amor
PostPosted: Aug 15, 2007 - 02:34 AM
Rookie
i don't understand why is it give warning?
warning: .cseg .db misalignment - padding zero byte
my code:
Code:
prompt1:   .db      "Yuksek voltaj hatasi!", null
prompt2:   .db      "voltaj = ", null
[b]=>[/b]prompt5:   .db      "Dusuk voltaj hatasi!", null
prompt4:   .db      "Yuksek sicaklik hatasi!", null
voltajyazi:
      ldi      ZH,high(2*prompt2)
      ldi      ZL,low(2*prompt2)
      rcall   PrStr
      ret
volyukprompt:
      ldi      ZH,high(2*prompt1)
      ldi      ZL,low(2*prompt1)
      rcall   PrStr
      ret
voldusprompt:
      ldi      ZH,high(2*prompt5)
      ldi      ZL,low(2*prompt5)
      rcall   PrStr
      ret
sicyukprompt:
      ldi      ZH,high(2*prompt4)
      ldi      ZL,low(2*prompt4)
      rcall   PrStr
      ret
Koshchi
PostPosted: Aug 15, 2007 - 04:25 AM
10k+ Postman
The memory reserved with .db must be an even number of bytes. One or more of your strings must be an odd number of bytes, so the assembler padded it with an extra byte.
Steve A.
theusch
10k+ Postman
A thread from a Forum search on "misalignment":
http://www.avrfreaks.net/index.php?name ... mp;t=27905
Mike B wrote:
This is what is happening. The AVR flash application program memory is 16 bits wide. Each byte is 8 bits wide, so you can also say the application program memory is 2 bytes wide (16 divided by 8 ). Two bytes together is also known as a 16 bit word.
When you use .db to place bytes in the flash application program memory, it takes two bytes to fill each word (each word has its own unique address). If you only specify an odd number of .db bytes, the assembler will pad your odd count with an extra zero byte (the assembler just happened to use zero for the value, it has nothing to do with strings). When you get the assembler warning message it pads your 21 bytes to 22 bytes to make it fit evenly into the 16 bit application flash memory words. If you do not want to see the warning message, you can add your own extra zero byte. In either case, you can go ahead and use the zero byte to terminate your string.
The newer versions of the assembler should pad the extra even byte correctly, without causing any problems.
From the AVR Assembler User's Guide:
DB - Define constant byte(s) in program memory and EEPROM
The DB directive reserves memory resources in the program memory or the EEPROM memory. In order to be able to refer to the reserved locations, the DB directive should be preceded by a label. The DB directive takes a list of expressions, and must contain at least one expression. The DB directive must be placed in a Code Segment or an EEPROM Segment.
The expression list is a sequence of expressions, delimited by commas. Each expression must evaluate to a number between -128 and 255. If the expression evaluates to a negative number, the 8 bits twos complement of the number will be placed in the program memory or EEPROM memory location.
If the DB directive is given in a Code Segment and the expressionlist contains more than one expression, the expressions are packed so that two bytes are placed in each program memory word. If the expressionlist contains an odd number of expressions, the last expression will be placed in a program memory word of its own, even if the next line in the assemby code contains a DB directive. The unused half of the program word is set to zero. A warning is given, in order to notify the user that an extra zero byte is added to the .DB statement
js
PostPosted: Aug 15, 2007 - 05:36 AM
10k+ Postman
Location: Sydney, Australia (Gum trees, Koalas and Kangaroos, No Edelweiss)
Code:
Ther are 20 characters in the string plus the null makes it 21, so the assembler makes it even by putting an extra null at the end as explained above.
amor
PostPosted: Aug 15, 2007 - 01:50 PM
Rookie
i understand very good:). thanks guys
now, it is ok
Code:
"Dusuk voltaj hatasi! ", null
4RESTER
PostPosted: May 01, 2013 - 09:48 AM
Newbie
How to switch off into the AVRASM2 the automatic padding by $00?
 View user's profile Send private message Send e-mail
clawson
PostPosted: May 01, 2013 - 10:05 AM
10k+ Postman
You cannot - opcodes must be word aligned so if the byte length of the data is odd then it must be padded so that it regains even alignment. If you have lots of data with "holes" then consider re-arranging the data storage.
4RESTER
PostPosted: May 01, 2013 - 11:06 AM
Newbie
For the storage datas into the Flash (CSEG) to access via the LPM. Like this:
Code:
l_LookUp_1: .DB $DE,$AD,$BE  ;<=- unwanted padding !!!
            .DB $EF          ;<=- unwanted padding !!!
            .DB $AA,$0F,$55  ;<=- unwanted padding !!!
            .DB $F0          ;<=- unwanted padding !!!
That's very bad, that imposible to turn off the padding.
clawson
PostPosted: May 01, 2013 - 11:35 AM
10k+ Postman
Code:
 l_LookUp_1: .DB $DE,$AD,$BE, $EF, $AA,$0F,$55, $F0
No padding Wink
(and in general just put an even number of bytes in each .db).
4RESTER
PostPosted: May 01, 2013 - 06:10 PM
Newbie
clawson wrote:
Code:
No padding Wink
In single line.
What about it?
Code:
l_LookUp_2: .DB $AA,$0F,$55  ;<=- unwanted padding !!!
Code:
.CSEG
.ORG $00F0
txt_OK:      .DB   "OK",0
txt_ERROR:   .DB   "ERROR",0
clawson
PostPosted: May 01, 2013 - 06:36 PM
10k+ Postman
In single line.
What about it?
No the only requirement is that each line have an even number of bytes:
Code:
l_LookUp_1: .DB $DE,$AD,$BE, $DE
            .DB $AD,$BE
l_LookUp_2: .DB $AA,$0F,$55, $DE
            .DB $AD,$BE
JohanEkdahl
PostPosted: May 01, 2013 - 08:23 PM
10k+ Postman
If you really want to arrange your code textually with odd number of bytes per line I believe that you can use the "line continuation symbol":
Code:
l_LookUp_1: .DB $DE,$AD,$BE, \
                $EF,         \
                $AA,$0F,$55, \
                $F0
The important thing is that each DB has an even number of bytes. Not each line.
4RESTER
PostPosted: May 01, 2013 - 09:30 PM
Newbie
Code:
                $EF,         \
                $AA,$0F,$55, \
                $F0
This work with the values, but not working with the text datas Crying or Very sad
Code:
.ORG $00F0
txt_OK:      .DB   "OK",0, \
js
PostPosted: May 01, 2013 - 11:47 PM
10k+ Postman
But with the above text a padding byte makes NO difference to you.
You can't use the line termination if you have a new label in the next line.
JohanEkdahl
PostPosted: May 02, 2013 - 09:21 AM
10k+ Postman
Code:
.ORG $00F0
No, of-course not. The continuation character is merely a way to make your code text look better. For the assembler, the above attempt is equivalent to
Code:
.ORG $00F0
txt_OK:      .DB   "OK",0, txt_ERROR:   .DB   "ERROR",0
which of-course is bad code.
The bottom line, stated several times in this thread already, is that every DB has to have an even number of bytes in it, or you will get the warning.
Above you have two DBs and must see to it that each of them has an even number of bytes. There is no way around it, so you must:
Code:
txt_OK:      .DB   "OK",0
joeymorin
PostPosted: May 02, 2013 - 11:53 PM
I think perhaps you are under the mistaken notion that this is a limitation of the assembler (or the linker). It is not. In AVR, instructions are 16-bit words, and all references to flash (in the context of instructions) are with word addresses. It is impossible to cause an AVR to execute code from an odd byte address, as that would be in the middle of an instruction word. The assembler knows this and is simply enforcing the restrictions imposed by the hardware.
JJ
4RESTER
PostPosted: May 03, 2013 - 03:42 AM
Newbie
JJ
LPM adressing as 8-bits bytes (not by 16-bits words).
I wont to know how to bypass limitation of AVRASM2 to control padding/no padding.
joeymorin
PostPosted: May 03, 2013 - 03:55 AM
LPM is for accessing data contained in flash.
Look at it this way: Imagine you had a single DB with an odd number of bytes. If the assembler didn't pad to an even number of bytes, then the instruction that follows the data contained in the DB would span a word boundary. The cpu cannot jump to or execute and instruction that is not word-aligned. Were the assembler or linker to generate code that had instructions offset by a single byte in this fashion, the cpu would basically be executing invalid and random code. Padding an odd-byte DB to an even number of bytes is the only way to fix this.
If you need every last byte, you'll have to store multiple data objects together in a single DB and manage the addressing yourself.
Perhaps an assembler expert can suggest a way to convince the assembler to pad only the last in a series of adjacent DBs, but to my knowledge that is not possible.
JJ
js
PostPosted: May 03, 2013 - 04:20 AM
10k+ Postman
You CANNOT DO IT as explained above, just make sure that you have an EVEN number of data bytes, if not then the assembler will pad it for you wether you like it or not. Smile
edit example of how to put things together to even out bytes
Code:
CHAR_GEN:
;Space !
.db   0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x04,0x04,0x04,0x04,0x04,0x00,0x04
2 by 7 bytes data combined for an even number of bytes (14).
Code:
;2 tables together to stop addition of padding bytes
   .db    6 , 62 , 58 , 50 , 38 , 24 , 9   ,   6 , 50 , 48 , 41 , 31 , 20 , 7
   .db    6 , 41 , 39 , 33 , 26 , 16 , 6 ,   6 , 34 , 31 , 28 , 21 , 13 , 5
   .db    4 , 41 , 35 , 23 , 9 ,            4 , 33 , 29 , 19 , 7
   .db    4 , 27 , 24 , 15 , 6 , 0
2 sinewave tables of different amplitude together, only the last unused byte is padded by a zero.
JohanEkdahl
PostPosted: May 03, 2013 - 08:18 AM
10k+ Postman
The how: YOU CAN'T. Period.
The why: Reread everything above.
This can be debated. You could just as well see it as the Z register having all but its lowest bit used as a flash address (addressed in words), and the lowest bit then selects what byte from the read word to pick. It is even likely that this is how it actually works. A whole word is read from flash to the CPU, and then (internal to the CPU) LSB of the Z register is then used to pick the high or low byte out of this word.
Anyway, the bottom line is: You just can't disable the padding. Live with it, and move on..
