clawson
PostPosted: May 01, 2009 - 02:34 PM
10k+ Postman
I just applied SP1 to Studio (available from www.atmel.no/beta_ware ). The change history states:
Part support
The following new parts have been added to AVR Studio since 4.15:
- ATxmega16D4, ATxmega32D4, ATxmega64D3, ATxmega128D3, ATxmega256D3
Check the device matrix to see which devices are supported by which tools: See a list of all supported devices and tools here.
New Features
AVR ISP mkII command line SW support for XMEGA device family
Bug Fixes
9473: Programming window - Empty Flash's .hex file read-back after programming and verification
9510: Cannot program a bootloader
7966: ATmega329P signature wrong.
9291: Misguidance in AVR Studio Help-->AVR Studio User Guide-->Getting Started-- >Debugging external code projects
9545: Bug in partdescription file of ATmega640
9505 ATmega640 needs STK600 support
9509 The include file for ATxmega128A1 contains errors
9528 Wrong fuse description in ATtiny48/88
9508 I am not asked if I want to reload project even if it has changed
Perhaps the most significant of those being that bootloaders can now be programmed once again.
js
PostPosted: May 02, 2009 - 12:05 AM
10k+ Postman
Location: Sydney, Australia (Gum trees, Koalas and Kangaroos, No Edelweiss)
Unfortunately no mention of a fix for the register windows bugs. Crying or Very sad
http://www.avrfreaks.net/index.php?name ... mp;t=77781
Obviously a case of discrimiation against ASM user. I'm off to the international court of justice. Laughing
Mikeharrison
PostPosted: May 10, 2009 - 11:26 AM
Part support
New Features
Bug Fixes
And hopefully it now doesn't trash M88 config fuses, rendering the chip unuseable - will test this today on a chip that isn't soldered in after trashing 3 qfp's yesterday Sad
clawson
PostPosted: May 10, 2009 - 12:17 PM
10k+ Postman
Reading your other thread it sounded more like you've inadvertently set CKSELs to the wrong combo and need to inject a clock - have you tried that?
Mikeharrison
PostPosted: May 10, 2009 - 12:34 PM
Just found the problem - an OSC pin was shorted to gnd, so as soon as the clock was set to external, it died, and the injected clock was getting shorted out!
