eric
PostPosted: Nov 05, 2002 - 06:25 PM
Newbie
VC is wrong. GCC is correctly pointing out a syntax error.
phys_audio_out is defined as a 2-dimensional array, or said another way, an array of arrays. When initializing this variable, the data must take on the same type structure of the variable. The data that you have is a 1-dimensional array, which is not the same type as the variable. Change the declaration to below:
#define MAX_OUT 3
#define NUM_AUD_LVLS 2
static const unsigned char phys_audio_out[MAX_OUT][NUM_AUD_LVLS]=
{0x1F, 0x20},
{0x21, 0x12},
{0x13, 0x24}
So now you have phys_audio_out declared as a 3-element array with each element being a 2-element array of constant unsigned character. The data initializer now matches the type.
Eric
