bobgardner
PostPosted: Sep 18, 2007 - 05:54 PM
10k+ Postman
I'll start out with an imagrcraft example for a usart rx interrupt... someone kindly quote this and add a gcc exmple and a CV example? I think a side by side comparison will show how to convert from one compiler to another more easily.
Code:
//imagecraft example
//required h files
#include <iom32v.h> //
//handler declaration
#pragma interrupt_handler uart_rx_isr:iv_USART_RX
void uart_rx_isr(void){
  //rest of code
//gcc example
//h files
//handler
//codevision example
//h files
//handler
 View user's profile Send private message Send e-mail Visit poster's website
lfmorrison
PostPosted: Sep 18, 2007 - 06:03 PM
Here's the AVR-GCC equivalent:
Code:
//required h files
  //rest of code
//gcc example
//required h files
#include <avr/interrupt.h> //
// The vector name (USART_RXC_vect in this case)
// will vary from part to part, based on the
// name given to that vector in your part's
// datasheet.
ISR(USART_RXC_vect){
  //rest of code
//h files
//handler
bobgardner
PostPosted: Sep 18, 2007 - 06:05 PM
10k+ Postman
Looks simpler than I imagined so far.....
clawson
PostPosted: Sep 18, 2007 - 06:21 PM
10k+ Postman
Code:
//required h files
  //rest of code
//gcc example
//required h files
// datasheet.
  //rest of code
//h files
#include <mega32.h>
//handler
// the bit that actually hooks the right vector in
// this is the USART_RXC that comes from mega32.h. As
// for GCC the names will vary from AVR to AVR
interrupt [USART_RXC] my_name_for_rx_isr(void) {
  //rest of code
bobgardner
PostPosted: Sep 18, 2007 - 06:36 PM
10k+ Postman
Cool stuff. I hope I'll be able to find this next time I try to port an example! Thanks!
david.prentice
PostPosted: Sep 18, 2007 - 06:56 PM
10k+ Postman
I have files that will compile with PIC, 8051 and AVR. Compilers for each of these targets have different syntax for declaring an ISR.
I prefer to keep source code as portable as possible while using one common header file that copes with the differences.
However those that require #pragma make it very awkward to construct a generic #include "mcu.h" that defines correct macros for each mcu and compiler combination. Similarly a #asm is also not really allowed within a pre-processor expansion.
Would it not be nice if all C compiler vendors followed a similar syntax ! Not only this but my neighbour would love to fly his weaners to overcome the current Foot and Mouth restrictions.
glitch
PostPosted: Sep 18, 2007 - 09:07 PM
Code:
//IAR example - AVR IAR Compiler [ICCAVR] (Current Version)
//h files
#include <iom32.h> // MCU include
#include <inavr.h> // Architecture include
//brings in __enable_interrupt() and __disable_interrupt()
#pragma vector=USART_RXC_vect
__interrupt void my_name_for_rx_isr(void) {
  //rest of code
//IAR example - A90 IAR Compiler [ICCA90] (Old Version)
//h files
#include <ina90.h> // Architecture include
// brings in _SEI() and _CLI()
interrupt[USART_RXC_vect] void my_name_for_rx_isr(void) {
  //rest of code
//Rowley CrossWorks example
//h files
#include <ATmega32.h> // MCU include
void my_name_for_rx_isr(void) __interrupt[UARTRX_VECTOR]
  //rest of code
//SPJ Systems' CAVR
//h files
interrupt(USART_RXC) void my_name_for_rx_isr(void) {
  //rest of code
//required h files
#pragma interrupt_handler my_name_for_rx_isr:iv_USART_RX
void my_name_for_rx_isr(void){
  //rest of code
//gcc example
//required h files
// datasheet.
  //rest of code
//h files
#include <mega32.h>
//handler
  //rest of code
Added IAR (new & old) Since many of the Atmel APP notes are based on IAR code, both new and old versions.
Also, for completeness, added Rowley CrossWorks (based on the documentation for it) as well as SPJ System's CAVR (Also based on the documentation).
glitch
PostPosted: Sep 18, 2007 - 10:54 PM
Code:
// IAR - AVR IAR Compiler [ICCAVR] (Current Version)
// required includes
#include <processor-specific include>
// brings in __enable_interrupt() and __disable_interrupt()
// not requred for the ISR itself, but will be needed to
// enable interrupts in your code
#pragma vector=interrupt-vector-name
__interrupt void my_name_for_this_isr(void) {
  //rest of code
// NOTE: The ISR function must immediately follow the #pragma
// IAR - A90 IAR Compiler [ICCA90] (Old Version)
interrupt[interrupt-vector-name] my_name_for_this_isr(void) {
  //rest of code
// gcc-avr
// be sure to set the correct processor model in the make file
ISR(interrupt-vector-name){
  //rest of code
// ImageCraft ICC for AVR
#pragma interrupt_handler my_name_for_this_isr : interrupt-vector-name
void my_name_for_this_isr(void){
  //rest of code
// NOTE: The ISR function does not need to immediately follow the #pragma
// HP InfoTech CodeVisionAVR
interrupt [interrupt-vector-name] my_name_for_this_isr(void) {
  //rest of code
// alternate
#include <io.h>
// be sure to set the correct processor model in the project options
  //rest of code
// Rowley CrossWorks
void my_name_for_this_isr(void) __interrupt[interrupt-vector-name]
  //rest of code
// SPJ Systems' CAVR
interrupt(interrupt-vector-name) void my_name_for_this_isr(void) {
  //rest of code
Made it more generic, by abstracting out the processor, function, and vector names.
bobgardner
PostPosted: Sep 18, 2007 - 11:12 PM
10k+ Postman
Now all the EEs can get their interrupts working and call themselves Software Engineers! I hope this comparison is helpful to some poor soul that has to adapt modules from one compiler to another. Is this a great forum or what?
theusch
PostPosted: Sep 19, 2007 - 12:06 AM
10k+ Postman
As an option, you can also
#include <io.h>
similar to your annotation for GCC and use the file indicated by the project options.
Lee
AllN
PostPosted: Sep 19, 2007 - 12:12 AM
Posting Freak
Most Excellent thread!!
Thanks for the post Bob; and to all the responders too!!!
John
Resistance is futile…… You will be compiled!
zbaird
PostPosted: Sep 19, 2007 - 12:42 AM
So Bob, when you're happy with this, why not have it moved to the tutorials forum where it will find a happy and appropriate home?
Chuck Baird
"It's better to catch the trapeze than test the safety net" -- RPi book
http://www.cbaird.org
bobgardner
PostPosted: Sep 19, 2007 - 01:15 AM
10k+ Postman
Make it so Number One!
microcarl
PostPosted: Sep 19, 2007 - 01:19 AM
You must be refering to Ensign ABCMiniUser of the AVRFreaks Star Fleet Command...
Carl W. Livingston, KC5OTL
microcarl@roadrunner.com
"There are only two ways to sleep well at night... be ignorant or be prepared."
The original Dragon Slayer !
Long live the AVR!!!
glitch
PostPosted: Sep 19, 2007 - 04:31 AM
#include <io.h>
Lee
Added
abcminiuser
PostPosted: Sep 19, 2007 - 04:55 AM
Moderator
Ensign?! More like supreme commander!
Actually, despite being the supreme commander of this here ship, I don't seem to have a commander's access card to the moderation computer of this particular forum. I'm afraid I've only got my Tutorials, Off-Topic and General Electronics ones on me. Care to repost in the Tutorials section while I go berate the underlings responsible for this lamentable oversight?
- Dean Twisted Evil
Atmel Studio 6.1 is now released, grab it here.
Report AS6/ASF bugs here.
theusch
PostPosted: Sep 19, 2007 - 05:51 AM
10k+ Postman
So, who is going to volunteer to do the whomping macro (somewhat akin to ISR() ) to make a generic interface? I modified one purchased commercial source library to add CV to it; it was fairly straightforward IIRC--each of the compilers has a preprocessor signature that one can access.
Example: "Prototype"
Code:
#ifdef __ICCAVR__
#pragma interrupt_handler CpCoreIntHandler:2
#endif
#ifdef __CODEVISIONAVR__
interrupt [EXT_INT0] void    CpCoreIntHandler      (void);
#endif
Function definition:
Code:
#ifdef __ICCAVR__
void CpCoreIntHandler(void)
#endif
#endif
lfmorrison
PostPosted: Sep 19, 2007 - 12:54 PM
IMHO the problem is that a macro (like GCC's ISR) cannot legally contain a preprocessor #pragma such as ImageCraft or the new version of IAR uses.
I think Jörg (dl8dtl) has written an abstraction layer that bypasses this constraint and allows common source code (within some constraints such as not allowing the use of IAR's built-in handling of the Flash address space) to be compiled on either IAR or GCC. IIRC he uses the alternative C99 Pragma() construct instead of the preprocessor equivalent, because it can be legally embedded within a macro.
IAR obviously has an implementation of this C99 form of pragma, but apparently it is somewhat finicky. Does ImageCraft?
theusch
PostPosted: Sep 19, 2007 - 03:27 PM
10k+ Postman
Even within a false #ifdef ? [I'd just assume it was only scanning for the matching #endif. But I just do K.I.S.S. C and preprocessor.]
Lee
lfmorrison
PostPosted: Sep 19, 2007 - 04:59 PM
Well, at that level, I think it would work. But that means you couldn't wrap everything up in a neat macro like you might be able to if it weren't for those darned pragmas.
For example, I think this:
Code:
#include "compatibility.h"
COMPILER_INDEPENDENT_INTERRUPT(vector_name)
Looks nicer than this:
Code:
#ifdef __ICCAVR__
#include "something"
#elif defined(__CODEVISIONAVR__)
#include "something else"
#endif
#ifdef __ICCAVR__
#endif
In the past, I wrote COMPILER_INDEPENDENT_INTERRUPT()-like macro that I saw to work correctly for both GCC and CodeVision. I understand that Jörg has already written something that he says worked correctly for both GCC and IAR.
But I haven't figured out how I'd write one that also encompasses ImageCraft because the C preprocessor chokes when one tries to wrap a #pragma up inside a #define.
