No answer again
Anyway I send my little program which finds device addresses connected to EVK1100 via I2C interface. May be it helps beginners like me in the future...
Regards!
Code:
#include <avr32/io.h>
#include "board.h"
#include "gpio.h"
#include "pm.h"
#include "intc.h"
#include "twi.h"
#include <stdio.h>
#include "dip204.h"
#include "spi.h"
#include "delay.h"
#define TWI_SPEED 100000 // Speed of TWI
//SPI CONFIGURATIONS FOR LCD DISPLAY
static const gpio_map_t DIP204_SPI_GPIO_MAP =
{DIP204_SPI_SCK_PIN, DIP204_SPI_SCK_FUNCTION }, // SPI Clock.
{DIP204_SPI_MISO_PIN, DIP204_SPI_MISO_FUNCTION}, // MISO.
{DIP204_SPI_MOSI_PIN, DIP204_SPI_MOSI_FUNCTION}, // MOSI.
{DIP204_SPI_NPCS_PIN, DIP204_SPI_NPCS_FUNCTION} // Chip Select NPCS.
// Switch the CPU main clock to oscillator 0
pm_switch_to_osc0(&AVR32_PM, FOSC0, OSC0_STARTUP);
// add the spi options driver structure for the LCD DIP204
spi_options_t spiOptions =
.reg = DIP204_SPI_NPCS,
.baudrate = 1000000,
.bits = 8,
.spck_delay = 0,
.trans_delay = 0,
.stay_act = 1,
.spi_mode = 0,
.modfdis = 1
// Assign I/Os to SPI
gpio_enable_module(DIP204_SPI_GPIO_MAP,
sizeof(DIP204_SPI_GPIO_MAP) / sizeof(DIP204_SPI_GPIO_MAP[0]));
// Initialize as master
spi_initMaster(DIP204_SPI, &spiOptions);
// Set selection mode: variable_ps, pcs_decode, delay
spi_selectionMode(DIP204_SPI, 0, 0, 0);
// Enable SPI
spi_enable(DIP204_SPI);
// setup chip registers
spi_setupChipReg(DIP204_SPI, &spiOptions, FOSC0);
// initialize delay driver
delay_init( FOSC0 );
// initialize LCD
dip204_init(backlight_PWM, TRUE);
dip204_hide_cursor();
// END OF THE SPI CONFIGURATIONS
static const gpio_map_t TWI_GPIO_MAP =
{AVR32_TWI_SDA_0_0_PIN, AVR32_TWI_SDA_0_0_FUNCTION},
{AVR32_TWI_SCL_0_0_PIN, AVR32_TWI_SCL_0_0_FUNCTION}
twi_options_t opt;
int status,i;
// TWI gpio pins configuration
gpio_enable_module(TWI_GPIO_MAP, sizeof(TWI_GPIO_MAP) / sizeof(TWI_GPIO_MAP[0]));
int SENSOR_ADDRESS=0x00,k=0x01,j=0;
int all_addresses[127];
int n;
for (n=0;n<128;n++)
all_addresses[n]=0;
// options settings
opt.pba_hz = FOSC0;
opt.speed = TWI_SPEED;
//search loop
for (i=0;i<256;i++){
SENSOR_ADDRESS=SENSOR_ADDRESS+k;
// options settings
opt.chip = SENSOR_ADDRESS;
char c[8];
sprintf(c, "%d",SENSOR_ADDRESS);
dip204_set_cursor_position(1,4);
dip204_write_string(c);
// initialize TWI driver with options
status = twi_master_init(&AVR32_TWI, &opt); //MASTER INIT
if (status == TWI_SUCCESS)
// display test result to user
dip204_set_cursor_position(1,1);
dip204_write_string("Init:PASSED");
dip204_set_cursor_position(1,2);
char c[10];
all_addresses[j]=SENSOR_ADDRESS;
j++;
dip204_write_string("Init:FAILED");
} //for
if(j>0){
dip204_clear_display();
int m;
dip204_set_cursor_position(1,3);
for(m=0; m<j; m++){
char d[10];
sprintf(d, "%d",all_addresses[m]);
dip204_write_string(d);
dip204_write_string(" ");
}//for
}//if
while(1);
} //main
