abcminiuser
PostPosted: Jan 10, 2007 - 12:41 PM
Moderator
Using the USART with AVR-GCC
Freaks,
I've had this three-quarters finished and sitting on my hard drive since mid-last year, so I decided to finish it and post here for the benefit of others. I'm the first to admit it's not very clearly written, so I may re-write it in the future. Comment away.
This tutorial will focus on setting up the serial USART on the AVR platform. Although other hardware AVR interfaces (eg, USI) can be configured for limited RS-232 serial transmission and reception such alternatives will not be covered.
What is the USART?
The vast majority of devices in the current AVR family lineup contain a USART hardware subsystem. The USART hardware allows the AVR to transmit and receive data serially to and from other devices - such as a computer or another AVR.
The USART transmission system differs to most other digital busses in that it does not utilize a separate pin for the serial clock. An agreed clock rate is preset into both devices, which is then used to sample the Rx/Tx lines at regular intervals. Because of this, the USART requires only three wires for bi-directional communication (Rx, Tx and GND).
The RS-232 Specification
The serial USART is frequently referred to as RS-232, which is a reference to the RS-232 specification which mandates the logic levels and control signals. While the AVR's normal logic levels are about 3-5V, RS-232 communication uses a low of +3V to +25V for a digital '0', and -3V to -25V for a digital '1'.
If the two USART devices are running at AVR logic levels, the Tx and Rx pins can be connected together directly. If the devices are using RS-232 spec. voltages, a level converter is needed.
This tutorial will assume the user is attempting to interface with a computer RS-232 port, which uses the proper RS-232 specification logic levels.
First things first - Setting up the Hardware
To connect your AVR to a computer via the USART port, you will need to add a level converter to your existing circuit. The most common/popular serial level converter is the Maxim MAX232 (datasheet avaliable here). This small and relatively inexpensive IC will convert your AVR's 5V logic levels to 10V RS-232 and vice versa.
Before you can hook up your MAX232, you need to first identify which pins of your AVR are responsible for serial communication. Looking in your AVR's datasheet, you should be able to identify the two serial port pins (named as alternative pin functions TX and RX).
You should wire up your MAX232 to reflect the schematic here. This will enable your AVR's USART hardware to interface with the computer's USART hardware.
Deciding on your AVR's system clock frequency
As mentioned above, the USART does not use an external clock. To allow the two interfaced devices to communicate together, you need to decide on a baud rate for communication. Also due to the timing-critical nature of the USART, your system's clock should be stable and of a known frequency. The AVR's system clock frequency is very important. The USART clock is derived from the system clock, and it is used to sample the Rx line and set the Tx line at precise intervals in order to maintain the communication.
If the system clock cannot be precisely divided down to a "magic" frequency for perfect communications, it will have a percentage error (where a byte fails to be read or written inside designated time frame). System clocks for perfect USART communications should be multiples of 1.8432MHz which when used will give a 0.00% error.
Other frequencies for the main AVR clock can be used, but as the frequency drifts from the "perfect" multiples of 1.8432MHz, the greater the percentage error will be (and thus the less reliable the serial communication will be). It is generally accepted that error percentages of less than +/- 2% are acceptable.
Looking in your AVR's datasheet in the USART section you should see a table of common baud rates, system clocks and error percentages. You should find a combination which suits your project's constraints and has the lowest possible error percentage.
I will be basing the rest of this tutorial on an example setup; a MEGA16 running at 7.3728MHz and a baud rate of 9600bps (bits per second). This combination, because it uses a system clock which is a multiple of the magic 1.8432MHz, has an error percentage of 0.00%).
Initializing the USART
Now you should have selected a baud rate, system clock and have your AVR set up with a RS-232 level converter - you're all set to go! All you need is the firmware to drive it.
First off, you need to enable both the USART's transmission and reception circuitry. For the MEGA16, these are bits named RXEN and TXEN, and they are located in the control register UCSRB. When set, these two bits turn on the serial buffers to allow for serial communications:
Code:
int main (void)
   UCSRB |= (1 << RXEN) | (1 << TXEN); // Turn on the transmission and reception circuitry
Next, we need to tell the AVR what type of serial format we're using. The USART can receive bytes of various sizes (from 5 to 9 bits) but for simplicity's sake we'll use the standard 8-bits (normal byte size for the AVR). Looking again at the MEGA16 datasheet, we can see that the bits responsible for the serial format are named UCSZ0 to UCSZ2, and are located in the USART control register C named UCSRC.
The datasheet very handily gives us a table showing which bits to set for each format. The standard 8-bit format is chosen by setting the UCSZ0 and UCSZ1 bits. Before we write to the UCSRC register however, note a curious peculiarity in our chosen AVR, the MEGA16. To save on register addresses, the UCSRC and UBRRH registers (the latter being explained later in this text) share the same address. To select between the two, you must also write the URSEL bit when writing to UCSRC:
Code:
int main (void)
   UCSRC |= (1 << URSEL) | (1 << UCSZ0) | (1 << UCSZ1); // Use 8-bit character sizes - URSEL bit set to select the UCRSC register
The URSEL bit does not exist in all AVR models; check your chosen AVR's datasheet.
There, we're almost done setting up the USART! The last thing to set for basic serial communications is the baud rate register. This register sets the clock divider for the USART which is used as a timebase to sample the incoming data at the correct frequency. It also gives the timebase for sending data, so it's vital for RS-232 serial communications.
The baud rate register is 16-bit, split into two 8-bit registers as is the case with all 16-bit registers in the AVR device family. To set our baud rate prescaler value, we first need to determine it. Note that the baud rate register value is NOT the same as the baud rate you wish to use - this is a common point of failure amongst those new to the serial subsystem. Instead, the value must be derived from the following formula:
    BaudValue = (((F_CPU / (USART_BAUDRATE * 16))) - 1)
Where F_CPU is your AVR's system clock frequency (in Hz), and USART_BAUDRATE is the desired communication baud rate.
Given my example project using a system clock of 7372800Hz and a baud rate of 9600, our formula gives:
    BaudValue = (((F_CPU / (USART_BAUDRATE * 16UL))) - 1)
    BaudValue = (7372800 / (9600 * 16) - 1)
    BaudValue = (7372800 / 153600 - 1)
    BaudValue = (48 - 1)
    BaudValue = 47
To make our life easier, we can turn this formula into a set of handy macros. F_CPU is automatically defined in AVR-GCC via your makefile, so all that is needed is the baud rate:
Code:
#define USART_BAUDRATE 9600
#define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL))) - 1)
This avoids "magic numbers" (unexplained constants) in our source code, and makes changing the baud rate later on very easy - just change the BAUD_RATE macro value. Now, we need to load this into the baud rate registers, named UBRRH (for the high byte) and UBRRL (for the low byte). This is simple via a simple bitshift to grab the upper eight bits of the BAUD_PRESCALE constant:
Code:
UBRRL = BAUD_PRESCALE; // Load lower 8-bits of the baud rate value into the low byte of the UBRR register
UBRRH = (BAUD_PRESCALE >> 8); // Load upper 8-bits of the baud rate value into the high byte of the UBRR register
Now we're ready to rock and roll!
Sending and receiving data
Once initialized, we're ready to send and receive data. We do this by the special register named UDR - short for "USART I/O Data Register". This is special for two reasons; it behaves differently when it is read or written to, and it is double buffered.
By assigning a byte to the UDR register, that byte is sent out via the AVR's Tx line. This process is automatic - just assign a value and wait for the transmission to complete. We can tell when the transmission is complete by looking at the transmission completion flag inside the USART control registers.
On the MEGA16, the Transmission Complete flag is located in the control register UCSRA, and it is named TXC. Using this information we can construct a simple wait loop which will prevent data from being written to the UDR register until the current transmission is complete:
Code:
UDR = ByteToSend; // Send out the byte value in the variable "ByteToSend"
while ((UCSRA & (1 << TXC)) == 0) {}; // Do nothing until transmission complete flag set
However this is non-optimal. We spend time waiting after each byte which could be better spent performing other tasks - better to check before a transmission to see if the UDR register is ready for data. We can do this by checking the USART Data Register Empty flag instead (called UDRE), also located in the UCSRA control register of the MEGA16:
Code:
while ((UCSRA & (1 << UDRE)) == 0) {}; // Do nothing until UDR is ready for more data to be written to it
This is much better, as now time is only wasted before a transmission if the UDR register is full. After a transmission we can immediately continue program execution while the UDR byte is sent, saving time.
Now we can move on to receiving data. As mentioned before, the UDR register behaves differently between read and write operations. If data is written to it it is sent out via the AVR's Tx pin, however when data is received by the RX pin of the AVR, it may be read out of the UDR register. Before reading the UDR register however, we need to check to see if we have received a byte.
To do this, we can check the USART Receive Complete (RXC) flag to see if it is set. Again, this is located in the UCSRA control register of the MEGA16:
Code:
while ((UCSRA & (1 << RXC)) == 0) {}; // Do nothing until data have been received and is ready to be read from UDR
ReceivedByte = UDR; // Fetch the received byte value into the variable "ReceivedByte"
Putting it all together
Right! Now it's time to put everything together! Let's make a simple program that echoes the received characters back to the computer. First, the basic program structure:
Code:
int main (void)
Next, our USART initializing sequence:
Code:
int main (void)
Now, an infinite loop to contain our echo code:
Code:
int main (void)
   for (;;) // Loop forever
And some echo code to complete our example. We'll add in a local variable "ReceivedByte", which will always hold the last received character from the computer:
Code:
int main (void)
   char ReceivedByte;
      while ((UCSRA & (1 << RXC)) == 0) {}; // Do nothing until data have been recieved and is ready to be read from UDR
      ReceivedByte = UDR; // Fetch the recieved byte value into the variable "ByteReceived"
      UDR = ReceivedByte; // Echo back the received byte back to the computer
And voila, we have a working serial example! Connect to this project via a serial terminal on your computer, using 8-bit, no parity 9600 baud communication settings and it will echo back anything you send to it.
Potential Pitfalls
There are several "gotchas" when dealing with the USART. First, make sure your AVR is running of a reliable, known clock source with a low error percentage at your chosen baud rate. New AVRs default to their internal oscillators until their fuses are changed. The internal RC oscillator is of too low a tolerance for use with the USART without external calibration.
Check your datasheet to check for the locations of the different flags. Different AVRs have the control flags located in different control registers (UCSRA, UCSRB and UCSRC).
Make sure your computer terminal is connected at the exact settings your AVR application is designed for. Different settings will cause corrupt data.
Cross your Rx and Tx wires. Your PC's Rx line should be connected to your AVR's Tx line and vice-versa. This is because the Rx/Tx lines are labeled relative to the device they are marked on.
Some AVRs do not have the URSEL bit to differentiate between the UCSRC and UBRRH registers - check your datasheet.
Advanced serial communication
A more advanced method of serial communication involves the use of the USART interrupts and is not covered here. I may cover it in a later tutorial if so desired.
- Dean Twisted Evil
(C) Dean Camera, 2006. All rights reserved. Not for reproduction on any website other than AVRFreaks.net without prior explicit permission.
 View user's profile Send private message Send e-mail Visit poster's website
knutbr
PostPosted: Jan 10, 2007 - 01:22 PM
I read it rather quickly, and it seems like a good introduction to serial comms! Check out this one though:
RS-232 communication uses a low of +3V to +25V for a digital '1', and -3V to -25V for a digital '0'.
+3V to +25V is used for signalling LOW, shouldn't that be digital '0'....
abcminiuser
PostPosted: Jan 10, 2007 - 01:25 PM
Moderator
Fixed, thanks.
- Dean Twisted Evil
lfmorrison
PostPosted: Jan 10, 2007 - 01:46 PM
Dunno if it's worth mentioning, but a newbie should probably be encouraged to look at the power-on default settings of the USART control registers as noted in the datasheet. (And all the registers they work with for that matter.)
For typical 8N1 asynchronous communications, UCSRC can usually be totally ignored (at least, in every AVR I've ever used) because the appropriate bits are automatically preset whenever the chip powers up or comes out of reset.
ravikiran
PostPosted: Jan 13, 2007 - 03:19 PM
Newbie
hey which software do you use to recieve the data on the comp...hmm and ya UCSRC and UBRR hav the same memory addr..the first bit wil decide which one is to be written ...i tried simulating it in avr studio..its not working ...any suggestions...??
bloody-orc
PostPosted: Jan 13, 2007 - 06:22 PM
Posting Freak
use windows terminal (start-programs-accessories-communications-hyper terminal
microcarl
PostPosted: Jan 14, 2007 - 12:35 AM
BaudValue = 47
The only thing I would like to add is that, unless the microcontroller XTAL1, XTAL2 frequency is one of those "Magic Numbers", the final BaudValue will be a mixed number and be rounded down as, the final value of BaudValue must be an integer - the remainder will be lost.
If an XTAL value is used that produces a value of say, 48.1, the error produced by the trunkation of the fractional part, I.E. 0.1, will produce a Baud rate error just slightly greater then 2%. This error may well work without USART timing issues.
But, an XTAL frequency producing a final BaudValue of say, 48.2 or greater, will produce a BAUD rate timing error of more then 4%, which is outside of the +/-3% error margin specified by Atmel.
Carl W. Livingston, KC5OTL
microcarl@roadrunner.com
It's a fundamental law of nature... All things gravitate toward total chaos!!!
The original Dragon Slayer !
Long live the AVR!!!
hys8312
PostPosted: Jan 17, 2007 - 12:52 AM
Newbie
Arrow
NightLynx
PostPosted: Jan 27, 2007 - 04:48 AM
Rookie
Code:
should actually be
Code:
#define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL))))
took me a few to figure out it was missing a closing )
abcminiuser
PostPosted: Jan 27, 2007 - 05:01 AM
Moderator
Thanks Night'. Actually, it should be:
Code:
As previously stated in the tutorial, I just missed the last part when I copy-pasted it. Fixed now, I've updated the PDF too.
- Dean Twisted Evil
HJHerbert
PostPosted: Feb 18, 2007 - 03:51 AM
Newbie
And if you add the half if the divisor, then the formula will not only truncate , but round up or down
#define BAUD_PRESCALE ((((F_CPU+USART_BAUDRATE * 8UL) / (USART_BAUDRATE * 16UL))) - 1)
theproject
PostPosted: Feb 24, 2007 - 09:24 PM
Newbie
Hi!
I'm not sure if I should post this here but I have a question regarding those capacitors around max232. Do their values have anything to do with the baudrate you are using or are always those values?
If they are a function of the baudrate what is the equation to calculate their capacity?
Thanks a lot.
bloody-orc
PostPosted: Feb 24, 2007 - 09:30 PM
Posting Freak
the capacity is given in the datasheet. it has absolutely nothing to do with BAUD rates nor anything with the serial data...
It's to create 10V for PC USART side and nothing more. read the MAX232 datasheet man!
joakimk
PostPosted: Feb 25, 2007 - 04:57 PM
Newbie
After compiling and writing to the ATmega16, and switching the serial cable to the "RS232 SPARE" connection, I set up a connection in Hyperterminal;
Baud 9600
8 bits, no parity, 2 stop bits
However, when I type text in the terminal, the echo is only exotic ASCII characters, not the a-z 0-9 I'm typing... I've tried 1 stop bit, and also 1.5 - same thing. Any clues as to why this is happening?
Btw, great tutorial, Dean! Smile
clawson
PostPosted: Feb 25, 2007 - 06:15 PM
10k+ Postman
What is the AVR clock source? The fact that you get some response suggests you are close so maybe you're using the internal oscillator and it needs calibrating?
Cliff
joakimk
PostPosted: Feb 25, 2007 - 08:27 PM
Newbie
...maybe you're using the internal oscillator and it needs calibrating?
Yes, I am using the internal oscillator;
Int. RC Osc. 1 MHz; Start-tp time: 6CK + 4ms ...
I tried modifying Dean's C code to run at 1MHz like this:
Code:
#define BAUD_PRESCALE (((1000000 / (USART_BAUDRATE * 16UL))) - 1)
How does one calibrate? Am I calculating the BAUD correctly? I couldn't get the F_CPU macro working, so I hard-coded 1MHz in the above formula...
abcminiuser
PostPosted: Feb 25, 2007 - 09:23 PM
Moderator
Try setting your terminal program for one stop bit, instead of two - that's what my code is expecting.
- Dean Twisted Evil
arlynwhitchurch
PostPosted: Feb 26, 2007 - 09:24 PM
Rookie
I am working 2 projects at the same time, an AVR (presently in an 8535, but that will probably change) and Windows desktop using wxWidgets. The projects talk to each other via RS-232C.
The AVR info in this forum looks very useful. If someone needs help at the other end of the cable, drop me a personal msg. and I will see if anything I have is applicable. It took me a while to get my own desktop program talking correctly on COM1.
I use an SDK500 for my prototyping and the "Spare Serial" port works with a standard cable directly to a desktop/laptop without 'twisting' it. You just have to remember to connect the 2 pins near the switches to D0 and D1. If you need to 'twist' the connections, there is a good place to do it for RX and TX. I use a 4.000 MHZ crystal, so I have to choose my baud rate settings carefully.
Another suggestion relative to serial ports is that it is quite useful to output debug statements to the serial port, but when you declare strings in printf statements, they fill up your data space. You can easily put them into EEPROM with a few simple functions.
I also have some AVR software for LCD displays and debouncing matrices of switches, such as keypads, that utilize timer interrupts to work in the background. PM me if this is something you are interested in.
The only thing more dangerous than a software engineer with a soldering iron is a hardware engineer with a compiler.
Lajon
PostPosted: Feb 26, 2007 - 09:29 PM
Posting Freak
joakimk, 9600 baud with 1MHz clock is not going to work well (-7% error even if the 1MHz was exact). Try 4800 baud or use a higher frequency internal RC oscillator setting. You can also try the U2X bit in the UCSRA register (but reception is more sensitve to errors when using it so this might be less useful when running from the internal oscillator). Note that Dean writes above:
/Lars
berntih
PostPosted: Mar 07, 2007 - 09:04 AM
Newbie
Hi all!
Beeing a newbie to avr's, I've worked a while with serial data-transmission and the dmx-standard (rs 485) on fpga's. Now I'm trying to get it into an AVR..
Will the UDR-register will be empty after one transmission?
Is the data in UDR only being transmitted once?
Is it possible to assign a vector to UDR, or is the UDR a one-byte-protocol?
What I want to do is to send 512bytes in a everlasting
loop (of cource with the possibility to manipulate the register).
Thnx,
- Bernt.
