| Author |
Message |
Posted: Feb 14, 2007 - 04:45 AM |
There's a lot of SD/MMC card info around, but most of it's not easy to wade through. This document tells specifically how to wire an SD card to a Butterfly, initialize it, and send commands.
There's no code, and you'll still have to do some research, but hopefully this will throw a little light on what's going on.
Please let me know if you have additions or corrections. |
_________________ Chuck Baird
"It's better to catch the trapeze than test the safety net" -- RPi book
http://www.cbaird.org
Posted: Mar 21, 2007 - 02:44 AM |
Thanks for writing the nice tutorial. I have a couple of questions:
1. I was wondering how do you set the clock to (SPR0, SPR1) be 400 KHz initially ?
2. The sparkfun socket has only one GND (Does this one short pins 3,6 internally) ?
3. What do we do with COM, WP and CD pins ?
thanks,
-sid |
Posted: Mar 21, 2007 - 04:45 AM |
On the ATmega 169 the SPR0 and SPR1 (and SPI2X) bits set the SPI master clock rate at the frequency of the oscillator divided by 2, 4, 8, 16, 32, 64, or 128. To hit a specific frequency would require running your AVR at one of those multiples of the target frequency you want, then setting the bits accordingly.
I checked my Sparkfun socket and pins 3 and 6 are connected together on the breakout board and brought out to GND.
The Com pin goes to the metal housing (case), and the WP (write protect) and CD (card detect) lines go to switches located inside the socket. CD shorts to COM when a card is inserted. WP is supposed to short to COM when the card is not write protected (via its slide switch), but on my breakout board this does not work. It also doesn't work the other way, so either my board is defective (probably) or they didn't wire it up. Anyway, there's a difficult to understand schematic that shows Com, WP, and CD in the lower right hand corner. |
Posted: Mar 21, 2007 - 06:51 PM |
Thanks. I have the IRQ, P9 connected to 10Kohm to supply voltage and the Com, WP, CD left open.
I have a question regarding setting clock to 400 KHz. The AT169 data sheet suggests using CLKPS[0-3] to divide the default clock frequency. However, I need a divider of 20 (8MHz/20 = 400 KHz), but CLKPS divides in powers of 2 (1, 2, 4, 8, ...)
I have posted this on avr-forums. Also, I am trying to get some code working on butterfly with SD card interface. If it works, I would like to attach it to the tutorial ?
-sid |
Posted: Mar 21, 2007 - 06:59 PM |
I guess I don't know why you need to have 400 KHz as the clock rate. The SPI master provides the clock, and if it needed to talk to something rated at 400 KHz, that would be the maximum speed. Anything slower (such as 8MHz/32) would work. Otherwise you can use an appropriate crystal to clock the AVR at less than 8MHz and choose it so that one of the divisors gives you the 400 KHz you want.
It's certainly fine with me for you to post code here. |
Posted: Mar 21, 2007 - 08:41 PM |
I have the following code currently as per the tutorial. However, it does not work with the AVR-Butterfly:
#define SD_PORT PORTE
#define SD_DDR DDRE
#define SD_SPI_CS PE4 //Use PE4 as chip sel
#define SD_SPI_PORT PORTB
#define SD_SPI_DDR DDRB
#define SD_SPI_SS PB0
#define SD_SPI_SCK PB1
#define SD_SPI_MOSI PB2
#define SD_SPI_MISO PB3
void SPI_Init(void) {
uint8 dummy, i;
SBI(SD_SPI_DDR, SD_SPI_SS); // set PB0 as op
SBI(SD_SPI_PORT, SD_SPI_SS); // set PB0 to 1
SBI(SD_SPI_DDR, SD_SPI_SCK);
SBI(SD_SPI_DDR, SD_SPI_MOSI);
CBI(SD_SPI_DDR, SD_SPI_MISO);
SBI(SD_DDR, SD_SPI_CS);
SBI(SD_SPI_PORT, SD_SPI_CS);
SBI(SPCR, MSTR); // Master
CBI(SPCR, CPOL); // CPOL, CPHA = 0, 0 => mode0
CBI(SPCR, CPHA);
CBI(SPCR, SPR0); // Fosc/64 ~ 125 KHz
SBI(SPCR, SPR1);
CBI(SPCR, DORD);
CBI(SPCR, SPIE); // No SPI interrupt enable
SBI(SPCR, SPE); // Write to SPCR
dummy = SPSR;
dummy = SPDR;
char SPI_byte(char c) {
char rcv = 0, i;
SPDR = c;
//while (!(inb(SPSR) & (1<<SPIF)));
loop_until_bit_is_set(SPSR, SPIF);
rcv = SPDR;
i = SPSR;
return rcv;
char SD_Init(void) {
unsigned int i;
char rcv;
SBI(SD_PORT, SD_SPI_CS); //Deselect SD
for (i = 0; i < 10; i++)
rcv = SPI_byte(0xff);
Delay(1);
CBI(SD_PORT, SD_SPI_CS); //Select SD
SPI_byte(0x40);
SPI_byte(0x00);
SPI_byte(0x00);
SPI_byte(0x00);
SPI_byte(0x00);
SPI_byte(0x95);
if((rcv = SPI_byte(0xff)) != 0xff)
break;
return rcv;
main() {
char buf[32], c;
CLKPR = (1<<CLKPCE);
CLKPR = (0<<CLKPS1)|(0<<CLKPS0); //clk = 8MHz
UART_Init();
LCD_Init();
SPI_Init();
c = SD_Init();
if (c == 0x01) {
} else {
sprintf(buf, "%d\n", c);
UART_Puts("fail\n");
UART_Puts(buf);
while(1);
When I run the code above, SD_init returns -1 (255). Not sure if there is something wrong with the code. I have the SD card connected to sparkfun.
-sid |
Posted: Mar 21, 2007 - 11:33 PM |
Actually, I meant working code. This forum isn't really the place to be debugging something. You might want to post this over on the AVR forum to have someone have a look at it. |
Posted: Oct 20, 2007 - 09:23 PM |
| hi..could you please tell me if the same procedure applies to interfacing an sd card to atmega32??? I am finding it really difficult to interface the sd card alone..leave the other peripherals. |
Posted: Oct 21, 2007 - 07:15 PM |
Posted: Jan 16, 2008 - 02:50 PM |
i am working on interfacing an SD card to an ATMEGA32 . This setup needs to be used in a data acquisition system such that a certain parameter needs to be polled and logged every minute, the log being stored onto the SD card. something like one text file for each day containing that day's log for every minute. As i understand it, I have broken this up into 2 steps:
1)the task of acquiring data and storing it as a text file(using an ASCII header to indicate it to be a text file)
2)sending this data into the SD card and storing it in such a way that when used with a PC, the SD card folder contains text files containing a particular days readings for each minute.
please let me know if this can be implemented? if so, what is the easiest method to acheive it?? |
Posted: Jan 16, 2008 - 03:25 PM |
| Not sure how that's immediately relevant to this thread but you might want to say what development language you are using. If it happens to be avr-gcc then a Google for "fatfs" (and a search for that here on Freaks) will be useful. |
Posted: Feb 07, 2008 - 01:32 PM |
I have interfaced an atmega32 to a 1GB SD card(Transcend). I can write and read a single block of data(=512 bytes) successfully. The problem comes when I try to read multiple blocks. No matter what I do, I am getting "CMD18 error". Could you please suggest a feasible solution?
Here's that chunk of code which is causing troubles..
CMD18();
for(i=0;i<50;i++)
if(SPI(0x0FF)==(char)0x00)
usart_puts("CMD18 success!");
goto read_data1;
usart_puts("CMD18 error"); return 0;
read_data1:
and the function CMD18() goes like..
void CMD18(void)
SPI(0x52);
SPI(0x00);
SPI(0x00);
SPI(0x05);
SPI(0x12);
SPI(0x0FF);
Regards |
Posted: Feb 07, 2008 - 04:40 PM |
| This is off the top of my head, and may be completely wrong, but try it with a smaller (~256K) card and see if it works. I have some vague memory of problems (i.e., other requirements) for big cards. |
Posted: Feb 14, 2008 - 11:23 AM |
Chuck, you are the man
I very much recommend your tutorial on using SD card. Real time-saver. Thumbs up! |
Posted: Mar 11, 2008 - 10:49 AM |
Hi All ,
Can any one please post or send me the link where in I can find the basic structure code for Interfacing SD Card with AVR Microcontroller.
Hello Chuck,
Can you please send the code related to the your Tutorial so that I can start testing the SetUp, where I have interfaced 1 GB SanDisk SD Card with ATmega32L.
Thanks a Lot !!
Mandar Bagul. |
Posted: Apr 07, 2008 - 07:17 AM |
Hello Chuck Baird,
Thanks a LOT !! for the posting the tutorial - SD and Butterfly.doc
Its a very handy - easy to implement Document.
after refering your documnet I was able to sucessfully Initilze the 256 MB SD Card.
But, I had issues in initilizing the 1 GB SD card
Is there any timing Issue ?
Thanks once again.
-Mandar Bagul
India |
Posted: Apr 07, 2008 - 07:29 AM |
I think the answer is yes, but I don't know what they are. See the post about 3 or 4 prior to this one.
Please do some searching and looking around, and when you find out the answer to this, post it here. I've kind of moved on to other things myself, but I would also like to know what the issues are.
Thanks. Sorry I don't have the information myself. |
Posted: Apr 08, 2008 - 07:12 AM |
Hello Chuck Baird,
Today, I have tried out interfacing the 1 GB SD Card from Transcend & it work fine !!
Conclusion : The tutorial - SD and Butterfly.doc is valid for 1 GB SD Card from Transcend.
Thanks a Lot once again !!
-Mandar Bagul. |
Posted: Jun 11, 2008 - 06:46 PM |
Maybe I am blind but I cant see any doc file nor link to any tutorial. Can anyone give a link to that tutorial ?
Regards. |
Posted: Jun 11, 2008 - 06:47 PM |
| update: double post |
