PostPosted: Mar 05, 2008 - 04:08 AM
Am I correct that it is a lot about nothing?? ie it can be safely discarded and use the usual 1<<bitname.
The example
       TCCR2 = _BV(COM20)|_BV(CTC2)|_BV(CS20);
        DDRD = _BV(PD7);
Can also be
       TCCR2 = (1<<COM20)|(1<<CTC2)|(1<<CS20);
        DDRD = (1<<PD7);
of course this would also apply to the various incantations of defining a bit like portx.x and therefore make code a bit more ahemmm portable... Confused
And finally, is this just a winAvr thingy or a GCC thingy? ie all micro flavours of GCC use _BV
kmr
PostPosted: Mar 05, 2008 - 04:12 AM
Hi John, as far as I'm aware, _BV is only defined in the avr-libc headers. Extracted from avr/sfr_defs.h in avr-libc:
#define _BV(bit) (1 << (bit))
Personally, I don't use _BV(bit) since it does save any characters over (1<<bit), adds a layer of indirection, and is not cross-platform compatible (without redefining _BV on non-avr-libc platforms).
Kevin Rosenberg
http://b9.com
http://kevin.hypershots.com
kevin123
PostPosted: Mar 05, 2008 - 04:24 AM
I always wish there was a way to define a macro with a variable length parameter list. For example, it would be nice if you could do something like this:
TCCR2 = _BV(COM20,CTC2,CS20);
 DDRD = _BV(PD7);
microcarl
PostPosted: Mar 05, 2008 - 04:53 AM
kmr wrote:
...adds a layer of indirection, and is not cross-platform compatible (without redefining _BV on non-avr-libc platforms).
You mean more like... adds a layer of obscurity.
Well, exactly how does _bv(x); work?
Does:
_bv(0); // Set bit low?
and:
_bv(1); // Set bit high?
If so, then I can see a text reduction.
But if not, I'm willing to bet that, under the mask, _bv(x); is no different then #define SET_BIT(x) (1<<x);, or simply PORTX |= (1<<x);, and the like.
I can't say, as I use one of the underdog compilers and there is no such thing as _bv(x);.
This this is a question I've always wanted to know the answer to, but was afraid to ask...
Carl W. Livingston, KC5OTL
microcarl@roadrunner.com
"There are only two ways to sleep well at night... be ignorant or be prepared."
The original Dragon Slayer !
Long live the AVR!!!
PostPosted: Mar 05, 2008 - 05:00 AM
That's why I'm here for. Keep on pm-ming silly questions and I'll ask them in your behalf. I won't tell anyone. Laughing
mikeperks
PostPosted: Mar 05, 2008 - 05:32 AM
I think this discussion is making it more obscure than it needs to be. _BV is a C macro, pure and simple, and is of course an acronym for BitValue. It could have been an inline function and no-one would know the difference. I guess one person's "layer of indirection" is another person's "encapsulation of function".
I personally find _BV easier to read than (1 << bit) but I guess it is ultimately down to personal choice.
--Mike
kmr
PostPosted: Mar 05, 2008 - 05:56 AM
Carl: I meant text reduction in terms of horizontal space. For example, "_BV(5)" is the same number of characters as "(1<<5)".
Mike: Yes, _BV(bv) is more mnemonic than (1<<bv), but for someone doing development on multiple compilers and multiple platforms, then it is essential to ensure that _BV(bv) is defined and in-line with expectaions on that platform. For myself, it's easier and more rapid to know the (1<<bv) idiom than ensure there is some _BV() preprocessor macro or inline function already defined before employing that expansion.
Kevin Rosenberg
http://b9.com
microcarl
PostPosted: Mar 05, 2008 - 06:14 AM
Yes, I understood that. Wink
kmr
PostPosted: Mar 05, 2008 - 06:23 AM
Heh, I should have assumed! Laughing
I see your point more clearly now: what the heck does _BV() mean? Gotta check the preceding header files to find out!
Kevin Rosenberg
http://b9.com
schickb
PostPosted: Mar 05, 2008 - 08:27 AM
When I'm deep into coding, I usually start thinking macros like _BV make the code easier to read. Primarily because they reduce symbol characters (one reason I've always disliked perl is its heavy use of symbols).
But then I do something else for a while, and when I return to the code I think: "What do all these macros do again?" Maybe I should create wordy macros like
#define _TWOTOTHEPOWEROF(bit) (1 << (bit))
Argg... then I'll need editor macros to reduce typing. Just can't win Wink
EW
PostPosted: Mar 05, 2008 - 10:13 AM
It's not a WinAVR thing, and not a GCC thing, it is an avr-libc thing.
It is not meant to add a layer of obscurity. Believe it or not, there are people out there who know nothing about bit-wise operators, and so this was created as a "convenience macro" for these people. It is convenient to use because it is slightly shorter, and it hides the use of the bit-wise left-shift operator for those people (typically coming from a PC environment) who are uncomfortable with these operators.
BTW, BV stands for Bit Value.
Feel free to use it, or not, as you like.
PostPosted: Mar 05, 2008 - 10:49 PM
GREAT. 1 less thing to understand...now let's see what else I don't need to know about C Smile
caviar
PostPosted: Mar 06, 2008 - 08:50 AM
Much ado about nothing...
_BV() and several other macros are purely shorthand notation for "common" operations. Some have suggested that _BV(x) is easier to understand than (1<<x) but I think that can't be the case as you'd have to know that BV stood for bit value and that in turn meant two to the power of the value supplied. In which case knowing that 1<<x does the same thing isn't exactly a massive jump.
In fact, to my mind, the use of _BV(x) adds more of a mystery for the beginner... what s this magic thing, why does it start with an underscore, why is it in capitals, etc?
In my opinion the name is terse and adds no understanding whatsoever (it doesn't, for example, indicate why you'd want to perform this magic in the first place - usually to produce a "mask value"). So I'll go further, and suggest that its purpose is to OBSCURE, allowing us who are in the know look superior Wink
S-Sohn
PostPosted: Mar 06, 2008 - 10:58 AM
You might don't get a variable parameter list but you could use something like this:
// BM => Bit Mask
#define _BM(bit7, bit6, bit5, bit4, bit3, bit2, bit1, bit0)     \
    ((bit7 == 7) << (bit7 & 7)) |                               \
    ((bit6 == 6) << (bit6 & 6)) |                               \
    ((bit5 == 5) << (bit5 & 5)) |                               \
    ((bit4 == 4) << (bit4 & 4)) |                               \
    ((bit3 == 3) << (bit3 & 3)) |                               \
    ((bit2 == 2) << (bit2 & 2)) |                               \
    ((bit1 == 1) << (bit1 & 1)) |                               \
    ((bit0 == 0) << (bit0 & 0))                                 \
You could use the macro this way (invert bit numbers which should be cleared):
UCSR0A = _BM (RXC0, TXC0, ~UDRE0, ~FE0, ~DOR0, ~UPE0, ~U2X0, ~MPCM0);
Which would be preprocessed to:
(*(volatile uint8_t *)(0xC0)) = ( ((7 == 7) << (7 & 7)) | ((6 == 6) << (6 & 6)) | ((~5 == 5) << (~5 & 5)) | ((~4 == 4) << (~4 & 4)) | ((~3 == 3) << (~3 & 3)) | ((~2 == 2) << (~2 & 2)) | ((~1 == 1) << (~1 & 1)) | ((~0 == 0) << (~0 & 0)) );
and compiled to:
ldi   r24, 0xC0   ; 192
sts   0x00C0, r24
Regards
Sebastian
S-Sohn
PostPosted: Mar 06, 2008 - 11:11 AM
UCSR0A = _BM (RXC0, TXC0, !UDRE0, !FE0, !DOR0, !UPE0, !U2X0, !MPCM0);
Gives the same result. The NOT operator might be the clearer method in this matter.
Regards
Sebastian
skeeve
PostPosted: Mar 06, 2008 - 06:17 PM
Much of my source is python code that generates header files.
If FRED is supposed to refer to pin D4, the python would generate
#define PORT_FRED PORTD
#define  PIN_FRED  PIND
#define  DDR_FRED  DDRD
#define  BIT_FRED  4
#define MASK_FRED  0x10
#define PCINT_FRED_vect PCMSK2
This way, I only have to use FRED==D4 once.
The rest of the time, I just have to spell correctly.
If I don't, I'll get an error message.
Michael Hennebry
PostPosted: Mar 06, 2008 - 06:31 PM
Hmmm...
_BV(n)
(1<<n)
Looks like the same length to me.
skeeve
PostPosted: Mar 06, 2008 - 07:57 PM
Hmmm...
_BV(n)
(1<<n)
The former has fewer shift changes.
Michael Hennebry
PostPosted: Mar 06, 2008 - 10:08 PM
and compiled to:
ldi r24, 0xC0 ; 192
sts 0x00C0, r24
Laughing Laughing Laughing So it's SO MUCH shorter and clearer writing stuff in ASM it seems. Thanks for proving the point!! Laughing Laughing Laughing
PostPosted: Mar 06, 2008 - 10:12 PM
But that doesn't make it "shorter".
