jwp
PostPosted: Oct 19, 2007 - 07:08 AM
Newbie
I've recently been trying to use the buildroot utility to create an image for the NGW100. Unfortunately i can't get it to work.
I followed the instructions from Atmels user guide but it hangs when i make.
I am using Ubuntu 6.10 running on VMware
Code:
make[3]: Entering directory `/home/johan/Desktop/linux/buildroot-poging2/toolchain_build_avr32_nofpu/fakeroot-1.8-host'
CONFIG_FILES= CONFIG_HEADERS= /bin/sh ./config.status
config.status: executing depfiles commands
config.status: executing libtool commands
/bin/sh ./libtool --tag=CC   --mode=link /usr/bin/gcc  -g -O2   -o faked faked.o libcommunicate.la -ldl
eval: 1: libtool_args+=: not found
eval: 1: compile_command+=: not found
eval: 1: finalize_command+=: not found
libtool: link: /usr/bin/gcc  ./.libs/libcommunicate.a -ldl
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../lib/crt1.o: In function `_start':
(.text+0x18): undefined reference to `main'
collect2: ld returned 1 exit status
make[3]: *** [faked] Error 1
make[3]: Leaving directory `/home/johan/Desktop/linux/buildroot-poging2/toolchain_build_avr32_nofpu/fakeroot-1.8-host'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/johan/Desktop/linux/buildroot-poging2/toolchain_build_avr32_nofpu/fakeroot-1.8-host'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/johan/Desktop/linux/buildroot-poging2/toolchain_build_avr32_nofpu/fakeroot-1.8-host'
make: *** [/home/johan/Desktop/linux/buildroot-poging2/toolchain_build_avr32_nofpu/fakeroot-1.8-host/faked] Error 2
I googled and searched everywhere but i can only find someone with the same problem here but he hasn't been answered Sad
I think it has something to do with having the wrong version of a library or something.
I hope someone can help me... Thanks in advance!
hce
PostPosted: Oct 19, 2007 - 07:10 AM
Could you change to use the snapshot Buildroot for AVR32?
PS! Always state which version of Buildroot for AVR32 you are using Smile
jwp
PostPosted: Oct 19, 2007 - 07:20 AM
Newbie
Thanks for the fast reply. I'm using (from atmel's website)
Buildroot for AVR32 (6.1 MB, revision 2.1.0-rc5, updated 20070924)
Release candidate, not fully tested. Some packages may not work for AVR32 architecture.
This release is base on upstream Buildroot snapshot 20070718.
Downloading the latest snapshot from the site...
Edit: theres a snapshot at the bottom i see, dont have to use the one from uclib SmileWink
squidgit
PostPosted: Oct 19, 2007 - 07:49 AM
I could never get fakeroot 1.8* to compile either. A quick fix is to change the version number at the top of package/fakeroot/fakeroot.mk to 1.5.10, that one works just about fine.
Donno what the problem is, I haven't bothered to investigate too much.
-S.
hce
PostPosted: Oct 19, 2007 - 07:55 AM
The problem is some borked libtool stuff in the downloaded source code. I tried adding a patch for it which should be in the latest snapshot.
