| Author |
Message |
Posted: May 23, 2008 - 11:39 AM |
Hello, I'm new with AVR's and I'm learning C programing for AVR. I just finished my first project which is is a led chaser with my own pattern, so i can say i learned a bit how avr's work. Now i would like to experiment with PWM control over RGB LED's. I got myself an RGB led with 4 pins, and an AVR butterfly. I did a bit of research on the web and all of the projects for AVR i found were written in ASM, so my questions are:
1: Can a code written in ASM be converted to C ?
2: Can you give me a link to a project about pwm control on RGB LED written in C ?
thank you, Florin |
Posted: May 23, 2008 - 12:03 PM |
1. Yes, but in ASM tricks are possibly that have no direct equivalent in C. Timing critical stuff might be difficult it every single instruction counts; you never really know what the compiler generates.
2. No, I don't know any. |
_________________ Free e-books
Modern Mechanix: Yesterday's Tommorow Today
Posted: May 23, 2008 - 01:20 PM |
Can I suggest that you read through some of the Tutorials, maybe the 'Newbie's guide to AVR Timers' and getting just a single LED under PWM control before moving to 3-channels (e.g. Red, Green and Blue).
When you run out of PWM timers (which you will do at some point) for controlling your multiple LEDs, then you're going to have to consider controlling them more directly.
I use the following method which isn't actually 'PWM', but it works very well for LEDs...
Take an 8-bit byte that holds the required intensity of the LED and turn on/off the LED in a timed pattern according to the binary value of that intensity.
E.g.
For an intensity value of 187 (binary 10111011)...
switch the LED with the following pattern:
ON for 128 ticks
OFF for 64 ticks
ON for 32 ticks
ON for 16 ticks
ON for 8 ticks
OFF for 4 ticks
ON for 2 ticks
ON for 1 tick
Whilst this might seem a little complex for a single-LED (certainly more so than just setting up a PWM output), it can scale very well to multiple LEDs.
I simply pre-calculate the pattern needed on each port/pin for each of the 8 time-slices. All the timer interrupt then needs to do is set the port-value and set the next interrupt delay. This means that the interrupt is quick and simple, hence the 'tick' timebase can be nice and short.
It can even be used to charlieplex/multiplex LEDs if neccesary; I've had 2 RGB LEDs hanging off a tiny13.
(Hopefully someone might move this to a more appropriate forum!) |
Posted: May 23, 2008 - 03:11 PM |
| That looks like an interesting variation of regular old 'software pwm' where you turn every thing off, set the loop counter to 0, then every loop check if the counter is up to the R value, turn on the R, counter = G value, turn on G, etc. If you count up to 64 (6 bits of adjustment range) 70 times a sec, the program should loop ~4000 times a sec |
_________________ Imagecraft compiler user
Posted: May 23, 2008 - 04:05 PM |
thx for your answers, and I'm waiting for more advices from you if possible
sorry, i thought this category is right for my thread |
Posted: May 23, 2008 - 04:11 PM |
I've just done a software PWM for an RGB LED for a tiny15. I does not have memory, only registers and a hardware stack, so C is not practical .
However, I set up a timer to fire with 25kHz. With an 8-Bit counter this gives a 100Hz PWM-interval. It decrements an 8-bit counter for each LED color and turns the LED off if the counter is zero. Every 256 interrupts it reloads the counters from the brightness setting and turns the LED's on.
The main routine is used to change the brightness settings to get interesting light changes.
Markus |
_________________ Markus
Posted: May 23, 2008 - 04:13 PM |
Markus is your code written in C ? because i could use other AVR's
Florin |
Posted: May 23, 2008 - 05:11 PM |
I don't think so as he hinted with this
C is not practical [for an AVR that has no RAM]
I am not sure all compilers have difficulties with RAM-less AVRs, so don't take this as a statement from me that I agree with MArkus, but as a hint to the fact that he actually didn't use C for this.
Anyhow, PWMing LEDs does not require high PWM periods (frequencies) as your brain will integrate the blinking. 100 Hz might well be enough. And then you'd have little problem with exact timings, so generally speaking thois would be more than doable with C.
Why not start out with a single (eg one-colour) LED and master the PWM technique there? Then move on to three colours. After all, a RGB LED is only three LEDs of different colours in a monolithic housing... |
Posted: May 23, 2008 - 05:14 PM |
| ok, I'll take the advice and start with single LED, but still i need a C example project. |
Posted: May 23, 2008 - 05:32 PM |
| State which AVR, what xtal speed, and which c compiler, maybe some kind soul will taior one of their existing projects for your specific example |
Posted: May 23, 2008 - 05:45 PM |
You can do the PWM either by using the PWM modes of timers (so read the timer tutorials in the tutorial forum) or you can "wiggle" a pin in PWM mode yourself but then you still need some basic timing tick (so read the timer tutorials in the tutorial forum).
For the latter approach:
You need to produce a PWM signal with a period of, say, 100 Hz (or more). Let's also assume that you want a PWM resolution of 100.
This means that you need to get some basic timer tick working at 100x100 Hz = 10 KHz. Use a timer for that. (Read the tutorials...).
Now every time the timer generates a tick you set a flag in the ISR.
Main loop in the program looks at the flag and holds a count of how many it has seen. You code so that this counter wraps to 0 at 100. Every time it wraps it sets the pin you are using for your PWM signal high. You also have a duty-cycle value you want to generate, and every time the count variable passes this value you set the PWM pin low.
Sketchy:
Code:
volatile int timerTick;
ISR(...) {
// This ISR will fire with a frequency of 10KHz
// (value not critical, could be a higher frequency)
timerTick = 1;
int main()
int tickCount;
int dutyCycle = 42;
// Set up the timer here (as you have learned from the timer tutorials) to generate interrupts with 10 KHz or so
while (1) {
if (timerTick == 1) {
tickCount++;
timerTick = 0;
if (tickCount >= 100) {
// Wrap and set the pin high
tickCount = 0;
PORTx |= 1<<PWM_PIN;
else if (tickCount == dutyCycle) {
// Set the pin low
PORTx &= ~(1<<PWM_PIN);
When this works you can move on to create code that generalizes this for n pins with a shared PWM frequency, but woith individual duty cycles. |
Posted: May 23, 2008 - 05:52 PM |
I don't want to hijack the thread, but I will ask, what effect can you do with PWM for an LED that would be visible to a human and can't be done in C? I agree that if you push a particular AVR to its maximum that you can do things with asm that you cant do with C, but since we can't perceive lights flickering at greater than about 60 times per second, I can't imagine any visible effect that you couldn't do in C and have the AVR twiddling its thumbs most of the time.
Smiley |
_________________ FREE TUTORIAL: 'Quick Start Guide for Using the WinAVR C Compiler with ATMEL's AVR Butterfly' AVAILABLE AT: http://www.smileymicros.com
Posted: May 23, 2008 - 06:14 PM |
Posted: May 23, 2008 - 06:15 PM |
Smiley, do you remember who posted the holiday light project for Christmas 2006 IIRC? That was a fully-worked example for RGB driving, and in addition made a string of lights. IIRC it was in Off-Topic Forum.
That is always the interesting challenge. IF the algorithm makes great use of Carry or Rotate (C has no concept of those), then I'll concede. Similarly, special arithmetic widths such as 24 bits--doesn't jesper's miniDDS use that? But in general one can almost always coerce C to get the job done, especially in a small contained app like this.
If there is a great advantage to using carry (say), then one can just drop into inline ASM for the critical sequence.
Lee |
Posted: May 23, 2008 - 06:31 PM |
Posted: May 23, 2008 - 07:06 PM |
| not sure if miamicanes ever posted his code. but gmprops code is on that other thread thread (an early version of it) That code is not for the AVR's PWM though, it's for working with TLC5940 external LED pwm chips. |
Posted: May 23, 2008 - 08:08 PM |
thx for all your help, I'll study a bit more and I'll come back if i have questions.
Florin |
Posted: May 23, 2008 - 08:49 PM |
| if the part that is stumping you is the timer interrupt, this program is simple enough that the RG and B will get bright and dim just by running in a tight loop. You dont care if it runs at 70 times a sec or 700 or 7000 as long as it works. |
Posted: May 24, 2008 - 12:48 AM |
No, my code is in assembler. In fact, for the Software-PWM part, assembler does very nicely. But for the part where I'm trying to find nice algorithms to change the colors around C would be much better.
While some C compiler do work for the tiny15, gcc/winavr does not and I thought a tour with assembler only sharpens my mind .
I you want I'll post the source.
Markus |
Posted: May 24, 2008 - 08:21 AM |
This trick doesn't work quite as elegantly for a 100-count-resolution PWM, but it's pretty cute for an even-power-of-two resolution like 256:
Every sampling interval, you add the "duty cycle" setting to an accumulating total. Use the carry from this addition as your PWM signal. |
