| Author |
Message |
Posted: Aug 09, 2005 - 10:39 AM |
I'm writing a bootloader (not interrupt driven) and need more program space.
I set the flag in the makefile not to generate Interrupts.. It does it, but don't removed the table.
Anyone an idea?
Andreas from Germany |
Posted: Aug 09, 2005 - 11:27 AM |
Moin Andreas,
Try the -nostartfiles flag, as in:
Code:
CFLAGS = -g -O1 -mmcu=$(TARGET) -nostartfiles ...
Please note that you will have to manually clear and initialize your static variables after you add it, meaning more chances to save flash!
-John |
Posted: Aug 09, 2005 - 12:25 PM |
Hmm... The Problem is, I've no stack now.... It's a bit difficult to programm without stack...
Andreas |
Posted: Aug 09, 2005 - 03:14 PM |
| Someone please correct me if I am wrong. The stack pointer is just another register or register pair: just set it or them to the last RAM address, RAMEND, before you use the stack. |
Posted: Aug 09, 2005 - 03:31 PM |
I also believe that you won't have access to the 'zero' register.
R1 is preset to have a value of zero as part of the startup routine. Gcc then assumes that R1 will always be zero from then on. If you skip the startup sections, then you might end up with a couple of surprises if you try to make use of the numeric constant 'zero' in your code. So, you might also have to include special provisions to ensure that R1 is zero before you do anything else in your main() function. |
Posted: Aug 09, 2005 - 05:43 PM |
| I forgot about the zero register -- thank you for pointing that out! You can clear R1 in your start up code as you prepare to zero all the static variables (the bss segment). The cautiously paranoid might also have main() periodically clear R1 to address the nagging worry: What if zero accidently becomes non-zero? |
Posted: Aug 10, 2005 - 05:13 AM |
Location: Bangalore ,Karnataka, INDIA Permanant-Howrah,West Bengal,INDIA
I have found a HACK to prevent the stack problem also just use:
Code:
COMMON_FLAGS = -mmcu=$(CPU) -nostartfiles -minit-stack=0x4FF
Where 0x4FF is the end of the SRAM address to init the Stack pointer.
Also if you want to intialize some variables before main just do by:
Code:
void initvars(void) __attribute__ ((section(".init0")));
void initvars(void)
//Your custome initialization before Main
But still the IVT remains. I am really not sure How to remove that. |
Posted: Aug 10, 2005 - 08:33 PM |
One way to do this is to use your own linker script.
Copy the appropriate script from
../avr/lib/ldscripts/...
into your source directory.
Look for the .text section for example
.text :
and just before the .text line, place the following :
/DISCARD/ : { *(.vectors); } /* Interrupt vectors */
There may be a 'cleaner' way to do this than to take a copy of the
system linker script and editting it, if so I'd be interested to hear
-- Simon. |
Posted: Aug 10, 2005 - 08:39 PM |
Oops I should have said that you need to tell the linker to actually use this
file when linking your application!!
Use the -T switch to gcc.
-- Simon. |
Posted: Aug 10, 2005 - 09:12 PM |
The idea with adding .vectors to DISCARD is OK, but keep in mind that
the very first entry of .vectors is actually the jump to the program
entry. You might want to replace that by your own jump. As you're
going to use a custom linker script anyway, it should be easy enough
by inventing your own initialization section, and use that in place of
the original .vectors.
.section .myvectors,"ax",@progbits
RJMP __init
__init is the name of the entry point of the section .init0
initialization code. Of course, if you don't need/want the standard
initialization either, feel free to replace whatever parts seem
appropriate from the original crt code. |
_________________ Jörg Wunsch
Please read the `General information...' article before.
Posted: Aug 10, 2005 - 09:29 PM |
If you don't wont to edit the linker script add
Code:
-nostartfiles -nodefaultlibs to LDFLAGS
and the following code to your bootloader module
(assuming you are not using static variables)
Code:
void __jumpMain (void) __attribute__ ((naked)) __attribute__ ((section (".init9")));
void __jumpMain(void)
asm volatile ( ".set __stack, %0" :: "i" (RAMEND) );
asm volatile ( "clr __zero_reg__" ); // r1 set to 0
asm volatile ( "rjmp main"); // jump to main()
Posted: Aug 11, 2005 - 04:05 AM |
There was a little bit of glitch in this:
Code:
I made it to:
Code:
Worked Fine and now from 300 bytes my codesize is 212 bytes only.
Thanks for the help.
Also I just wanted to ask where we can get the info for the avr-gcc flags and the info regarding the Linker Scripts. |
Posted: Aug 11, 2005 - 09:34 AM |
> flags
In the GCC manual and/or info pages. Some important options are also
explained in the avr-libc documentation.
In the linker manual (info pages -- for WinAVR, see the TkInfo
browser). |
Posted: Mar 13, 2006 - 01:29 AM |
I am also designing a bootloader... in this case an I2C bootloader.
So, I also want to discard the IVT generation... I am trying to follow these indications to create a new script file and discard the standard code with something custom... what I am doing is using the /DISCARD/ command to remove the (.vectors) section, but I am returning an error:
C:\WinAVR\bin\..\lib\gcc\avr\3.4.5\..\..\..\..\avr\bin\ld.exe: `__vector_default' referenced in section `.text' of C:/WinAVR/bin/../lib/gcc/avr/3.4.5/../../../../avr/lib/avr5/crtm168.o: defined in discarded section `.vectors' of C:/WinAVR/bin/../lib/gcc/av
The make files looks like this:
Code:
# Makefile for the project i2cboot
## General Flags
PROJECT = i2cboot
MCU = atmega168
TARGET = i2cboot.elf
CC = avr-gcc.exe
## Options common to compile, link and assembly rules
COMMON = -mmcu=$(MCU)
## Compile options common for all C compilation units.
CFLAGS = $(COMMON)
CFLAGS += -Wall -gdwarf-2 -DF_CPU=8000000UL -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
CFLAGS += -MD -MP -MT $(*F).o -MF dep/$(@F).d
## Assembly specific flags
ASMFLAGS = $(COMMON)
ASMFLAGS += -x assembler-with-cpp -Wa,-gdwarf2
## Linker flags
LDFLAGS = $(COMMON)
LDFLAGS += --verbose -Tavr5.x -Wl,-Map=i2cboot.map
## Intel Hex file production flags
HEX_FLASH_FLAGS = -R .eeprom
HEX_EEPROM_FLAGS = -j .eeprom
HEX_EEPROM_FLAGS += --set-section-flags=.eeprom="alloc,load"
HEX_EEPROM_FLAGS += --change-section-lma .eeprom=0
## Objects that must be built in order to link
OBJECTS = main.o init.o
## Objects explicitly added by the user
LINKONLYOBJECTS =
## Build
all: $(TARGET) i2cboot.hex i2cboot.eep i2cboot.lss size
## Compile
main.o: ../main.c
$(CC) $(INCLUDES) $(CFLAGS) -c $<
init.o: ../init.c
##Link
$(TARGET): $(OBJECTS)
$(CC) $(LDFLAGS) $(OBJECTS) $(LINKONLYOBJECTS) $(LIBDIRS) $(LIBS) -o $(TARGET)
%.hex: $(TARGET)
avr-objcopy -O ihex $(HEX_FLASH_FLAGS) $< $@
%.eep: $(TARGET)
avr-objcopy $(HEX_EEPROM_FLAGS) -O ihex $< $@
%.lss: $(TARGET)
avr-objdump -h -S $< > $@
@echo
@avr-size -C --mcu=${MCU} ${TARGET}
## Clean target
.PHONY: clean
clean:
-rm -rf $(OBJECTS) i2cboot.elf dep/* i2cboot.hex i2cboot.eep i2cboot.lss i2cboot.map
## Other dependencies
-include $(shell mkdir dep 2>/dev/null) $(wildcard dep/*)
What am I doing wrong? |
_________________ ---
ARod
Posted: Mar 14, 2006 - 02:53 PM |
I am enclosing my own boot loader make file. This file was auto generated
by the KamAVR and later I modified it to my needs.
Code:
## NOTE: This makefile uses GNU make syntax. ##
## ===== It may not work when called by other make utilities ##
### PROJECT NAME ###############################################################
PROJECT = dk1-boot
## CPU #########################################################################
CPU = atmega8
### SOURCES ####################################################################
OBJ = bootprog.o
## TOOLS #######################################################################
COMPILER = avr-gcc
ASSEMBLER = avr-gcc
LINKER = avr-gcc
ROMIZER = avr-objcopy
DUMPER = avr-objdump
## FLAGS #######################################################################
COMMON_FLAGS = -mmcu=$(CPU) -nostartfiles -nodefaultlibs
COMMON_FLAGS += -Os
COMMON_FLAGS += -mno-interrupts
COMMON_FLAGS += -funsigned-char
COMMON_FLAGS += -funsigned-bitfields
COMMON_FLAGS += -Wall
COMMON_FLAGS += -Wstrict-prototypes
LINK_FLAGS = $(COMMON_FLAGS) -ggdb
COMPILE_FLAGS = $(LINK_FLAGS) -c -DF_CPU=4000000UL
COMPILE_FLAGS += -Wa,-acdhlmns=$(<:.c=.lst)
ASSEMBLE_FLAGS = $(COMMON_FLAGS) -c -I. -x assembler-with-cpp
ASSEMBLE_FLAGS += -Wa,-gstabs,-acdhlmns=$(<:.s=.lst)
FLASH_FLAGS = -j .text
FLASH_FLAGS += -j .data
FLASH_FLAGS += -j .Topseg
ELF_FLAGS = -Wl,-Map=$(PROJECT).map
ELF_FLAGS += -Wl,-section-start=.text=0x1800
ELF_FLAGS += -Wl,-section-start=.Topseg=0x0
ELF_FLAGS += --cref
ELF_FLAGS += -lm
## ACTIONS #####################################################################
COMPILE = $(COMPILER) $(COMPILE_FLAGS)
ASSEMBLE = $(ASSEMBLER) $(ASSEMBLE_FLAGS)
LINK = $(LINKER) $(LINK_FLAGS)
REMOVE = rm -f
SIZE1 = avr-size $(PROJECT).elf
SIZE2 = sh avr-mem.sh $(PROJECT).elf $(CPU)
## BUILD #######################################################################
all: elf flash eep list
$(SIZE1)
$(SIZE2)
rebuild: clean all
clean:
$(REMOVE) $(PROJECT).hex
$(REMOVE) $(PROJECT)_eeprom.hex
$(REMOVE) $(PROJECT).elf
$(REMOVE) $(PROJECT).map
$(REMOVE) $(PROJECT).cof
$(REMOVE) $(PROJECT).lst
$(REMOVE) $(OBJ:.o=.lst)
$(REMOVE) $(OBJ)
eep: $(PROJECT)_eeprom.hex
flash: $(PROJECT).hex
elf: $(PROJECT).elf
list: $(PROJECT).lst
## LINK ########################################################################
$(PROJECT)_eeprom.hex: $(PROJECT).elf
$(ROMIZER) $(EEPROM_FLAGS) -O ihex $(PROJECT).elf $(PROJECT)_eeprom.hex
$(PROJECT).hex: $(PROJECT).elf
$(ROMIZER) $(FLASH_FLAGS) -O ihex $(PROJECT).elf $(PROJECT).hex
$(PROJECT).lst: $(PROJECT).elf
$(DUMPER) -d -S $(PROJECT).elf > $(PROJECT).lst
$(PROJECT).elf: $(OBJ)
$(LINK) $(OBJ) -o $(PROJECT).elf $(ELF_FLAGS)
## COMPILE #####################################################################
%.o : %.c
$(COMPILE) $< -o $@
%.o : %.s
$(ASSEMBLE) $< -o $@
Hope that it is helpful to you.
Boseji |
Posted: Mar 14, 2006 - 04:49 PM |
Hey thanks for sharing!!!
Also I just want to point out that I am using avrStudio4.12 SP2 and the gcc plug-in and all my development is done on it. Also I found that if I hit twice the Rebuild button, the second time the error disappear...
Boseji,
I will look at your Makefile to play with it... what it is interesting is that you don't need to use a modified ldscript version. ( avr5.x)... isn't it? meaning that I won't need to mess up with link scripts.. just the Makefile... awesome! |
ARod
Posted: Mar 15, 2006 - 10:20 PM |
If I compile the code given by Peter Fleury the generated code locates statck initialisation to main() and not in __jumpMain(). So if I for example end __jumpMain with rjmp WinMain and rename main to WinMain there will be no stack initialisation.
Why isn't stack initialisation done in the C-startup code before main?
Olof |
Posted: Mar 16, 2006 - 12:32 PM |
It is, look closely. |
Posted: Mar 16, 2006 - 07:07 PM |
This is the result::
Code:
main.elf: file format elf32-avr
Disassembly of section .text:
00000000 <__jumpMain>:
asm volatile ( ".set __stack, %0" :: "i" (0x55aa) );
0: 11 24 eor r1, r1
2: 00 c0 rjmp .+0 ; 0x4
00000004 <main>:
int main( void )
4: ca ea ldi r28, 0xAA ; 170
6: d5 e5 ldi r29, 0x55 ; 85
8: de bf out 0x3e, r29 ; 62
a: cd bf out 0x3d, r28 ; 61
return 0;
c: 80 e0 ldi r24, 0x00 ; 0
e: 90 e0 ldi r25, 0x00 ; 0
10: 00 c0 rjmp .+0 ; 0x12
00000012 <exit>:
void exit( int a )
for(;;); // Lock forever in a loop.
12: ff cf rjmp .-2 ; 0x12
To me it is pretty clear that main starts at 4h. And that the stack pointer is initialised after 4h.
I appeded the example files used to produce the code.
Best regards
Olof |
Posted: Mar 16, 2006 - 09:57 PM |
Olof,
I just download your zip file, and I found the __stack declaration, also I compile it everything went ok... see the first code line after void __jumpMain(void) declaration. |
ARod
