy   w4*w7,b            ; b  = (Ar - Br)*Wi
   sub   w5,[w11--],w5         ; w5 = Ai - Bi
                  ; pLower-> Br (=Dr)
   msc   w5*w7,a,[w11]+=2,w7      ; a  = (Ar - Br)*Wr
                  ;    - (Ai - Bi)*Wi = Dr
                  ; w7 = Br
                  ; pLower-> Bi (=Di)
   mac   w5*w6,b,[w11]-=2,w5      ; b  = (Ar - Br)*Wi
                  ;    + (Ai - Bi)*Wr = Di
                  ; w5 = Bi
                  ; pLower-> Br (=Dr)
   sac.r   a,#1,[w11++]         ; save 1/2*Dr
                  ; pLower-> Bi (=Di)
   sac.r   b,#1,[w11++]         ; save 1/2*Di
                  ; pLower-> Br (next)
   lac   [w10++],a         ; a  = Ar
                  ; pUpper-> Ai (=Ci)
   lac   [w10--],b         ; b  = Ai
                  ; pUpper-> Cr
   add   w7,a            ; a  = Ar + Br
   add   w5,b            ; b  = Ai + Bi
   sac.r   a,#1,[w10++]         ; save 1/2*Cr
                  ; pUpper-> Ci
_endGroup:
   sac.r   b,#1,[w10++]         ; save 1/2*Ci
                  ; pUpper-> Ar (next)
   add   w12,w10,w10         ; w10-> upper leg (next set)
_endBflies:
   mov   w2,w8            ; rewind twiddle pointer
   ; Update offset to factors.
   sl   w3,w3            ; oTwidd *= 2
   ; Find out whether to perform another stage...
   dec   w13,w13            ; w13= log2N - k -1
   bra   gt,_doStage         ; if W13 > 0, do next stage
_endStages:               ; else, no more stages...
   pop   w0            ; restore return value
   ; Restore PSVPAG and CORCON.
   pop   PSVPAG
   pop   CORCON
   ; Restore working registers.
   pop.d   w12            ; {w12,w13} from TOS
   pop.d   w10            ; {w10,w11} from TOS
   pop.d   w8            ; {w8,w9} from TOS
   return
   .end
; OEF
It uses the DSP engine, of course. AVRs don't have anything comparable.
Leon
Leon Heller
G1HSM
jayjay1974
But you could treat an FFT routine as a black box, you don't have to understand FFTs in intimate detail to be able to use it.
As long as you understand what goes in and what comes out, then how the routine does its trick is not really relevant.
nackmasm
PostPosted: Jun 19, 2009 - 01:38 PM
Newbie
This is exactly what I am looking for. I am just struggling to figure out where the input and output goes in the code I have been looking at.
Leon, thanks. This looks like it might help.
ArnoldB
PostPosted: Jun 19, 2009 - 07:03 PM
Well, both "what goes in" and "what goes out", work better when you actually know what you are doing. Some knowledge about the DFT in general and and the particular FFT algorithm in particular can avoid a lot of tears and hair-pulling.
leon_heller
PostPosted: Jun 19, 2009 - 07:06 PM
You also need to do things like "windowing", simply applying an FFT won't work.
Leon
Leon Heller
G1HSM
ka7ehk
PostPosted: Jun 19, 2009 - 09:58 PM
10k+ Postman
You can find out a LOT more here.
http://www.dspguide.com/pdfbook.htm
It is well written and not constrained to conventional DSPs. All of the algorithms are actually demonstrated in BASIC! I highly recommend it
Jim Wagner
Oregon Research Electronics, Consulting Div.
Tangent, OR, USA
There are some answers that have no questions.
nackmasm
PostPosted: Jun 23, 2009 - 01:12 PM
Newbie
Thanks, Jim.
tyler.w.gilbert
PostPosted: Jun 30, 2009 - 05:12 AM
Rookie
Windowing is a technique used when designing digital filters. It is no necessary to do frequency analysis with an FFT. As an aside, no windowing (truncating) is equivalent to applying a rectangular window.
Tyler
www.coactionconsulting.com
jayjay1974
PostPosted: Jun 30, 2009 - 12:47 PM
I have do not have much experience with FFTs, but the few times I read things about, windowing the data before applying the FFT is very common.
For example, in LTSpice you can select a quite few windowing options for the FFT graph.
leon_heller
PostPosted: Jun 30, 2009 - 12:58 PM
Windowing is needed to avoid errors due to leakage when performing an FFT!
Leon
Leon Heller
G1HSM
ganzziani
PostPosted: Jun 30, 2009 - 02:09 PM
Resident
Leon
Applying an FFT to a block of data (without windowing) DOES work. The resulting data set IS the FFT of the original data.
Yes, I understand the windowing is necessary and convinient from an analysis point of view (frequency leakage as you say on your other post), but not from a mathematical point of view.
www.gabotronics.com
tyler.w.gilbert
PostPosted: Jun 30, 2009 - 03:35 PM
Rookie
I concede. Windowing will reduce leakage and is necessary. However, collecting 256 data points and performing an FFT is equivalent to a de facto rectangular window. Rectangular windows have the worst frequency leakage characteristics, but for a beginning it is probably sufficient.
Tyler
ka7ehk
PostPosted: Jun 30, 2009 - 05:57 PM
10k+ Postman
Be aware that the frequency span and resolution are intimately tied to the sample rate and the total number of samples.
Jim Wagner
Tangent, OR, USA
ArnoldB
PostPosted: Jun 30, 2009 - 07:09 PM
No, an FFT (there are several) is just an algorithm. The result of an FFT is a set of Fourier coefficients of a discrete Fourier series (DFS), representing a periodic discrete time signal.
The crux lies in the periodic property. The way you obtained (by sampling) the original discrete time signal makes it unlikely that you sampled exactly a multiple of periods of the signal. Instead, you have cut the signal somewhere midway. So your samples don't represent your original signal, but a different one.
You now feed the wrong data into an FFT algorithm, and you obtain the coefficients of a DFS for that wrong signal. Yes, you got the right coefficients for your data, only that your data doesn't represent your signal. So the coefficients aren't the right ones for a DFS of your original signal. Garbage in, garbage out.
Simple windowing, or more advanced windowing techniques like Bartlett or Welsh try to mitigate the problem of feeding the wrong data into an FFT algorithm. The result is a set of DFS coefficients that are in some (but not all) aspects better. "better" as in closer to the real DFS coefficients of your original signal.
ganzziani
PostPosted: Jun 30, 2009 - 08:01 PM
Resident
ArnoldB. I understand and agree to what you are saying.
I was trying to differentiate the analitical vs the mathematical aspects of the DFT.
From a mathematical point of view, if you apply a DFT to a data set, you get a set of DFT coefficients that represent the original data set in the frequency domain.
www.gabotronics.com
