| Author |
Message |
Posted: Apr 22, 2006 - 02:26 PM |
The following text is a slightly reformatted version of a post made by Eric quite a while ago. It has been referred to by so many users (it's now the post for bit-manipulations), and has helped so many that I have reposted it here so it is more easily found.
Programming 101 - By Eric Weddington
To really understand what's going, it's best to learn C languages bit operators and about truth tables.
| bit OR
& bit AND
~ bit NOT
^ bit EXLUSIVE OR (XOR)
<< bit LEFT SHIFT
>> bit RIGHT SHIFT
These operators work on bits and not logical values. Take two 8 bit bytes, combine with any of these operators, and you will get another 8 bit byte according to the operator's function. These operators work on the individual bits inside the byte.
A truth table helps to explain each operation. In a truth table, a 1 bit stands for true, and a 0 stands for false.
The OR operation truth table:
0 OR 0 = 0
0 OR 1 = 1
1 OR 0 = 1
1 OR 1 = 1
The AND operation truth table:
0 AND 0 = 0
0 AND 1 = 0
1 AND 0 = 0
1 AND 1 = 1
The XOR operation truth table:
0 XOR 0 = 0
0 XOR 1 = 1
1 XOR 0 = 1
1 XOR 1 = 0
The NOT operator inverts the sense of the bit, so a 1 becomes a 0, and a 0 becomes a 1.
So let's say I have a byte foo that is initialized to 0:
Code:
unsigned char foo = 0;
To set bit 0 in foo and then store the result back into foo:
Code:
foo = foo | 0x01;
The OR operation is used between the variable that we want to change and a constant which is called a BIT MASK or simply the MASK. The mask is used to identify the bit that we want changed.
Remember that we write the constants in hexadecimal because it's shorter than writing it in binary. It is assumed that the reader knows how to convert back and forth between hex and binary.
Usually, though the statement is made shorter in real programming practice to take advantage of C's compound assignment:
Code:
foo |= 0x01;
This is equivalent to the statement above.
To clear bit 0 in foo requires 2 bit operators:
Code:
foo = foo & ~0x01;
This uses the AND operator and the NOT operator. Why do we use the NOT operator? Most programmers find it easier to specify a mask wherein the bit that they are interested in changing, is set. However, this kind of mask can only be used in setting a bit (using the OR operator). To clear a bit, the mask must be inverted and then ANDed with the variable in question. It is up to the reader to do the math to show why this works in clearing the desired bit.
Again, the statement is made shorter with a compound assignment:
Code:
foo &= ~0x01;
To see if a bit is set or clear just requires the AND operator, but with no assignment. To see if bit 7 is set in the variable foo:
Code:
if(foo & 0x80)
The condition will be zero if the bit is clear, and the condition will be non-zero if the bit is set. NOTE! The condition will be NON-ZERO when the bit is set. But the condition will not NECESSARILY BE ONE. It is left to the reader to calculate the value of the condition to understand why this is the case.
There is another useful tool that is not often seen, and that is when you want to flip a bit, but you don't know and you don't care what state the bit is currently in. Then you would use the XOR operator:
Code:
foo = foo ^ 0x01;
Or the shorter statement:
Code:
foo ^= 0x01;
A lot of times the bit mask is built up dynamically in other statements and stored in a variable to be used in the assignment statement:
Code:
foo |= bar;
Sometimes, a programmer wants to specify the bit NUMBER that they want to change and not the bit MASK. The bit number always starts at 0 and increases by 1 for each bit. An 8 bit byte has bit numbers 0-7 inclusive. The way to build a bit mask with only a bit number is to LEFT SHIFT a bit by the bit number. To build a bit mask that has bit number 2 set:
Code:
(0x01 << 2)
To build a bit mask that has bit number 7 set:
Code:
(0x01 << 7)
To build a bit mask that has bit number 0 set:
Code:
(0x01 << 0)
Which ends up shifting the constant 0 bytes to the left, leaving it at 0x01.
MACROS
Because there are a number of programmers who don't seem to have a familiarity with bit flipping (because they weren't taught it at school, or they don't need to know it because of working on PCs), most programmers usually write macros for all of these operations. Also, it provides a fast way of understanding what is happening when reading the code, or it provides additional functionality.
Below is a set of macros that works with ANSI C to do bit operations:
Code:
#define bit_get(p,m) ((p) & (m))
#define bit_set(p,m) ((p) |= (m))
#define bit_clear(p,m) ((p) &= ~(m))
#define bit_flip(p,m) ((p) ^= (m))
#define bit_write(c,p,m) (c ? bit_set(p,m) : bit_clear(p,m))
#define BIT(x) (0x01 << (x))
#define LONGBIT(x) ((unsigned long)0x00000001 << (x))
To set a bit:
Code:
bit_set(foo, 0x01);
To set bit number 5:
Code:
bit_set(foo, BIT(5));
To clear bit number 6 with a bit mask:
Code:
bit_clear(foo, 0x40);
To flip bit number 0:
Code:
bit_flip(foo, BIT(0));
To check bit number 3:
Code:
if(bit_get(foo, BIT(3)))
To set or clear a bit based on bit number 4:
Code:
if(bit_get(foo, BIT(4)))
bit_set(bar, BIT(0));
bit_clear(bar, BIT(0));
To do it with a macro:
Code:
bit_write(bit_get(foo, BIT(4)), bar, BIT(0));
If you are using an unsigned long (32 bit) variable foo, and have to change a bit, use the macro LONGBIT which creates un unsigned long mask. Otherwise, using the BIT() macro, the compiler will truncate the value to 16-bits.[/list] |
Posted: Apr 22, 2006 - 02:59 PM |
Posted: May 04, 2006 - 10:58 PM |
this is also touched on in "AVR035: Efficient C Coding for AVR" http://www.atmel.com/dyn/resources/prod_documents/doc1497.pdf
I based a few macros off of that app note, and created avr035.h:
Code:
#ifndef _AVR035_H_
#define _AVR035_H_
// from AVR035: Efficient C Coding for AVR
#define SETBIT(ADDRESS,BIT) (ADDRESS |= (1<<BIT))
#define CLEARBIT(ADDRESS,BIT) (ADDRESS &= ~(1<<BIT))
#define FLIPBIT(ADDRESS,BIT) (ADDRESS ^= (1<<BIT))
#define CHECKBIT(ADDRESS,BIT) (ADDRESS & (1<<BIT))
#define SETBITMASK(x,y) (x |= (y))
#define CLEARBITMASK(x,y) (x &= (~y))
#define FLIPBITMASK(x,y) (x ^= (y))
#define CHECKBITMASK(x,y) (x & (y))
#endif
Posted: May 05, 2006 - 06:30 AM |
A recent thread had a very nice solution which extends on the basic bit-manipulation macros. IIRC it went something along the lines of:
Defines:
Code:
#ifndef _AVR035_H_
#define _AVR035_H_
#define VARFROMCOMB(x, y) x
#define BITFROMCOMB(x, y) y
#define C_SETBIT(comb) SETBIT(VARFROMCOMB(comb), BITFROMCOMB(comb))
#define C_CLEARBIT(comb) CLEARBIT(VARFROMCOMB(comb), BITFROMCOMB(comb))
#define C_FLIPBIT(comb) FLIPBIT(VARFROMCOMB(comb), BITFROMCOMB(comb))
#define C_CHECKBIT(comb) CHECKBIT(VARFROMCOMB(comb), BITFROMCOMB(comb))
#endif
Use:
Code:
#define Status_LED PORTA, 3
C_SETBIT(Status_LED);
C_CLEARBIT(Status_LED);
- Dean  |
Posted: Mar 19, 2007 - 03:37 PM |
As an additional item to check if a bit is clear:
Code:
if(~(foo) & 0x80)
_________________ Ben
-Using IAR (& ocasionally CodeVision)
0.7734
1101111011000000110111101101
Posted: Mar 20, 2007 - 02:49 AM |
Code:
if(~(foo) & 0x80)
My 1st choice would be for the following which, IMHO, is easier to "read":
Code:
if ( ( foo & 0x80 ) == 0 )
should result in the same compiler generated code.
Don |
Posted: Mar 24, 2007 - 01:37 PM |
With regards to the above i'd use
if(!CHECKBITMASK(foo,0x80))
or
if(!CHECKBIT(foo,7))
But i agree Don's code is more readable
/Bingo |
Posted: May 11, 2007 - 11:01 AM |
Another approach:
I like it to access bit variables like any other variables and then I can write:
if(i == 1)
if(i == 0)
i = 0;
i = 1;
which looks easy readable for me.
This can easy be done by casting a portbit as a member of a bit field.
On the attachment there is the definition of the macro SBIT.
Following an example code:
Code:
#include <io.h>
#include "sbit.h"
#define KEY0 SBIT( PINB, 0 )
#define KEY0_PULLUP SBIT( PORTB, 0 )
#define LED0 SBIT( PORTB, 1 )
#define LED0_DDR SBIT( DDRB, 1 )
int main( void )
LED0_DDR = 1; // output
KEY0_PULLUP = 1; // pull up on
for(;;){
if( KEY0 == 0 ) // if key pressed (low)
LED0 = 0; // LED on (low)
LED0 = 1; // LED off (high)
Naturally this macro can also be used for internal flag variables, not only for IO registers.
Peter |
Posted: Jun 28, 2007 - 02:50 PM |
Code:
TCCR1B |= (1 << CS10);
You might want to explain what this means. I didn't realize you could actually left shift a bit to a specific place using this actual name of the bit. It drove me crazy because the timer tutorial was directing me here and your tutorial makes no mention of this. |
Posted: Jun 28, 2007 - 03:18 PM |
That means, that nr 1 is shifted left as many times as it is needed to reach bit named CS10. Where does the compiler know that CS10 is that? well you give him the AVR's name and it's smart enough to know such things thanks to some smart programmers on the GCC side  |
Posted: Jun 28, 2007 - 03:44 PM |
I think this tutorial is trying to be as generic as possible. Not all the AVR C compilers have all the bit names defined in the header files for each AVR part so
Code:
won't necessarily work on all compilers.
There's no "magic" to it anyway, a typical part definition file that does include the bit positions simply has something like (for mega16):
Code:
#define CS10 0
#define CS11 1
#define CS12 2
#define WGM12 3
#define WGM13 4
#define ICES1 6
#define ICNC1 7
For those C compilers that don't have the bit definitions in their .h collection the AVR Studio file \Program Files\Atmel\AVR Tools\AvrStudio4\xmlconvert.exe will probably prove useful to generate .h files from Atmel's own XML part definition files:
Code:
C:\Program Files\Atmel\AVR Tools\AvrStudio4>xmlconvert
xmlconvert: No source file specified
Usage: xmlconvert [-f output-format] [-o outdir] [-1nbclV] infile ...
Output formats: a[vrasm] | g[cc] | i[ar] | c[c] (generic c)
Options:
-1 = Don't generate AVRASM2 #pragma's
-n = Don't warn about bad names
-b = use DISPLAY_BITS attribute to limit bit definitions
-c = Add some definitions for compatibility with old files
-l = Produce linker file (IAR only)
-q = Allow linked register quadruple (32-bit)
-V = print xmlconvert version number
Cliff |
Posted: Jun 29, 2007 - 02:52 AM |
Thanks all; I'm going to use most of the above for next yr's class. And another lesson you just taught. Show Dons, BenG, and then Bingos to show writing style and how they accomplish the same thing.
I couldn’t write (copy) the curriculum without this site.
Thanks for the help and making the world a better place,
John |
_________________ Resistance is futile…… You will be compiled!
Posted: Jun 29, 2007 - 05:32 PM |
Code:
Code:
#define CS10 0
#define CS11 1
#define CS12 2
#define WGM12 3
#define WGM13 4
#define ICES1 6
#define ICNC1 7
Where are the definitions in AVR GCC? I am guessing in the IO header file or each header has every single part defined for only the related registers. |
Posted: Jun 29, 2007 - 05:34 PM |
Yup in GCC all your programs include <avr/io.h> and your Makefile will define a MCU=. As a consequence of these two things it will lead to io.h choosing to pull in one of the io????.h files in \winavr\avr\include\avr\
Cliff |
Posted: Jun 29, 2007 - 05:53 PM |
Cliff
I am guessing Avr Studio is handling the making the Makefile when I compile my program. Oddly enough I don't even think I defined the correct MCU when I first created the project. I defined it as a Mega 168 and only figured out that it was a Mega 48 when my Dragon complained that the parts didn't match up. Is this because the parts are in the same data sheet? |
Posted: Jun 29, 2007 - 06:03 PM |
| There's several MAJOR difference between 48 and 168. For example one uses RJMPs for its interrupt vectors and one uses JMPs (because the entire memory is no longer reachable with an RJMP). Far more worryingly the 168 has 1K of SRAM while the 48 has 512 bytes. So the RAMEND used to initialise the stack pointer will be different between the two. I'm therefore astonished that you found that code built for a 168 worked in a 48 !?! |
Posted: Jun 29, 2007 - 06:51 PM |
Well the code I wrote was only five lines long and didn't use interrupts. Though I might want to make sure that the I actually did program for the 168. I don't have access to the computer I wrote the code in at the moment. |
Posted: Jul 03, 2007 - 08:03 PM |
Another thing I've just learned, you can toggle the PORTxn pins by writhing to the PINxn register.
So instead of toggling the bits with the XOR operator, you can write to the PINxn address.
Do not know if the compiler optimization already does that? |
Posted: Jul 03, 2007 - 08:42 PM |
| But that only works on the recent AVRs, not all of them. |
Posted: Nov 06, 2007 - 08:19 PM |
Code:
if(~(foo) & 0x80)
Code:
Don
and another way...
Code:
if (!( foo & 0x80 ))
