Post new topic   This topic is locked: you cannot edit posts or make replies.
jimbotko
PostPosted: Jan 27, 2006 - 10:01 AM
Wannabe
I have a very repeatable problem with AVR Studio 4.12b462 and WinAVR 20060125 where AVR Studio freezes during the compilation process whenever eeprom.h is included. Note: this appears to be AVR Studio related since it does NOT hang when compiled with the same makefile from a command lind.
Generate a new GCC proejct in AVR studio for any micro (I tried the attiny45 and atmega8) and try the following source:
Code:
#include <avr/eeprom.h>
int main (void)
   while (1) ;
   return 0;
The compilation process will hang at this point:
Code:
avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" --change-section-lma .eeprom=0 -0 ihex asdf.elf asdf.eep
If you comment-out the #include <avr/eeprom.h> it will compile just fine. The project appears to be corrupted if you try and re-open it after force-quitting AVR Studio during the hang, but deleting the "default" configuration directory fixes that.
If I compile using the AVR Studio generated makefile in Programmer's Notepad, it compiles just fine. So this seems to be some AVR Studio related error...
I apologize if this is a known bug, I just ran in to this after 5 minutes of trying the new WinAVR and AVR Studio. Sad
clawson
PostPosted: Jan 27, 2006 - 11:08 AM
10k+ Postman
Yup, I see exactly the same lockup. I found that the solution could be narrowed down to not deleting the ENTIRE default build directory but just the target.o.d in the default\dep directory. Rather curiously, in my case, this consists of:
Code:
eric.o: ../eric.c C:/WinAVR/avr/include/avr/io.h \
  C:/WinAVR/avr/include/avr/sfr_defs.h C:/WinAVR/avr/include/inttypes.h \
  C:/WinAVR/avr/include/stdint.h C:/WinAVR/avr/include/avr/iom16.h \
  C:/WinAVR/avr/include/avr/portpins.h \
  C:/WinAVR/avr/include/avr/version.h C:/WinAVR/avr/include/avr/eeprom.h \
  C:\WinAVR\bin/../lib/gcc/avr/3.4.5/include/stddef.h
C:/WinAVR/avr/include/avr/io.h:
C:/WinAVR/avr/include/avr/sfr_defs.h:
C:/WinAVR/avr/include/inttypes.h:
C:/WinAVR/avr/include/stdint.h:
C:/WinAVR/avr/include/avr/iom16.h:
C:/WinAVR/avr/include/avr/portpins.h:
C:/WinAVR/avr/include/avr/version.h:
C:/WinAVR/avr/include/avr/eeprom.h:
C:\WinAVR\bin/../lib/gcc/avr/3.4.5/include/stddef.h:
In this all path separators are the Unix style forward-slash APART from those two back slashes on the lines that reference stddef.h - if I edit them to be forward slashes the AVR Studio no longer locks up when the project is loaded.
So there seem to be two faults here - one is the inclusion of the wrong slashes in the first place which is presumably something introduced by the new WinAVR but the other is clearly a fault in Studio - it should be abe to handle both Windows and Unix style directory separators.
Cliff
torleifs
PostPosted: Jan 27, 2006 - 11:27 AM
Thanks for reporting this problem!
And thanks for narrowing it down to the handling of dependencies.
This is bug #4260 in our bugtracking system.
regards,
Torleif
jimbotko
PostPosted: Jan 27, 2006 - 08:05 PM
Wannabe
Cliff
Nice work. Looks like it's back to KamAVR again for me. Smile
torleifs
PostPosted: Jan 29, 2006 - 11:35 AM
Ok, the problem has been fixed.
I had not considered forward slashes as path separators when processing the dependency files and this resulted in an infinite loop.
I am sorry for the trouble this has caused.
regards,
Torleif
jimbotko
PostPosted: Jan 29, 2006 - 01:50 PM
Wannabe
regards,
Torleif
Great! So is there a beta version of AVR Studio lurking somewhere with this fix? Smile
dl8dtl
PostPosted: Jan 29, 2006 - 02:29 PM
separators when processing the dependency files ...
Just for the record, they have always been valid path name separators
in MS Windows internally (i.e. on the syscall level), and even in
MS-DOS dating back to at least MS-DOS version 3.x (probably even 2.x).
The reason they adopted two path name separators when incorporating
the Unix-style file system hierarchy was mainly their command shell
(COMMAND.COM, now CMD.EXE) inherited the forward slash as an option
separator from its anchestor CP/M, so that character wasn't available
on the command level for that purpose. Well, in theory, there was
even a syscall to change the option delimiter from slash to dash (so
to be fully unix compatible), but I think this feature has never been
seriously implemented in any program.
The "drive" letters are another inheritance from CP/M, btw...
To make the long story short: when programming MS Windows, you should
always be aware that both '/' and '\\' are valid path name separators.
Jörg Wunsch
Please read the `General information...' article before.
 View user's profile Send private message Send e-mail Visit poster's website
Colin
PostPosted: Jan 30, 2006 - 01:07 AM
Wannabe
Torleif -
I also noticed that the memory usage report has disappeared with the new WinAVR.
I would post this in the Studio forum, but thought best to stay in this thread.
Colin
abcminiuser
PostPosted: Jan 30, 2006 - 01:25 AM
Moderator
Colin, that's because the new WinAvr's memory usage script has been incorperated into one of the binutils. You could either reimplement the new commands youself via a custom AVRStudio makefile (or at least force AVRStudio to run custom Makefile commands) - see the new makefile template. Otherwise i'm sure Torleif can implement that extreamly easily just by changing WinAVR's internal makefile.
- Dean Twisted Evil
Atmel Studio 6.1 is now released, grab it here.
Report AS6/ASF bugs here.
jaguarondi
PostPosted: Jan 31, 2006 - 05:00 PM
Wannabe
regards,
Torleif
Would greatly benefit from this too, a couple of my projects are freezing. Confused
For the size report, a quick fix I found waiting for the next (and soon Wink avrstudio version is to copy avr-mem.sh into winavr/bin. You can get it from your previous winavr installation or better use the latest version which should have a download link somewhere in these forums.
mpthompson
PostPosted: Jan 31, 2006 - 06:48 PM
Wannabe
I'm running into this bug compiling for the ATtiny45. I'm very happy to hear it's been fixed, but I'm a bit confused as to whether the fix is available for download somewhere. Any further details regarding how to get this fix would be most helpful.
-Mike
torleifs
PostPosted: Feb 01, 2006 - 12:49 PM
The fix is now available from this location:
http://www.atmel.no/beta_ware/
Release notes:
This upgrade fixes the following problems that the plug-in had with the WinAVR 20060125 release.
-Infinite loop when determining dependencies. (After completing a build.)
-No reporting of memory usage.
Torleif
jaguarondi
PostPosted: Feb 01, 2006 - 03:15 PM
Wannabe
Thank you very much Torleifs for your kind and fast reaction to this. The update works for me. I'm back on track now ...
mpthompson
PostPosted: Feb 01, 2006 - 05:27 PM
Wannabe
Very much appreciated. Thank you.
-Mike
Colin
PostPosted: Feb 01, 2006 - 11:36 PM
Wannabe
Torleif -
Thanks for getting the update out so quickly. Very Happy
Unfortunately, this bug has re-surfaced: Sad
In a GCC project, set include file paths to a path with spaces in the name, eg "c:\program files\...."
Include files are correctly found by the compiler, but where the file names show up in the 'External Dependencies' tree, the path is corrupted. Double clicking the filename does not bring the file up in the editor.
Colin
torleifs
PostPosted: Feb 02, 2006 - 12:09 PM
It seems I may have been a bit too fast then. Sad
When you write 'corrupted' do you mean that the spaces are preceded by a '\'?
That is what I observe at least.
Unfortunately, I don't have time to look into it right now, so it might be a while before a fix is distributed.
Torleif
Colin
PostPosted: Feb 02, 2006 - 07:45 PM
Wannabe
No worries. We appreciate the quick response to the WinAVR changes.
That's exactly it.
Colin
**Edit:**
I just found another small bug for you. Surprised
On saving the project options, 'UL' is appended to the frequency (new feature). Now go back into the options, and change anything. When saving, an additional 'UL' is appended ('ULUL'). And so on....
jaguarondi
PostPosted: Feb 03, 2006 - 04:37 PM
Wannabe
I reported the UL problem some while ago to Atmel and they were already avare of it. Should be there in the next version or Service Pack I guess.
jheissjr
PostPosted: Feb 26, 2006 - 01:18 AM
I am still having a problem with AVRStudio freezing. From what others are saying, the problem seems to be fixed with version 20060125 and Service Pack 4.12 so I assume the problem is with me.
Without adding avrlib include folders, I am able to comile without freezing(with the exprected cannot find file.h error) . It is when I include avrlib folders that it freezes while compiling. I do not see eeprom.h listed in the .o.h file so I am not sure what is causing the problem. Suggestions / Things to try are very welcome Wink
dl8dtl
PostPosted: Feb 26, 2006 - 02:18 PM
> with me.
No, you need the beta version from the Norway beta site.
Jörg Wunsch
