gedex
PostPosted: Apr 04, 2007 - 06:55 AM
Newbie
I've two AVRs (both are Atm8535) for my robot.
I need a fast protocol to communicate between them.
since 10 pins are free on each, i could use TWI (Ten Wire Interface) Very Happy, just to speed up data transfer
since 7 ultrasonics & electric compass are assigned to the slave
It's so confused to implement the handshaking. Is there anyone implemented this before? or is it possible to modify some I2C / TWI routine available here?
clawson
PostPosted: Apr 04, 2007 - 12:09 PM
10k+ Postman
SPI is also a "nice and easy" communcation for a couple of AVRs in close proximity.
rasto_novak
PostPosted: Apr 04, 2007 - 02:28 PM
Newbie
Code:
what fast have to be the protocol ?
gedex
PostPosted: Apr 04, 2007 - 03:48 PM
Newbie
rasto_novak wrote:
Code:
It should be 1 - 2 Mbps.
I've used USART before, since my target board uses 4 MHz crystal, i set baud rate to 9600bps and set U2X to enhance transfer rate. But this setting will give 0.2% error. The data being transfered consists 7 byte & i dont want to lose 1 bit.
Koshchi
PostPosted: Apr 04, 2007 - 05:02 PM
I think that you are misunderstanding what this value means. It does not mean "0.2 % of the time there will be an error". It means that the baud rate is off by 0.2%. This is a very different thing. UARTs are tolerant of baud rate errors up to 2.0%, so 0.2% shouldn't cause you any problems. But for short distances such as this TWI (two wire interface), or SPI might still be a better choice. Or you could use an entire 8 bit port for data and another pin as a strobe/latch signal (and one more pin to indicate direction if you need bi-directional).
Steve A.
wylfwt?
dksmall
PostPosted: Apr 04, 2007 - 05:21 PM
Posting Freak
I've done almost exactly what you're trying to do. First off, with both micros running at the same frequency (4mhz), there is no baudrate error between the 2 micros, so set the UBRR to 1 and run 115.2K. That 8.5% error will only occur if you try to communicate with another device like a PC, that's using standard baudrates and standard frequencies.
Here's the maze runner I did that with http://www.parex.org/parex_autoevent_ma ... azer.shtml
donblake
PostPosted: Apr 04, 2007 - 11:56 PM
Posting Freak
That's not entirely correct. There will be some baud rate error since the two micros are not running at exactly 4 MHz. If they're running on external crystals or resonators, for example, the baud rate error is insignificant. However, if either is running on the internal RC oscillator, the baud rate error can be significant.
Don
dksmall
PostPosted: Apr 05, 2007 - 12:20 AM
Posting Freak
Don
This is true, I was thinking external resonators, since that's what I did.
glitch
PostPosted: Apr 05, 2007 - 12:26 AM
well you won't get that rate with the AVR's TWI hardware, and you certainly won't get there through a bit banged solution either. SPI is probably your bst option here, and the implementation is quite straight forward.
zoomcityzoom
PostPosted: Apr 05, 2007 - 01:04 AM
Posting Freak
I think you were joking about TWI being a 10 wire interface, but if you do have 10 free pins on each micro, why not use a 4 or 8-bit dbi-directional interface between the two? A 4-bit interface shouldn't be too difficult. An 8-bit bi-directional interface with 2 control lines is a bit more challenging. If the 10 free pins include the SPI pins then you could always drop back to that if you decide you don't want to continue working on the parallel interface.
SPI would be easier than TWI, but a parallel interface would be more interesting to implement.
glitch
PostPosted: Apr 05, 2007 - 02:15 AM
Hint, what if that was a binary number?
zoomcityzoom
PostPosted: Apr 05, 2007 - 02:50 AM
Posting Freak
Doh!
theusch
PostPosted: Apr 05, 2007 - 04:51 AM
10k+ Postman
Confused is right. With a summary of above: "It will take some pins on each plus a bunch of stuff to implement a 'fast protocol'", why not do it on one AVR such as Mega640? [I'm guessing that A/D channels are the limiting factor.]
Lee
Jepael
PostPosted: Apr 05, 2007 - 10:00 AM
gedex wrote:
rasto_novak wrote:
Code:
Note that the concept of error in this case is quite relative.
With a 4MHz oscillator, you can only get within 0.2% from exact 9600bps for PC communications, but with a 4MHz oscillator, you can make the two AVRs talk to eachoter with 0% error at least 250kbps, or 500kbps if you use the U2X feature.
The error only comes from the crystals, which should be less than 1000ppm (0.1%). You won't lose any bits, as anything less than 2% mismatch should be ok.
- Jani
Jepael
PostPosted: Apr 05, 2007 - 10:04 AM
Another joke:
There are only 10 kinds of people. Those who understand binary numbers, and those who don't.
Actually I think I've seen this on a T-shirt somewhere or something.
- Jani
RES
PostPosted: Apr 06, 2007 - 05:01 PM
Resident
Jepael wrote:
Another joke:
- Jani
I've got a 100 wheel drive car with 10 rear wheels and 10 front wheels.
Why don't you use USI?
RES - http://www.attiny.com
brberie
PostPosted: Apr 06, 2007 - 09:24 PM
Resident
I'm thinking of a 1000 cylinder 100 wheel drive track with 10 front wheels and 1 only driver!
Dentist has charged me for all my 100000 teeth!
donblake
PostPosted: Apr 08, 2007 - 03:04 AM
Posting Freak
FWIW, I just got slave TWI (I2C) working on a ATTiny2313 using USI. It's based on Atmel's AVR312 Application Note. I ported the code to WINAVR GCC, did some cleanup and fixed several errors. If anyone's interested, I can make it available.
Don
ZachSt
PostPosted: Apr 10, 2007 - 02:22 AM
Newbie
Don
If you could post that, it would be great. I'm working on a similar project now. I have one master microcontroller, which I want to speak to three slave ones separately depending on the address. Right now I use an 8-bit bus, 3 address bits, and 2 control bits for a hand-shake, before realizing that TWI is probably the way to go.
NightSky
PostPosted: Apr 10, 2007 - 07:36 AM
SPI is more along the master/peripheral addressing scheme found in classic microprocessor architecture. You have an SS line which functions as a chip select for each SPI chip hooked to the master. That would allow you to keep your 3 address lines.
TWI is reliable (for me) using the TWI hardware, and questionably reliable with the USI hardware. Atmel is looking into this, I think.
TWI can be quite nice, but you need to put your own message protocol on top of it. TWI gives you the addressing capability of 128 possible addresses using the 7 bit addressing scheme, but certain addresses are reserved. You might want to look at the nxp (www.nxp.com) site for more information on addressing. I'd suggest at a minimum the combination of address/count/command/data with a possible return of count/status/data for each message.
Harvey
