pmitruka
PostPosted: Dec 05, 2008 - 11:51 AM
Newbie
I am trying to enable the watchdog timer in Atmega1280. The code is as follows:
wdt_reset();
WDTCSR = _BV(WDIF) | _BV(WDIE) |_BV(WDCE) | _BV(WDE) | WDTO_1S;
WDTCSR = _BV(WDIF) | _BV(WDIE) | WDTO_1S;
MCUSR = 0;
sei();
ISR(WDT_vect )
// Do something
but the interrupt routime is not getting started.. any idea.. Please help Sad
curtvm
PostPosted: Dec 05, 2008 - 12:26 PM
Keep resetting the watchdog in the while loop won't help.
Code:
int main(void){
   MCUSR = 0;
   WDTCSR = (1<<WDCE)|(1<<WDE);
   WDTCSR = (1<<WDIF)|(1<<WDIE)|WDTO_1S;
   sei();
   while(1);
ISR(WDT_vect ){
   // Do something
The wdce/wde part is only needed to change the prescale in this case.
my (mostly untested) watchdog header for irq modes-
http://www.mtcnet.net/~henryvm/wdt/
pmitruka
PostPosted: Dec 05, 2008 - 12:28 PM
Newbie
Can u plz suggest me the code... I am new to AVR programming...
I need a watchdog which will wake up the processor every one minute... using atmega1280...
Thanks in advance Smile
pmitruka
PostPosted: Dec 05, 2008 - 12:30 PM
Newbie
Thanks in advance
pmitruka
PostPosted: Dec 08, 2008 - 09:41 AM
Newbie
Hi All,
Following is my code snippet.. need to have a watchdog which will wake up the controller from sleep every one minute.. Right now trying for 8 sec.
MCUCR &= ~_BV(PUD);
WDT_Initialization_as_Wakeup_Source();
// Some src here
wdt_reset();
WDTCSR |= (1<<WDIE);
sleep_enable();
for(;Wink
fun_xyz1(); // Some src
ISR(WDT_vect)
fun_xyz2();// Some src
void WDT_Initialization_as_Wakeup_Source( void )
/* Setup Watchdog */
// Use Timed Sequence for disabling Watchdog System Reset Mode if it has been enabled unintentionally.
MCUSR &= ~(1<<WDRF); // Clear WDRF if it has been unintentionally set.
WDTCSR = (1<<WDCE )|(1<<WDE ); // Enable configuration change.
WDTCSR = (1<<WDIF)|(1<<WDIE)| // Enable Watchdog Interrupt Mode.
(1<<WDCE )|(0<<WDE )| // Disable Watchdog System Reset Mode if unintentionally enabled.
(1<<WDP3 )|(0<<WDP2 )|(0<<WDP1)|(1<<WDP0); // Set Watchdog Timeout period to 4.0 sec.
/* Enable Power Down Sleep Mode */
MCUCR |= (1<<SM1) | (1<<SE);
but comehow the interrupt routine is not getting called at all... Pelase help me... bit urgent..
-PM
sadavis80
PostPosted: Dec 08, 2008 - 02:27 PM
Newbie
As pointed out above, leaving
Code:
wdt_reset();
in the while routine will keep the WDT from getting called. Comment it out and the WDT should trigger. I think - I don't use GCC).
BTW - I'm not an expert, but I don't see where you are 'putting the AVR to sleep'. Does sleep_enable() do that? - if so it would seem that your while loop operates rather strangely .. at least to me. The function call within the While would never get called, at least until after the WDT triggered. Doesn't a wdt reset NOT execute a rti at the end, and instead return to program main start??
And SOME compilers automatically sprinkle 'wdt_reset' calls throughout the code unless you specifically tell it not to.
Steve
theusch
PostPosted: Dec 08, 2008 - 02:57 PM
10k+ Postman
OK, I'll bite--could you list these SOME compilers that "put words into your mouth"? [that would pretty much defeat the purpose of using the watchdog]
Lee
curtvm
PostPosted: Dec 08, 2008 - 04:51 PM
Here's one example, I guess-
http://www.avrfreaks.net/index.php?name ... 990#514990
theusch
PostPosted: Dec 08, 2008 - 05:38 PM
10k+ Postman
I'm well aware of that well-defined situation--note that it was my post. I'm looking for "sprinkle" examples.
Lee
curtvm
PostPosted: Dec 08, 2008 - 06:30 PM
That's why it was so 'juicy' (I thought maybe you were losing your memory). I guess delays sprinkled through the code, would be well defined sprinkles, not automatic compiler sprinkles.
I need to find me some Christmas cookies. For some reason.
theusch
PostPosted: Dec 08, 2008 - 06:35 PM
10k+ Postman
LOL
Using a library routine, that >>you<< choose to use, that has documented behaviour of doing a WDR is enitely different than "compilers automatically sprinkle 'wdt_reset' calls throughout the code unless you specifically tell it not to". I'm asking for an example of that.
