Search |
| Author |
Message |
Posted: Dec 23, 2008 - 10:11 AM |
On a whim I ordered a few things from goldmine-elec.com, including a few specific parts for projects I am already working on. Aside from those, I got one Mini Free Surprise Box Gift, three Electronic Surprise Box, and two Super Electronic Surprise Box. The reason behind this is my dreadful lack of miscellaneous parts to play with on a whim.
First of all, I have definitely solved that problem. I will catalog here the contents of the boxes, to better inform other community members considering such purchases. Virtually every component, with a few noted exceptions, is leaded, not SMT, and about 10% of the components have leads bent out of their useful positions (but not broken or unusable). Of the components still on tapes about 75% are well kept while 25% have one leg detached from the tape or bent leads. I kept pretty accurate counts of most things, but the ones above about 50x are estimated.
The mini surprise box is a freebie on any purchase of $25 or more. It came in a cardboard sleeve, about 12 cubic inches of stuff.
6x TOB50K sliding potentiometers
5x 10K single turn potentiometers
2x 1K single turn potentiometers
1x 50K large single turn potentiometer
3x TO220 22N50/185
3x TO220 22N50/185628
33x 564J100 (AC capacitor?)
50x 6mm 4-lead DPST n.o. pushbutton switches
10x 12mm SPDT sliding switches
1x DIP-14 socket
8x 5mm green LEDs diffuse
5x 5mm yellow LEDs
4x 3mm green LEDs
3x 3mm yellow LEDs
2x 3mm red LEDs
5x 5mm red LEDs and green LEDs mounted together
4x misc resistors
7x 125V 4A cylindrical glass fuses
8x 3.5mm stereo phono jack, large housing
40x 3.5mm stereo phono jack, small housing
60x 5/32" ID unthreaded 1/4" aluminum nuts
200x misc small inductors, mostly coreless
50x 2mm x 3mm blue toroids
2x volume knobs with tightening screws
2x holiday noisemakers, single PCB with speaker, battery, pushbutton.
60x 1/8" x 1/2" machine screws
The normal surprise box is $3.25, about 50 cubic inches of stuff.
14x large SPDT switches
1x small SPDT switch
1x large DPTT switch
3x large dual 2M single turn potentiometers (one broken)
1x large 2M log single turn potentiometer
2x 10K single turn potentiometers
9x 3.5mm stereo phono jack, large housing
2x 3.5mm stereo phono jack, small housing
1x 3.5mm stereo phono jack, medium housing
28x 2.5mm phono-like mono plugs
1x optical audio jack
1x wide DIP-24 socket
2x DIP-20 socket
1x DIP-14 socket
1x ADM709 Power Supply Monitor with Reset DIP-8
1x 74F273N DIP-20
1x 74F257N DIP-16
1x MAX232CPE DIP-16
3x 3300uF 16V electrolytic capacitors
3x 33uF 16V electrolytic capacitors
3x 15uF 50V electrolytic capacitors
3x 330uF 6.3V electrolytic capacitors
20x misc 20-2200uF 6.3-100VDC electrolytic capacitors
1x 4uF 220VAC capacitor
1x 75uF 400VAC capacitor
5x 1/8" x 1" piezo buzzers
1x 1/4" x 1 1/2" piezo buzzer
1x 1/4" x 1/4" condenser mic
7x misc crystals 3-64MHz
13x small (1/8" toroids) multi-tap binocular core transformers
25x 5mm green LEDs
4x 5mm yellow LEDs
7x 5mm yellow LEDs diffuse
1x 8mm red LED diffuse
7x misc LEDs 3-5mm
37x misc diodes
5x ~1W 4.7 resistors
1x ~2W 100K resistor
4x 25W 680 resistors
3x 1/4W 830M resistors
2x 1/4W 10 resistors
20x misc .25-5W 10-10M resistors
11x 1/2" threaded plastic standoffs
22x .5-1" metal screws in bags of two
10x misc nuts/washers
1x aluminum 2.5" dia dual .125" pulley
15x misc plastic connector housings
60x misc small coreless inductors
15x misc small toroid cored inductors
100x 2mm x 3mm blue toroids
25x misc TO220
20x misc transistors
10x misc metal connectors
3x small transformers
2x 5mm green LEDs
5x machine screws, washers
4x misc headers/connectors
2x misc diodes
20x misc mystery 2-lead components
I have sorted a couple of other boxes, and have one more to sort. I will post the contents of at least one of the super boxes tomorrow evening, hopefully of all 4 remaining boxes.
Sneak preview: the first super electronic surprise box contains, among other things, a 6" can 24V stepper motor with a separate revolution counter circuit.
The super surprise box is $5.95, about 145 cubic inches of stuff.
1x 6" x 2" 24V SM-024-0065-RX stepper motor w/ revolution counter (worth the price of the box, alone)
1x 1" brushless motor controller/coils
29x 3.5mm stereo phono jack, large housing
38x 3.5mm stereo phono jack, medium housing
47x 3.5mm stereo phono jack, small housing
11x 1W 4.7 resistors on tape
14x 1/4W 6.2 resistors on tape
6x 1/2W 0.7k resistors on tape
3x ~5W 0.75k resistors
11x 1/4W 100k resistors on tape
2x 1/4W 1k resistors on tape
2x 5.6k SIP-9 resistor networks
8x misc resistors
18x 1A 30V schottky rectifier diodes on tape
108x small brown/black glass diodes on tape
63x "HR R 152K 1KV 55" two leads, 3/8" blue disc, capacitor? on tape
8x 330uF 6.3V electrolytic capacitors
5x 100uF 35V electrolytic capacitors
2x 3300uF 16V electrolytic capacitors
5x 220uF 10V electrolytic capacitors
5x 390uF 16V electrolytic capacitors
20x 33uF 16V electrolytic capacitors on tape
9x 100uF 25V electrolytic capacitors on tape
5x misc 10-800uF 16-315V electrolytic capacitors
8x misc capacitors
2x ST NE555N DIP-8
3x 74F827N DIP-24
1x 74F240 DIP-20
1x MC74F245N DIP-20
30x misc headers/connectors
6x misc yellow/green LEDs
20x .5-1" metal screws in bags of two
6x misc screws
1x large dual 200K/2K single turn potentiometer
9x 20K single turn potentiometers
8x misc automotive indicator lamps
5x optical audio jack
2x 1/2" parabolic reflectors and plastic lenses
16x rubber stylus grips
60x misc plastic connector housings
2x heavy duty 3-position screw terminals
3x misc switches
40x misc small coreless inductors
20x small toroid cored inductors
28x misc TO220
11x 125V 4A cylindrical glass fuses
13x misc metal connectors
10x misc transistors
40x misc diodes
26x misc mystery 2-lead components
1x BNC coax connector
1x lost keychain finder
2x gps antenna blob
2x random partial PCB with components
2x 6" wacom stylus with one button, broken tip
Another super surprise box...
1x food-grade water pump, no specs
1x small printer assembly (rollers, gears, sprockets, springs)
1x 4xAA holder, 9V connector
5x ~1000:1 gearboxes, gear input, shaft output
10x .5-1" metal screws in bags of two
2x AC power plugs
2x small transformers
2x misc small pcb w/ components
5x rubber stylus grips
19x misc automotive indicator lamps
1x 74F240 DIP-20
1x A7601 DIP-8 (clipped legs)
16x 220uF 10V electrolytic capacitors
6x 330uF 6.3V electrolytic capacitors
5x 390uF 6.3V electrolytic capacitors
9x 100uF 35V electrolytic capacitors
5x 100uF 63V electrolytic capacitors
3x 200uF 16V electrolytic capacitors
3x 330uF 10V electrolytic capacitors
5x 3.3uF 100V electrolytic capacitors on tape
23x 68uF 16V electrolytic capacitors on tape
26x 15uF 50V electrolytic capacitors on tape
5x 100uF 25V electrolytic capacitors on tape
5x misc electrolytic capacitors
13x 20k single turn potentiometers
1x 47k single turn potentiometer
1x large 20k/2k dual single rotation potentiometer
6x misc headers/connectors
7x 5mm green LEDs
1x 3mm green LED
1x red 7 segment LED, 5mm x 15mm
13x "HR R 152K 1KV 55" two leads, 3/8" blue disc, capacitor? on tape
30x 3-lead brown "L4.5H" on tape
23x "1N 47 40a 736" metal diodes? on tape
1x 6" wacom stylus with one button, broken tip
22x misc headers/connectors
28x 3.5mm stereo phono jack, small housing
24x 3.5mm stereo phono jack, medium housing
25x 3.5mm stereo phono jack, large housing
1x gps antenna blob
1x plastic magnifying lens
50x misc plastic connector housings
350x misc small coreless inductors
12x misc TO220
30x misc diodes
4x 125V 4A cylindrical glass fuses
6x misc .25-1" ferrite toroids
12x misc transistors
25x small toroid cored inductors
1x photodiode
20x misc metal connectors
3x misc screws
4x misc switches
1x CBT3253C SOIC-16
1x ATMEL324 24CO1A SOIC-8
1x 10W 0.75k resistor
2x 5W 51 resistors
30x misc components
12x black rubber covered 1/2" 2-lead blobs
50x silver "433J IH0D" 2-leads
Another regular surprise box:
1x 2" cube heat sink
46x 2.5mm phono-like mono plugs
40x .5-1" metal screws in bags of two
5x 1W 4.7 resistors on tape
4x 1/2W 0.7k resistors on tape
3x 5W 0.68k resistors
3x 8.2k SIP-5 resistor networks
20x misc resistors
8x 3-lead brown "L4.5H" on tape
21x misc TO220
13x large SPDT switches
1x large DPDT switch
2x large DPDT rocker switches
1x 25k single turn potentiometer
3x 10k single turn potentiometers
5x 10M single turn potentiometers
50x misc diodes
10x 3300uF 16V electrolytic capacitors
15x misc electrolytic capacitors
1x 3.5mm stereo phono jack, small housing
21x 3.5mm stereo phono jack, large housing
3x 2.5mm phono-like mono plugs
5x small transformers
125x misc small coreless inductors
10x small (1/8" toroids) multi-tap binocular core transformers
7x small toroid cored inductors
14x misc headers/connectors
1x 1" ferrite toroid
9x misc 3.6-32MHz crystals
30x misc components
4x 1/4" condenser microphones
4x IR(?) photodiodes(?)
8x misc metal connectors
6x metal crimp pins
12x misc small metal hardware
5x silver "433J IH0D" 2-leads
24x misc plastic connector housings
3x DIP-20 socket
1x DIP-24 socket
1x 74F260N DIP-14
1x ST NE555N DIP-8
1x LM324D SOIC-14
1x "2327" "tall" DIP-6
2x 5mm red+green LEDs
56x misc 5mm LEDs
One normal surprise box to go!
The last box has a lot more diodes and crystals and LEDs, less headers and transistors, more loose components, less on ribbons. I accidentally mixed it in with the previously counted parts, so no full list for this one. |
Posted: Dec 23, 2008 - 11:13 AM |
I don't want to rain on the parade, but you'll find that there is always, really always, in any DIY project at least one part you don't have in stock. You can buy as many surprise boxes or sets as you want, one part will always be missing when you do a project.
On a positive note, it seems your surprise boxes contain useful parts. I have seen other "sets" that where practically just a way for the vendor of getting rid of electronic waste and being paid for the waste. |
_________________ Windows is like the faint smell of piss in a subway... -- Charlie Brooker, The Guardian, Monday 28 September 2009
Posted: Dec 23, 2008 - 02:26 PM |
On the first day of Christmas...
Lord, how this stuff accumulates. In a few years you'll be paying someone to get rid of stuff like this.
Tip: put the stuff into small plastic pouches and label them. Sifting through a hap of junk looking for something in particular is not my idea of fun. |
_________________ If you think education is expensive, try ignorance.
Posted: Dec 23, 2008 - 06:28 PM |
ArnoldB, the issue of worthless surprise boxes is why I am doing this. I want other people to be well informed when making purchase decisions. I think that these boxes are well worth the cost. In each box I have opened just a couple of items, at quantity, have more than made up the value of the box.
emuler, I am rather precise when it comes to sorting and labeling, thanks for the tip. I know that there is a good chance I will never use the majority of this stuff, but the choices it gives me are well worth the trouble of sorting the ones I don't need to find the ones that I do.
PS: unopened boxes notwithstanding, I will never have to shop for 3.5mm phono stereo jacks again  |
Posted: Dec 23, 2008 - 06:39 PM |
The next time you play Electronic Goldmine, check out "EVQ" Panasonic EVQ-WTEF2515B Mechanical Rotary Encoder
Endless quadrature "encoder" with shaft like would be on a 'scope knob. Obsolete model, but DigiKey lists similar for about $6/each; about $1+ as "surplus".
Lee |
Posted: Dec 23, 2008 - 09:43 PM |
eBay is this way -> http://www.ebay.com  |
Posted: Dec 24, 2008 - 12:37 AM |
| They are in great condition, I could almost certainly sell them on ebay. At even 5 cents apiece (10% of qty100 price on mouser) the 300+ of them that I already have (without having tallied half the boxes) would recoup what I spent on the boxes. |
Posted: Dec 24, 2008 - 06:40 PM |
Posted: Dec 24, 2008 - 09:59 PM |
Interesting, that is a lot of typing...?
Do you have an economic interest in sharing the contents? I have so much to do in a day that I certainly could not afford to waste my time detailing the contents of a surprise box.
No offense...just seems like lots of work for no reason. I have a local surplus electronics supplier that sells all of those items. I have accumulated so much stuff that I will never use... |
_________________ You may only be one person in the world but, you may be the world to one person!
"Life! Life, do you hear me? Give my creation LIFE!" Gene Wilder
SKYPE Name: JonRobrt
Posted: Dec 25, 2008 - 03:07 AM |
Altruistic interest. As mentioned above, some companies' similar boxes are less helpfully varied, some could even be called rip-offs. Now when someone is interested in buying this sort of box and searches these forums they will find a few examples from this company. When I order a similar box from another site (which I will be doing from at least two other sites in the near future) I will make a single post for each of them as well.
I know that I, personally, would be grateful if this information was already published by someone else, and thus I publish it for others to reference. I have no economic interest or investment in your purchasing decisions.
PS: Making the list also provided a small personal incentive to bother trying to identify more of the parts I did not recognize, which otherwise would have ended up in my mystery part pile. |
Posted: Dec 27, 2008 - 05:12 AM |
Ah junk boxes...yes I had great fun...I remember many years ago (25?) buying a 10 lb surprise box of resistors from Olsen Electronics (still around?) Well, I spent many hours sorting them into 10 bins by color code.
After finishing, I wished I had sorted by the multiplier band rather than the 1st band! I still have 'em this way & still occasionally dig around for one...probably still have 9.5 lb left....some day I'm going to hook them all in series.
Around the same era, we came across a whole LARGE dumpster full of BRAND NEW, in the boxes green bar printer paper (?!!?)..Thinking someone had lost their mind, we of course loaded up our car with all we could haul & went into the "paper" selling business door to door at various companies...After spending our first money, we got irate calls, that the paper would not fit in any printers since the two sprocket hole sets were not punched in synch from side to side. So much for our empire.
Hoyt |
_________________ When in the dark remember-the future looks brighter than ever.
Posted: Dec 28, 2008 - 12:59 AM |
I have parts that I bought as part of those "Grag-Bags " way back in the mid-1970's, that I've still not used, and never will. For me, they are a waste of money.
Even as well stocked as my parts bins are, I'm still needing some part or another to complete a project - that's just the way it seems to work out. |
_________________ Carl W. Livingston, KC5OTL
microcarl@roadrunner.com
It's a fundamental law of nature... All things gravitate toward total chaos!!!
The original Dragon Slayer !
Long live the AVR!!!
Posted: Jan 12, 2009 - 09:19 PM |
| Worst case, I throw 90% of the parts away (the likely fate of the remaining mystery parts), and the remaining 10% were still well worth my investment. The headphone jacks, pushbuttons, and SPST/SPDT/DPDT switches more than make up the value of the boxes, and I expect to use all of those eventually. |
Posted: Jan 13, 2009 - 03:17 AM |
I suffer from the disease called "Can't throw usable stuff away". Like the previous toaster, CD player, several old PCs.
Need to find a 12 step program. |
Posted: Dec 06, 2009 - 07:35 PM |
