| Author |
Message |
Posted: Nov 18, 2008 - 02:39 AM |
Hello everybody;
I need help with the following subject:
I have installed the new 4.15 AVR Studio but if I try to launch it I get a message that the WDAPI811.DLL can not be found.
Can anybody help me out?
TKS |
Posted: Nov 18, 2008 - 05:29 AM |
Posted: Nov 18, 2008 - 09:52 PM |
Hi Pradheep;
The OS is XP SP3. I have two XP machines at home and I can not find the .dll file (under c:/windows/system32/wdapi811.dll) on both.But it exists once I have find it on my pc at office ( XP SP3). I have found that it is a dll from JUNGO ( http://www.jungo.com)and according to the answers from microsoft I think that it is not part of windows original package. I do not know what application or installation sw had insttalled or removed it from my computer. I will try to re-install the previous version 4.14 to check what is going to happen.
Tks |
_________________ Thanks to
AVR-GCC
and
SourceForge People
Posted: Nov 18, 2008 - 10:25 PM |
I'm back
I intalled again the version 4.14 and the the 4.15 as an update ( at first time I have removed the 4.14 version before to install the new 4.15). The Jungo's dll is installed by the software to control USB interface.So, do not remove the previus version befor install the new one.
So, I consider the issue solved.
Regards |
AVR-GCC
and
SourceForge People
Posted: Nov 20, 2008 - 08:13 PM |
got the same (no wdapi811.dll). I installed 4.15 on fresh XP SP2 (AVRStudio was one of the first things I installed). I unchecked installation of USB driver.
Now using 4.14 but try install 4.15 on current install. |
Posted: Dec 14, 2008 - 07:32 PM |
I have the same problem with 4.15 and I'm using Vista Ultimate x64.
Will go back to 4.14 until they fix this annoying error! |
Posted: Dec 17, 2008 - 01:08 AM |
| I've also just run into this bug! Bah! I'll have to downgrade to 4.14 and try again. All I wanted to do was upgrade from 4.11 to add support for the ATmega324, and now I can't program at all. |
Posted: Dec 17, 2008 - 01:39 AM |
I just installed 4.15 on WIN 2000. For the first install I chose not to install the USB option. When running the app, I got the DLL error.
I reinstalled the app, without uninstalling anything, and selected to install the USB option. This time, it worked just fine. Problem resolved.
Hope this helps. SteveRob |
Posted: Dec 17, 2008 - 03:03 AM |
| Thanks, SteveRob! I've just discovered exactly the same workaround! I uninstalled 4.15, installed 4.12 (I happened to have that version available), selected to install the USB support (even though I have no USB programmer), then upgraded to 4.15. During the upgrade, an extra step showed up, installing USB drivers. After that version 4.15 works fine. Hope this info will help others/help debug the problem. |
Posted: Dec 17, 2008 - 07:08 AM |
But do we really have to install USB drivers? Isn't that to force something you don't want?
Jungo crashed my old computer so I want to avoid that driver and since I'm not using it it's nothing I want! |
Posted: Dec 17, 2008 - 09:01 AM |
I've posted a bug report. Hopefully it will be fixed in the near future. |
Posted: Jan 18, 2009 - 10:28 AM |
Have had the same error.
I've executed the install program , then i choosed "Modify" and on the next screen i choosed "Install usb drivers,etc,etc..".
After that, AVR Studio start without problems. |
Posted: Jan 18, 2009 - 01:10 PM |
Everyone doesn't want to polute the system with unwanted drivers.
/Henke |
Posted: Feb 02, 2009 - 07:51 PM |
I am running WIN XP Pro SP3. After upgrading to 4.15 (from 4.14?) I had the same issue, and "Modify" followed by "Install USB ...." fixed my "starting" issue as well. Thanks for the tip!
GMK |
