| Author |
Message |
Posted: Oct 04, 2006 - 09:44 PM |
[Moderator's note: as that thread is sticky now, please
avoid followups here. Rather open your own new thread
instead.]
*** YOU MUST LOG IN TO DOWNLOAD THE SCRIPTS ***
*** DEBUGGING XMEGA's isn't supported on Linux. The protocol is still an Atmel secret.
Now also as a .deb install package ... Read further on below
Guyzz i have succeded in building avr-gcc-4.3.4 w. avr-libc-1.6.8 , and Jörg's latest patches on my Ununtu 10.04
I'm only testing on the latest Ubuntu LTS.
All other version & distro's , are not guaranteed to work/compile. I'll try to help out , and so will the forum i'm sure. But don't demand support if it doesn't work , just ask nicely in the forum
I am enclosing the scripts i use (credits of A. Erasmus) , if they could be of any use
The steps are these:
Read Readme.txt
Then install the packages listed in pre-reqs.txt.
Then....
1: Make sure you are root (blushing) , or use sudo
2: Make a working directory , where you extract the files from the archive.
3: If desired edit the buildavr-no-insight.sh file , to change the prefix .. default is : prefix=/usr/local/avr
4: Make sure that the prefix dir is empty or nonexisting
5: Run : chmod +x *.sh
6: Run : ./getfiles.sh
7: Run : ./get-patches.sh
8: Run : ./buildinsight.sh
9: Run: ./buildavr-no-insight.sh
You just answer yes to the existing directory question in step 9.
When building is done , you might want to free around 500MB of diskspace by removing the sources and binaries used to make avr-gcc.
To do so Run: ./buildavr-cleanup.sh
Note this little script expects the "build prefix" to be /usr/local/avr/
Edit:2
I have an avr user on my Linux-box for doing avr development , i have added this to my .bash_profile in my /home/avr directory , it sets up the path to avr-gcc.
# User specific environment and startup programs
PREFIX=/usr/local/avr
export PREFIX
PATH=$PATH:$HOME/bin:$PREFIX/bin
export PATH
The script builds avr-gcc-4.3.4 w. binutils2.20 and then avr-libc-1.6.8
The script now also automaticly builds avarice-2.10 and avrdude-5.9 , as per request of Jörg.
Note : gcc-4.3.x uses the GMP & MPFR libs , in order to function. So make sure to install the packets mentioned pre-reqs.txt
avr-insight is upgraded to ver 6.8 witch builds ok on 64-bit machines , and it has its own buildscript (buildinsight.sh) , as it takes ages to build.
Use: tar xvzf <filename> to extract it if it's a .tgz file, or unzip if it's a zipfile.
Just ansver yes if any of the scripts says that /usr/local/avr exists (ie. when building insight after gcc or the other way around.
But always delete /usr/local/avr before you are making a total/new rebuild.
Updated the scriptfiles to build binutils and insight without the -Werror flag. This was caused by GCC 4.3.x (on Ubuntu 8.10) being unable to build the targets. And was due to a lot of new warnings being enabled by default.
@20-jun-2009
Upgraded the "old" script building avr-gcc-4.2.2 to build avr-gcc-4.2.4 ... "Jörg did all the patches".
4.2.2 could produce more compact code in some cases.
@14-jul-2009
Upgraded the script to build avr-libc-1.6.7 and avrdude-5.8 , no changes to avr-gcc.
As usual "Jörg & the others" did all the hard work.
@12-aug-2009
Upgraded the avr-gcc-4.2.4 script to build avr-libc-1.6.7 and avrdude-5.8.
Also applied a "Hotfix patch" to binutils , to avoid a relocation error in the AVR25 architecture (tiny85 etc).
Everybody is urged to rebuild their toolchain
@29-0ct-2009
Updated the avr-gcc-4.1.2 binutils 1-17 avr-libc-1.46
script , as it failed in makeinfo.
Moved the updated script to this post
http://www.avrfreaks.net/index.php?name ... 653#632653
@03-Nov-2009
Updated the avr-gcc-4.3.3 script , with an avarice patch , to fix a problem when building with "native" gcc 4.4.1
@01-Dec-2009
Made a Debian/Ubuntu ".deb" install package containing the binaries build with the above 03-Nov-2009 script.
Read more here
http://www.avrfreaks.net/index.php?name ... mp;t=86953
@17-Dec-2009
Updated the ".deb" install package , w. a new avrdude binary , containing a PDI patch. (See .txt file in the download site)
Read more here
@16-Jan-2010
Updated the avr-gcc-4.3.3 script , to build avrdude-5.9
Removed the two "interrim avrdude patches" , as 5.9 should fix that.
All other remains unchanged.
The script still includes the "AVR25 relocation fix" patch , and the avarice patch
@18-Jan-2010
Updated the ".deb" install package (named 16-jan-2010) , w. avrdude-5.9. (See .txt file in the download site)
Read more here
Get the package here.
http://www.wrightflyer.co.uk/avr-gcc/
@26-Jan-2010
Updated the scriptfiles and the ".deb" install package to 26-jan-2010 , Added avrdude-5.10 , all other unchanged.
@25-Feb-2010
Made a "Special Static" version , with the patches from WinAVR-20100110-install.exe , so it should be compatible.
Should be installable on both 32-bit & 64-bit versions.
See http://www.avrfreaks.net/index.php?name ... mp;t=90241
@09-Mar-2010
Updated the avr-gcc script , to build avr-gcc-4.3.4 and binutils-2.20.
Added 2 patches to avr-insight/avr-gdb.
Added a builtins.h file in the builddir , see readme for use
Added a package-versions file , now versions are only maintained in that file.
Added a new "automatic" way to patch binutils , gcc & insight.
Thanx to Jörg the linux (FreeBSD) build , now has the same patches as WinAVR-2010. A big thankyou to Jörg & EW.
Also uploaded as .deb package avr-gcc-4.3.4-avrfreaks-09-mar-2010.deb
@30-apr-2010
Rebuild the 09-mar-2010 packages on Ubuntu 10.04 LTS
This time i have a x64 system , so i build both 32bit (i386) and 64bit x64 packages.
Uploaded as .deb packages here
Only toolchain change is : Updated insight from 6.8 to 6.8-1
@04-jun-2010
Updated buildscript to build avr-insight to 6.8-1
No other changes , and no new .deb's as the 30-apr deb's allready contains that.
/Bingo
Posted: Oct 04, 2006 - 10:28 PM |
This appears to have become an at least occasionally requested item.
Is there any interest of making this thread `sticky'?
(Please stop replying if you see there's an unanimous vote; I'll
have to split the thread otherwise to decouple the `noise' from
the actual content otherwise before making it sticky.) |
_________________ Jörg Wunsch
Please don't send me PMs, use email instead.
Please read the `General information...' article before.
Posted: Oct 05, 2006 - 09:01 AM |
[quote="dl8dtl"]
[/quote]
I think that would be a good idea. In particular, I find the information about patches (and where to get them) very useful. |
Posted: Oct 10, 2006 - 10:52 PM |
I'm a relative newbie to Linux, used SUSE a little. Just today I installed UBUNTU. Looks like it will help me brake that bad Windose and commercial-Linux habit.
Have played around with WINAVR a little and like it. Would like to go to GNU GCC on Linux.
Making this thread sticky has my vote.
Mike |
Posted: Oct 16, 2006 - 06:37 PM |
Just "Touching the date"
/Bingo |
Posted: Nov 01, 2006 - 04:18 PM |
compiling binutils with the your scripts failed for me with the following error message (using a current gentoo box with gcc 4.1.1):
Code:
gcc -DHAVE_CONFIG_H -I. -I../../../source/binutils-2.17/binutils -I. -D_GNU_SOURCE -I. -I../../../source/binutils-2.17/binutils -I../bfd -I../../../source/binutils-2.17/binutils/../bfd -I../../../source/binutils-2.17/binutils/../include -I../../../source/binutils-2.17/binutils/../intl -I../intl -DLOCALEDIR="\"/usr/local/avr/share/locale\"" -Dbin_dummy_emulation=bin_vanilla_emulation -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Werror -g -O2 -c ../../../source/binutils-2.17/binutils/wrcoff.c
cc1: warnings being treated as errors
../../../source/binutils-2.17/binutils/wrcoff.c: In Funktion »coff_start_struct_type«:
../../../source/binutils-2.17/binutils/wrcoff.c:2277: Warnung: berechneter Wert ist unbenutzt
make[4]: *** [wrcoff.o] Fehler 1
make[4]: Leaving directory `/usr/local/avr/build/binutils-2.17/binutils'
make[3]: *** [all-recursive] Fehler 1
make[3]: Leaving directory `/usr/local/avr/build/binutils-2.17/binutils'
make[2]: *** [all] Fehler 2
make[2]: Leaving directory `/usr/local/avr/build/binutils-2.17/binutils'
make[1]: *** [all-binutils] Fehler 2
make[1]: Leaving directory `/usr/local/avr/build/binutils-2.17'
make: *** [all] Fehler 2
(./buildavr-no-insight.sh) binutils build failed
Any idea?
Regards:
Uwe Fechner |
Posted: Nov 01, 2006 - 04:28 PM |
Drop the -Werror. I'm not going to do anything about the COFF patch
anymore, given that AVR-COFF is close to be dead. |
Posted: Dec 28, 2006 - 10:08 PM |
thank you very mutch. Your script run successfully with Mandriva 2005. I made a little remark, it don't run with Mandriva 2007. There are some errors with "binutils build failed" message.
Regards.
Monmon  |
Posted: Jan 03, 2007 - 08:18 PM |
Is there an easy way to drop the -Werror using the script? It fails on a ubuntu 6.10 and I have tried to remove the -Werror but somehow it pops back again...
/Mikael |
Posted: Jan 04, 2007 - 04:22 PM |
> on a ubuntu 6.10 ...
"Is there a way to get rid off these seat belts? They are always in
my way."
The correct solution is not to remove the -Werror but to remove the
warning triggering your problem. Not having Ubuntu Linux, and you not
quoting it, I can only guess, but I assume it's:
wrcoff.c: In function 'coff_start_struct_type':
wrcoff.c:2277: warning: value computed is not used
FreeBSD's CVS version recently also switched to GCC 4.x, and thus also
stumbled across that one.
I have just updated the COFF patch for this in my FreeBSD port. The
solution was much simpler than your attempt to get rid of the -Werror:
a "(void)" cast had to be placed before a function call that returned
a value that was not used. (Upon thinking of it, I'm asking myself
whether ignoring the return value is actually the right thing to do,
but at least, it's been that way all the time, and I don't really see
the Big Picture of all this anymore after that many years.)
I also updated the ATmega256x patch in binutils to get rid of that
annoying "operation is dangerous with linker stubs" warning that was
triggered by large C switch() statements. In a discussion with Björn
Haase, we agreed that this was a regression (it wasn't really
dangerous in the switch() situation anyway), and also not all that
useful as Björn initially believed, as there are many more other ways
to shoot into your feet with the linker stubs which cannot be warned
about anyway. So that warning is gone now. (This matches the patch
Eric is using for his most recent WinAVR.) |
Posted: Jan 04, 2007 - 07:25 PM |
Thanks Jörg!
The void cast did the trick in Ubuntu 6.10 as well.
/Mikael |
Posted: Mar 29, 2007 - 07:12 PM |
This script worked flawlessly on Arch linux.
Any hints on how build avr-insight, and/or avr-gdb?
Sam
EDIT
I am sorry, that didn't really follow http://www.catb.org/~esr/faqs/smart-questions.html
What I should say is that I have a difficult time determining what the latest stable package is. Right now I am building Insight 6.6.
Code:
./configure --prefix=/home/swinchen/opt/avr-insight --target=avr
I am just not sure if I will run into any problems with this version.
Thanks Again,
Sam |
Posted: Apr 07, 2007 - 09:49 PM |
Would it be a problem, for the purpose of consistency, to alter this script to install in the gcc directory (/usr/lib/gcc/gcc-4.1 not sure) along with the i486 target and the arm-elf target?
outer_space |
Posted: Apr 10, 2007 - 10:43 AM |
outer_space
Maybe like this ??
the prefix , is pointing to the final "Install dir"
/Bingo |
Posted: Apr 10, 2007 - 05:47 PM |
| I mean to suggest altering the script to make it consistent with native and arm prefixes so all three end up in the same spot (for everybody) |
Posted: Apr 10, 2007 - 05:56 PM |
I seem to recall having read that once upon a time the /usr/local/avr prefix was chosen so that it would be a simple matter of blowing away the entire directory to get rid of *everything* AVR-related from the filesystem without worrying about:
1) Accidentally removing anything non-AVR-related in the same operation
2) Accidentally losing track of some AVR components and orphaning them
I'm sure there are better ways to accomplish both of these tasks nowadays though. |
Posted: Apr 10, 2007 - 09:20 PM |
Only if you are carefully tracking the files you did install.
That's where the package management systems of the various Unix
systems come into the game. If you are installing something
outside of these package managers, you have to track that
yourself.
Each of the tools should also come with a Makefile target
"make uninstall", but I wouldn't hold my breath to see whether
they are really removing everything (including perhaps empty
directories they once created): these targets probably belong
to the lesser tested features even if they come "for free"
along with autoconf/automake. |
Posted: Apr 21, 2007 - 12:07 PM |
If somenone wants to build packages for installation using the debian packaging system, I wrote a mini how-to:
http://blog.coldtobi.de/index.php?op=Vi ... p;blogId=1
Enjoy!
(The patches are also filed against the debian packages, for your reference, these are the bug numbers:
#420061 #416924 ) |
Posted: May 15, 2007 - 09:16 PM |
Just touching the date , to indicate the new avr-libc-1.4.6 build
/Bingo |
Posted: Jun 06, 2007 - 05:49 PM |
I change my PC and now I installed Ubuntu 7.04. The script work perfectly with my old PC and Mandrake 2005 (not with 2007).
AVR-GCC package download don't work on tiny45. Then I want compile this version and patches (tiny45) but ./configure indicate : "C compiler cannot create executables". I try different options but there is always this error .
Thank for your help and for all Ubuntu users.
Monmon.
(Celeron 2500 + Ubuntu 7.04 + Tiny45 + Kontrollerlab) |
