abhijit8
PostPosted: Jun 22, 2007 - 07:34 AM
Newbie
Hey anyone knows from where can i download the Bray's terminal(http://www.avrfreaks.net/index.php?module=FreaksTools&func=viewItem&item_id=293 Its homepage http://bray.velenje.cx/avr/terminal/ is not working..
curtvm
PostPosted: Jun 22, 2007 - 09:42 AM
http://www.smileymicros.com/download/te ... tion=42:42
abhijit8
PostPosted: Jun 27, 2007 - 04:28 PM
Newbie
thanks..
bray
PostPosted: Mar 01, 2008 - 03:51 PM
Newbie
New web address....
http://braypp.googlepages.com/terminal
B
nleahcim
PostPosted: Mar 01, 2008 - 05:03 PM
bray wrote:
Bray! I was wondering if you were still around. Out of curiosity, what is new in the latest version? By the way, I've been loyally using your tool for something like 2-3 years now.
stevech
PostPosted: Mar 01, 2008 - 06:13 PM
Heck of a good program. Use it all the time. Thank you!
kmr
PostPosted: Mar 01, 2008 - 06:23 PM
Bray, by far my favorite microcontroller interfacing program -- thanks!
Kevin Rosenberg
http://b9.com
http://kevin.hypershots.com
 View user's profile Send private message Send e-mail Visit poster's website
bray
PostPosted: Mar 01, 2008 - 06:55 PM
Newbie
Hello
What's new? Hmmm...depends on what is your last version. There were some major changes on com port scanning and selecting (up to com32) and small bug fixes. If you can tell me version date i can tell you some more details.
B
smileymicros
PostPosted: Mar 01, 2008 - 07:41 PM
Bray,
I just made a $50 donation to you since I mention your program in my book and I've used it a lot in my own development work. I'm making this public in the hopes that others who use your terminal will be motivated to also donate to you for your excellent work.
Smiley
FREE TUTORIAL: 'Quick Start Guide for Using the WinAVR C Compiler with ATMEL's AVR Butterfly' AVAILABLE AT: http://www.smileymicros.com
nleahcim
PostPosted: Mar 01, 2008 - 08:48 PM
bray wrote:
Hello
B
I have been using 20040714. I just noticed that when running the latest from your website it seems to access the Internet. Why is this? (checking for updates perhaps?)
bray
PostPosted: Mar 01, 2008 - 09:31 PM
Newbie
Huh...I am really glad to hear that something i'm doing since 1997 is useful for someone else. Yes, it's more than 10 years now. Wink
Smiley, many thanks!
Huh...there was a lot of changes since 20040714.
Here is my "WHAT WAS DONE" list Wink
Code:
14.07.2004 - more scripting, rxclear bugfix
  16.07.2004 - ascii table fixes
  22.07.2004 - rescan ports and only connect button, resize bug
  26.07.2004 - new script functions
  28.07.2004 - TCP/IP remote
  31.08.2004 - shrink panels
  01.09.2004 - version with 12 com ports
  05.09.2004 - auto sctoll in hex mode
  16.09.2004 - selectable TCP remote port
  27.09.2004 - request/response form
  18.10.2004 - scripting - SetRTS, SetDTR
  29.10.2004 - longer repeat delay 99999ms
  04.11.2004 - new macro settings form
  05.11.2004 - 512k send file buffer, macro buttons on main form
  07.11.2004 - scripting - Graph_Clear, Graph_Text, ...
  17.11.2004 - highlighted macro buttons in auto mode, script filename
  22.12.2004 - scripting - Graph_Rx
  01.01.2005 - RxMemo savetofile...
  03.01.2005 - add CR/CR+LF, show & hide buttons and com settings
  08.01.2005 - send file delay
  09.03.2005 - better delay function in scripting
  10.03.2005 - wider range for macro delay 0000-9999ms (%DLYxxxx)
  12.06.2005 - invert option for RTS (RS485)
  07.10.2005 - cpystr in scripting (could be removed or changed)
  07.10.2005 - %SUM command
  09.10.2005 - open file
  27.12.2005 - macro naming
  20.01.2006 - COM10 bugfix
  11.02.2006 - remote port select
  26.02.2006 - custom BR bugfix (must reconnect to change value)
  20.04.2006 - new comport selection engine ;)
  25.04.2006 - request response
  20.09.2006 - no more con/disconnect from keyboard(PK), char delay for macro
  12.07.2007 - com20 bugfix
  10.08.2007 - comxx fix
About net access...
You probably get a warning from your firewall, right?
This is because terminal is trying to "listen" on port 23 (telnet port). This is a feature that was added in v20040728 for TCP/IP remote control. It works but it's still some kind of experimental thing.
Let me explain how this works and maybe be useful.
For example...if you have two PCs on your local network and only one have COM port you can connect your com device to this PC and run terminal on it and then remotely connect to this PC from another. All you have to do is to open command prompt and telnet to PC with COM port (telnet 192.168.x.x). Now you can communicate with terminal via ethernet. All you type is transfered into Tx window and all from Rx window will be displayed.
I hope this will help.
tblough
PostPosted: Mar 02, 2008 - 12:44 PM
I've been looking for an update as well. My $10 is on it's way.
Cheers,
Tom
nleahcim
PostPosted: Mar 02, 2008 - 10:34 PM
Code:
About net access...
Hi Bray - thanks for clearing that up. Sounds like a neat feature.
One thing I've never understood was what was appended to the end of messages being sent. So right now if all check boxes are unchecked, if you hit enter when entering text, it just sends the text without anything at the end (no CR or anything like that), right? Then if you check "+CR" it will add on a CR to the end of the string in the text entry box. And if you check CR=CR+LF then it'll add both a CR and an LF? Or am I completely off?
Also, have you ever thought about giving your terminal tabs so that you can monitor multiple com ports at once? I often will have two or three instances of your terminal open (in fact, I have two open right now) so that I can listen to a couple different devices at the same time. Right now I just alt-tab between them, but tabs would be cool Smile
Anyways, thanks again for making such a useful tool available for free to the community!
bray
PostPosted: Mar 03, 2008 - 09:27 PM
Newbie
Yes...it should be something like that. Smile
If you are not sure you can connect pin 2 and pin 3 on com connector to get loop back and turn on hex mode in Rx and you'll see exact echo.
Yes...i'm thinking about that...maybe in version 2.0. Wink
bray
PostPosted: Mar 18, 2008 - 09:36 PM
Newbie
BTW: new version is available
Some bugfixes and 10 more macros.
MartinM57
PostPosted: Mar 22, 2008 - 09:52 PM
Resident
Is there a definition of the functions available when scripting?
e.g a PAUSE command would be nice, but I don't know if there is one or not....
Plons
PostPosted: Mar 22, 2008 - 10:43 PM
Hi Bray,
I am using your terminal-program (as you know Wink ), and noticed the following:
I have a virtual com-port, number 9, built with a FT232R. This USB-chip is not bus-powered, but target-powered. When I have an open com-link to it, and turn the target system off, the terminal-program gets stuck.
I realise that it is not very decent Wink to do so, but wanted to let you know it happens. I tried to put this report on http://braypp.googlepages.com/terminal, but I can't find where to put the report.
Cheers
Nard
PS Tested with an old version from 2004, the latest one on your site, and the version before that with "only" 10 macro's. Hyperterminal survives my abusive turn-off while com-link open action.
Dragon broken ? Or problems with the Parallel Port Programmer ? Scroll down on my projects-page http://www.aplomb.nl/TechStuff/TechStuff.html for tips
bray
PostPosted: Sep 18, 2008 - 11:56 AM
Newbie
Hello
offtopic....is there any similar (free?) program for windows mobile/PPC's ?
bray
PostPosted: Sep 19, 2008 - 08:57 AM
Newbie
Ok....no answers. Wink I suppose there is no good free serial terminals for WMPPC's out there. I have plans to make some kind of light version of Terminal.
Any candidats? Wink
"I didn't know it was impossible when I did it."
https://sites.google.com/site/terminalbpp/
hws
PostPosted: May 13, 2009 - 01:40 PM
Wannabe
I found a problem receiving characters with framing errors (wrong parity)
I admit, it has been a 2004'er version Embarassed
I wrote a MODBus driver which ignores characters with wrong parity. (8,E,1 ist the desired configuration)
One sender launches a message of 5 characters, but I only received 2 characters.
BrayTerm as a spy in this connection showed me all 5 characters correctly.
Unsing BrayTerm instead of the real sender, I could receive all 5 characters.
Using a digital scope I realized, that the sender always uses a "1"Bit for Parity.
How deals BrayTerm (newer versions) with received Framing Errors.
- ignoring characters completely
- displaying without any error-hint
- displaying chracter but showing framing error (e.g. different colour on display) ?
hws
