pomprocker
PostPosted: Apr 13, 2008 - 08:29 PM
Rookie
I am getting this:
>fboot.exe -b57600 -c3 -probot.hex -vrobot.hex
COM 3 at 57600 Baud: Connected
Bootloader V1.7
Target: 1E9307 ATmega8
Buffer: 960 Byte
Size available: 7680 Byte
File robot.hex open failed !
Program-Error
Any one know whats going on? I've tried multiple hex files too.
danni
PostPosted: Apr 13, 2008 - 09:43 PM
This means, there exist no "robot.hex" inside the current directory.
Peter
pomprocker
PostPosted: Apr 13, 2008 - 10:40 PM
Rookie
I know what it means, but the file is in the same directory as the executable fboot.exe
Papabravo
PostPosted: Apr 13, 2008 - 11:34 PM
How does anybody know what directory the file is supposed to be in? Is it specified, or has somebody just assumed they know the answer?
We never have time to do it right,
but we always have time to do it over
pomprocker
PostPosted: Apr 13, 2008 - 11:45 PM
Rookie
I have not seen it specified any where, I just assumed the same directory as the executable.
danni
PostPosted: Apr 13, 2008 - 11:50 PM
The hex file must be in the current directory, where you start fboot.exe.
Maybe since fboot.exe was a DOS application, it can be a problem, if the current directory path was very long (above 80 characters from the root).
E.g. make a directory "C:\TMP", place the hex file into it and then start fboot.exe.
Peter
pomprocker
PostPosted: Apr 14, 2008 - 12:54 AM
Rookie
Can you specify a directory path and filename after the arguments -p and -v ? ie.. -pc:\tmp\robot.hex
pomprocker
PostPosted: Apr 14, 2008 - 01:12 AM
Rookie
ok I moved the directory closer to root and still not working...same problem.
pomprocker
PostPosted: Apr 14, 2008 - 03:24 AM
Rookie
Whats the Init string argument for?
pomprocker
PostPosted: Apr 14, 2008 - 03:49 AM
Rookie
YESSS I figured it out.
The hex filename has to be 8 characters or less.
danni
PostPosted: Apr 14, 2008 - 09:50 AM
E.g. "robot.hex" was fine.
Why you write it, but don't use it?
Peter
P.S.:
I tested it and it seems the path limit was about 256 characters (not 80).
pomprocker
PostPosted: Apr 14, 2008 - 09:24 PM
Rookie
I apoligize I just used robot.hex as an example. My fault. The real file name was 16 characters.
Also, What is the page size of this bootloader?
danni
PostPosted: Apr 14, 2008 - 09:50 PM
The bootloader need less than 512 bytes of code.
Thus the bootloader fuses must be set for the smallest size >=512 bytes (256 words).
Peter
pomprocker
PostPosted: Apr 15, 2008 - 05:49 AM
Rookie
Would you happen to know why i can only program through UART once, and then the second time around I can't even connect? Am I over writing the booloader?
Would the BootLock bits help? Do you know what I should set for the ATmega8?
danni
PostPosted: Apr 15, 2008 - 08:25 AM
Then you have not programmed the boot reset fuses accordingly.
Please look on the data sheet of your AVR and then set the fuses for reset start at Flashend - 255 words.
Peter
pomprocker
PostPosted: Apr 15, 2008 - 06:00 PM
Rookie
Thanks for your help Peter. I think I managed to get it working for me. It works great by the way!
societyofrobots
PostPosted: Apr 22, 2008 - 08:00 PM
pomprocker, what did you change to fix it?
How do YOU make a robot?
http://www.societyofrobots.com
societyofrobots
PostPosted: Apr 22, 2008 - 10:50 PM
Never mind I fixed it.
The problem was that the bootloader would only work within the first .3 seconds, but my usb took longer to power up thereby missing the time window. A rewiring kept the usb powered up . . .
But, where is the location in code to make the bootloader wait longer?
pomprocker
PostPosted: Apr 23, 2008 - 07:53 AM
Rookie
well I set the BootLock12
but it really had to do with the fact that I had a wire running from 5v out on the breakout board to the 5v out bus on the adc side.
pomprocker
PostPosted: Apr 23, 2008 - 08:00 AM
Rookie
When I implement the BlueSMiRF bluetooth for UART, when I upload code to it with fboot, how do I perform a "remote reset" of the ATmega8?
