Yehonatan
PostPosted: Apr 13, 2009 - 06:43 PM
Hi
My name is Yoni and I practical engineering from Israel
And sorry about my poor English
today i began to write interface progrem for LCD
the instruction strings I am going to store in the flase area for that I am use the avr/pgmspace/h librery and I red this great artical which help me a lot
http://www.avrfreaks.net/index.php?name ... mp;t=38003
but when I wrote this progrem the compiler didnt found any bug and sdidfnt show any warning but when I simulate the program the out port didnt show the right ascii value and show other one
this is the progrem
#include<avr/pgmspace.h>
#include<avr/io.h>
#include<avr/version.h>
void data_for_send(char *data)
while (pgm_read_byte(data) != '\0')
PORTD=pgm_read_byte(data);
data++;
void main()
asm("nop");
prog_char TestFlashStr[] = "Hello";
DDRD=0xff;
data_for_send(TestFlashStr[0]);
asm("nop");
if any one know what is the problem please notifi me what is it or may be there is a bug with my compiler
the compiler is the latest or almost the latest version of winavr
another question any one have another place which contain information about this librery which is not the avr reference where i can learn more about this librery
Thanks Yoni Spiegel
atomicdog
PostPosted: Apr 14, 2009 - 12:23 AM
You are not using the array correctly
Do not dereference the array.
void main()
    asm("nop");
    DDRD=0xff;
    data_for_send(TestFlashStr);
    asm("nop");
Edit: Removed incorrect info
sternst
PostPosted: Apr 14, 2009 - 01:02 AM
atomicdog wrote:
You need to dereference the pointer.
No. His version of data_for_send is correct.
Yes, that's right.
@ Yehonatan:
Your major problem is that you try to put an automatic local variable into flash. That does not work. Make TestFlashStr global or static local.
Stefan Ernst
Yehonatan
PostPosted: Apr 14, 2009 - 09:46 AM
Hi
I changed the string to global but it still doesn't work well
the first value that I receive in out put is 0xC
after that 0x94
and 0x5A
any one have an idea why the program still there is a bug
Yoni Spiegel
Yehonatan
PostPosted: Apr 14, 2009 - 09:47 AM
Hi
after that 0x94
and 0x5A
Yoni Spiegel
PostPosted: Apr 14, 2009 - 09:48 AM
So post the code you are now using. Also please do NOT cross post - I wasted my time answering your other copy of this same thread last night.
Yehonatan
PostPosted: Apr 14, 2009 - 10:07 AM
the new code is
#include<avr/io.h>
prog_char TestFlashStr[10] = "Hello";
data++;
void main()
asm("nop");
DDRD=0xff;
asm("nop");
and sorry the mass that I done my laptop doing a lot of problems with this web site and I dont know why (may be buster or virous ) so if you can give me a link to the next post it would be helpful Embarassed
PostPosted: Apr 14, 2009 - 10:21 AM
Would you PLEASE learn to use [ code ] tags - your code is virtually unreadable otherwise.
Anyway it would seem that you have completely ignored the advice given by atomicdog, Stefan and myself previously. As I told you in the other copy of this thread use:
data_for_send(&TestFlashStr[0]);
or
but not:
You need to pass the ADDRESS OF the object, not the value of the first element as your receiving routine is defined to accept a pointer not a value.
Yehonatan
PostPosted: Apr 14, 2009 - 10:30 AM
thanks a lot this really was my problem Very Happy
PostPosted: Apr 14, 2009 - 10:43 AM
You do understand the change that has been made don't you? That is you do understand the purpose of '&' or the fact that specifying the name of an array passes a pointer to it?
Yehonatan
PostPosted: Apr 14, 2009 - 10:59 AM
Yes I understand this change data_for_send(&TestFlashStr[0]); to send the adress to the pointer I think
but I dont understand why this is OK
but I will be happy to read better explantion if someone have
I glad to learn new information especially with AVR
PostPosted: Apr 14, 2009 - 11:17 AM
C just does you a favour of passing the address of an array if you specify nothing but the name without [] to pick out a specific element. When you do something like:
char text[] = {"Hello, world"};
char buffer[20];
strcpy(buffer, text);
UART_printstring(buffer);
then it acts the same as:
char buffer[20];
strcpy(&buffer[0], &text[0]);
UART_printstring(&buffer[0]);
(just a bit easier to read).
Yehonatan
PostPosted: Apr 14, 2009 - 12:47 PM
thanks a lot now I understand this topic much better than befor
dkinzer
PostPosted: Apr 14, 2009 - 05:11 PM
It would seem that at least a warning would be appropriate here, perhaps even an error. Here are two pieces of test code, both of which compile without error/warning but only one produces code that comports with the specified attributes.
This one results in correct code:
#include <avr/pgmspace.h>
char b;
  static prog_char data[] = "abcd";
  b = pgm_read_byte(data);
This one results in incorrect code:
char b;
Don Kinzer
ZBasic Microcontrollers
http://www.zbasic.net
PostPosted: Apr 14, 2009 - 05:14 PM
prog_char would need some serious re-work then - at present it's nothing more than a typedef. Also how can a macro tell if it's been invoked in the context of a local or a global? Or were you suggesting an actual modification to the linker?
dkinzer
PostPosted: Apr 14, 2009 - 05:38 PM
I wasn't suggesting an implementation - I don't know enough about the structure of the compiler/linker to do so.
I have seen a warning related to Flash data items. For example, the code below produces the message:"warning: '__progmem__' attribute ignored". In both cases the attribute indicating that the data item should be placed in Flash has to be represented somewhere along with the attribute indicating whether the data item is statically or dynamically allocated.
char b;
  char foo[] PROGMEM;
  b = pgm_read_byte(foo);
Don Kinzer
