| Author |
Message |
Posted: Jul 12, 2008 - 09:50 PM |
Posted: Jul 12, 2008 - 10:27 PM |
Somewhat related are Adam Dunkels ProtoThreads at http://www.sics.se/~adam/pt/ . From the website:
Protothreads are extremely lightweight stackless threads designed for severely memory constrained systems, such as small embedded systems or wireless sensor network nodes. Protothreads provide linear code execution for event-driven systems implemented in C.
Posted: Jul 14, 2008 - 10:20 AM |
| Femto OS is another RTOS for AVR architecture. |
Posted: Nov 08, 2008 - 11:20 PM |
| Not sure if I can post a question here, but why would someone want an operating system for an AVR, a microcontroller? Could someone here who uses such please explain, as I'd never considered such a thing but would like to understand the motivation. |
Posted: Nov 08, 2008 - 11:34 PM |
Here we go again.. Just do a search here at AVRfreaks on RTOS and similar and you will find more pro's and con's than you actually care about.
Oh, well... I am not necessarily ruling in OSes in all cases for AVRs (I'm not that stupid). But I can easily think of situations where it would help.
What if you want to run several parallell processes where some need to be higher prioritized than others? What if you want to want TCP/IP connectivity? What if you want to access an IDE hard disk with a FAT file-system? Sure you can say that you can write code for those without having an operating system, but then we'd just be playing with words.
Once upon a time I used machines with 64KB of RAM (for both program and data, Von Neumann architechture) that ran operating systems that where more complicated than several of the "small footprint" RTOSes for AVRs that are out there. The biggest AVR has 256 KB of (program) FLASH and 8KB of (data) RAM... |
Posted: Nov 08, 2008 - 11:58 PM |
I often think there's a limit (somewhere between 32K and 64K but not exactly sure where) at which program complexity probably becomes so great that there's a call for multi-tasking but it could be as simple as non-premeptive, perhaps even just protothreads.
Cliff |
Posted: Feb 15, 2009 - 07:30 PM |
Posted: Apr 24, 2009 - 10:16 AM |
| No, it's not correct. scmRTOS is preempteve OS. |
Posted: May 06, 2009 - 04:25 PM |
Posted: May 06, 2009 - 08:32 PM |
| There is actually a port for that in the projects section! But you are correct it is not on the list. |
Posted: May 08, 2009 - 07:40 AM |
| uCOS-II is another for AVR Architecture |
Posted: May 08, 2009 - 10:32 AM |
| Folks, can you give URLs when you mention a missing OS that isn't in the list above then I'll edit the link into the first post. Ta. |
Posted: May 08, 2009 - 09:00 PM |
Posted: May 09, 2009 - 02:46 PM |
| Please correct the definition of the scmRTOS. It is preemptive, not cooperative. |
Posted: Oct 25, 2009 - 02:20 AM |
Thank you for the list - are you able to put the licence after each one - the last two are ideal:
scmRTOS: a C++ cooperative OS with Mit license
iRTOS: a C preemptive OS with LGPL license
Posted: Nov 09, 2009 - 06:18 AM |
| thanks for that list. But can anyone tell me, which one RTOS for AVR that use BASIC programing language? please help me |
Posted: Nov 09, 2009 - 08:36 AM |
Posted: Nov 10, 2009 - 07:46 PM |
clawson wrote:
Thanks for your reply Clawson but i already know that script, its not a real RTOS, its just split the procedure into stacks and make priority for task in order every millisecond.
That i want to know is how to make more than one procedures to work simultaneously.
But really i appreciated for your help, thanks,
Do you have any ideas,links,etc? |
Posted: Nov 11, 2009 - 09:43 AM |
Yes switch to C then pick one of the 20+ listed above  |
Posted: Nov 26, 2009 - 07:52 AM |
| This is supposed to be tutorial, but all I can see is a list of links. There should be some tutorial in this forum, which explains what RTOS is, what is thread, preempting, etc. |
