| Author |
Message |
Posted: Mar 18, 2009 - 11:39 PM |
Using AVR Timer/Counters: Pulse Width Modulation Modes
OK Freaks, thanks for your responses and suggestions after my plea (below). I've reposted the whole enchilada as a pdf with the code and makefile in a zip.
Please note: You have to log in if you want to be able to download the files and read the tutorial!
Does this work for everyone??
I'll wait a few days for comments and either repost (with a complete tutorial, or delete this and go to Instructables. |
Posted: Mar 20, 2009 - 04:02 AM |
Thanks for the write up.
To answer your question, I would like to see a well commented, reasonably monolithic code example showing the usage of the pwm hardware.
Such an example could include the initialization of the pwm hardware, selecting prescalers (and the like) based on appropriate criteria (F_CPU being the most obvious), mode selection, output pin, duty cycle, frequency, hooking interrupts at various times in the cycle.. and so on and so forth.
ex; One large code block with many of the commonly used features represented, comments describing what each one does, and where features are mutually exclusive, only one is uncommented. The comments could also include datasheet page numbers to review for additional details.
I've always found it easier to start with something that is working, modify it, pick it apart, and learn from it while referencing a tutorial or the datasheet. The datasheet is horribly lacking a code segment pulling together and example of the usage of the hardware it is describing in the section - unless I'm just missing it. 350 pages, and very little example code.
Oh, and whatever you do, don't waste your time at Instructables. They've really gone down hill lately. So many things are turning into "Membership Benefit!"s. First we lost viewing all steps on one page, now you cannot view the other images posted for a step w/o logging in. Before long, all a person will be able to do (w/o logging in,) will be viewing the abstract of the instructable.
I'd rather not read a paragraph or two, then click on the Next button and wait for another page load just to read the next two paragraphs. Put the whole thing on one page, and remove the clutter from the rest of the page.
-Thanks. |
Posted: Mar 20, 2009 - 09:31 PM |
Thanks for the excellent response, zphere. Hopefully, I'll get a few more opinions on this as well.
The sort of tutorial you're asking for is exactly what I have prepared and am trying to post. The first few parts that make up the posting so far are admittedly wordy, but provide the necessary background to understand the PWM modes. Not only do I have more detailed info on the PWM modes, but I have an example program that shows the modes in action and can be easily plagiarized for your own purposes. ("Show me a good programmer and I'll show you a good plagiarizer!")
I think you're a little harsh with Instructables. Your points are well taken, but here're a few counterpoints.
What's wrong with logging in? After all, we have to login in to Freaks to post, to see the Projects, and even to see the Figures that I included with my first post.
Yes, you have to click to see the next section, but you can always download the pdf version.
Finally, for the poster, Instructables handles uploaded code, figures, and files much better than whatever Forum Software it is that Freaks uses.
So here's what I'm thinking: I will actually post the Tutorial as several separate posts - one section (and no more than 3 figures or files each). I think this will work.
An alternative is to put the code, figures and diagrams in the Projects section. So a reader could download them, then read the Tutorial itself.
Any opinions or suggestions??
Thanks. |
Posted: Mar 21, 2009 - 12:37 PM |
Too complex - the best bet is to put the whole thing into a .PDF and attach it to a post here. (use CutePDF is you need a free PDF "printer") |
Posted: Mar 21, 2009 - 06:00 PM |
Sounds like a good idea, I'll try it. It'll take a few hours to get the file all put together, then I'll post it.
In the mean time, I've noticed an error in the Makefile lines to enable the Clock Output. Don't use the code in my first post - I'll correct it in the new one.
Thanks again for the suggestion. |
Posted: Mar 22, 2009 - 03:42 AM |
Edit any changes into earlier posts, too, since not everyone will read through the entire thread. |
_________________ Chuck Baird
What Would Samperi Do?
http://www.zbaird.com
Posted: Mar 22, 2009 - 04:21 AM |
| Done - Corrections are in the original posting. |
Posted: Mar 24, 2009 - 06:16 PM |
All comments prior to this one were to the original (partial)post. Comments after this should be to the new pdf version and to the code that goes with it.
Hopefully, the pdf approach will be satisfactory! Thanks for your patience. |
Posted: Mar 29, 2009 - 07:55 PM |
| Thank's man now eat your whole enchilada and a few taquitos, thanks a lot |
Posted: Apr 21, 2009 - 08:37 AM |
| Thousand of thanks to u.great job man. |
Posted: May 07, 2009 - 11:12 AM |
Your tutorial along with deans, are the best recipe for PWM!  |
Posted: May 09, 2009 - 07:17 AM |
| Excellent tutorial (though I'm still mulling it over; my own app requires timer 0, so no frequency correct mode, making the examples a little less applicable for me). I did notice a mistake in Fig. 4 (p. 8): OC1A goes low when COUNT equals OCR1A and high when COUNT equals ICR1 (TOP). Text on p. 7 says, "When the COUNT is equal to the value in OCR1A, the output on OC1A will go high. As soon as the count reaches TOP, OC1A will be cleared." Sounds like just the opposite of what's shown. I know the output may easily be inverted, but the text should match the diagram. |
Posted: May 14, 2009 - 05:30 PM |
If you're using just timer 0, then you have just Phase Correct Mode available. Since this mode offers the main advantages of Phase & Frequency Correct Mode, you'll be just fine and the examples I give should be fully applicable. In fact, I couldn't really come up with a good demo of P&F Mode vs. Phase Correct Mode only. P&F only helps if the behavior during a frequency transition is of great importance - usually it isn't. If you use Phase Correct Mode only in the examples I provide, you'll find the behavior is identical.
As far as Fig. 4 vs. the text, you are correct on both points. The text *should indeed* match the figure (sorry about that); and the behavior can be easily inverted. (Maybe that's what I was trying to illustrate and just didn't realize it? }
HTH. |
Posted: May 27, 2009 - 12:37 PM |
Hi all,
seems everybody's using OC1A here... I have also tried to set pwm on OC1B of mega8 but it didn't work.
The (working) code I made for OC1A was:
Code:
void pwm_set_1A(unsigned char pulse_width)
DDRB |= (1<<1); //Port B.1 as o/p (OC1A)
OCR1AL = pulse_width; //Load Pulse width
OCR1AH = 0;
TCCR1A=((1<<COM1A1)&~(1<<COM1A0)|(1<<WGM10)&(~(1<<WGM11))); //8-bit, Non-Inverted PWM
//just a harder way to write TCCR1A = 0x81 :D
TCCR1B = 1<<CS10; //Start PWM
Now, it works. Problem is with getting OC1B to work:
Code:
void pwm_set_1B(unsigned char pulse_width)
DDRB |= (1<<2); //Port B.2 as o/p (OC1B)
OCR1BL = pulse_width; //Load Pulse width
OCR1BH = 0;
TCCR1A = ((1<<COM1B1)&~(1<<COM1B0));//|(~(1<<WGM13)&(1<<WGM12))); //8-bit, Non-Inverted PWM
TCCR1B = ((1<<WGM12)&~(1<<WGM13));
I am using these in:
Code:
for(unsigned char i=0; i<0xff; i++)
{pwm_set_1B(i); //pwm_set_1A(i) works here
_delay_ms(5);
for(unsigned char i=0xff; i>0; i--)
{pwm_set_1B(i);
_delay_ms(5);
when I run it in Proteus, nothing comes on OC1B. Am I setting TCCR1A & TCCR1B the correct way??
Kind suggestions please...
-Regards,
Munish  |
Posted: May 27, 2009 - 12:38 PM |
How do you know Proteus simulates correctly? |
Posted: May 27, 2009 - 12:41 PM |
| Coz it is simulating OC1A correctly! and in hardware also I have connected 2 LEDs to both the OCs. OC1A lights (dims) its respective LED, while OC1B doesnt. |
_________________ -
Munish
Posted: May 29, 2009 - 04:16 AM |
Looks to me like you aren't really doing the same things to make OC1B like OC1A.
- You're making TCCR1A equal to just 1<<COM1B1. The setting of (1<<WGM10)&(~(1<<WGM11) is lost.
- Setting TCCR1B to (1<<WGM12)&(~(1<<WGM13) would select CTC mode. (See the Waveform Generation Mode Bit Description Table.)
- But that doesn't even happen since you then make TCCR1B equal to 1<<CS10 and wipe out the value of the other bits in TCCR1B.
Try this:
Code:
OCR1BH = 0;
TCCR1A = (1<<COM1B1) |(1<<WGM10)); //8-bit, Non-Inverted PWM
If you OR in the command to enable OC1B, you can keep OC1A running as well. |
Posted: Sep 27, 2009 - 11:22 AM |
| Thank you for the great+detail+ easy to understand tutorial!! Really helped me!! =) |
Posted: Sep 27, 2009 - 01:08 PM |
| Dear guyz i m getting a crrupeted zip from the link geven above? wht shld i do now? |
Posted: Sep 27, 2009 - 11:56 PM |
| is anyone one here writing bascom scripts for atmega48? This looks like all greek to me. I would pay someone to compile me a script. |
