felipemirand
PostPosted: Aug 19, 2012 - 11:55 PM
Newbie
Hi guys!
I've spent more than three weeks trying to make Atmega8 able to "speak" I2C (I have to use a LM75 sensor) but I have no success at all... =(
Can someone help me with an example with two Atmega8 linked by I2C? A Proteus example would also be very good for me too, but, any help will be very useful for me.
I've already visited all foruns on Internet (including Peter Fleury) and nothing... Sad
js
PostPosted: Aug 20, 2012 - 12:27 AM
10k+ Postman
Location: Sydney, Australia (Gum trees, Koalas and Kangaroos, No Edelweiss)
http://www.procyonengineering.com/embedded/avr/avrlib/ download AVRLIB.
If you are using WinAVR-20100110 then there is a TWI (I2C) demo code, in my computer it lives here C:\WinAVR-20100110\doc\avr-libc\examples\twitest
js
PostPosted: Aug 20, 2012 - 05:23 AM
10k+ Postman
There are 70 threads discussing the LM75 here, maybe this one helps?
http://www.avrfreaks.net/index.php?name ... light=lm75
felipemirand
PostPosted: Aug 20, 2012 - 02:09 PM
Newbie
Thanks, JS.
The problem is that I already visited this page and they didn't solve the problem stated on the thread (which is the same as mine).
I'm already using LM74 (SPI) and I made it work perfectly (by the way, I want to share the code here, but I don't know how yet), but, using LM75 (I2C) had become a very hard problem... I made so many things trying to make I2C working on Atmega8 that AVRFreaks is my last hope...
clawson
PostPosted: Aug 20, 2012 - 03:05 PM
10k+ Postman
I'd start by considering what debug techniques you have available. A DSO or a logic analyser would be invaluable. Also, if this particular I2C device is complex then pick something real easy like an EEPROM or an RTC and get the basics of I2C working between the AVR and that (with proven library code such as Fleury). When you have the basics working it firstly rules out a lot of the low level, hardware "unknowns" and also will have given you experience you may put towards debugging what's happening with a more complex device.
Visovian
PostPosted: Aug 20, 2012 - 05:02 PM
Posting Freak
If I understand you have the sensor connected to Avr1 and want to send values from Avr1 to Avr2.
You can use uart, it is much easier in my opinion.
A one-way communication will do (from Avr1 to Avr2), so that you use 2 wires, same as I2c.
If hw uart is not available then use a software one.
Ooh, I gave it up much sooner (Avr as i2c slave).
felipemirand
PostPosted: Aug 20, 2012 - 07:09 PM
Newbie
Yeah, but I can use almost everything on Atmega8 (LCD, USART, SPI) but no deal with I2C... Sad
I spent all that time serching/testing and nothing...
After I make the code, I'll put it here because I don't want anybody facing the same boring problem... Mad
js
PostPosted: Aug 20, 2012 - 11:16 PM
10k+ Postman
So is the problem the I2C/TWI or the LM75? You have a I2C/TWI library which works (I have never used that one but others) so all you need to do is to figure out what the LM75 wants.
And of course the first thing we want to know is if you have the I2C pullup resistors mounted on the board, without them nothing will work.
Also you many want to start with something for which you have working examples like a DS1307 or a I2C memory chip.
winAvr has a demo project
* Simple demo program that talks to a 24Cxx I²C EEPROM using the
* builtin TWI interface of an ATmega device.
Are you using winAvr or the newfangled AS6? Either way I'm sure you have working examples of how to communicate using thw I2C.
felipemirand
PostPosted: Aug 20, 2012 - 11:31 PM
Newbie
Hi, John.
I'm first using Proteus to simulate the codes. I'm using Atmega8 and TC74 (which is a clone of LM75) on it with pull-ups and everything. I made a code (which I'm organizing right now to put here on AVR Freaks) for reading a LM74 (SPI) and the conversion routine will be the same, but I'm having problems with I2C and Atmega8. I already read Atmega8 datasheet but I can't make them work. I tried different libraries (TWI/I2C is kind of complex for making my own) , clocks but no success at all...
The best result was some random waves (on virtual scope) on SDA... =(
js
PostPosted: Aug 21, 2012 - 12:13 AM
10k+ Postman
Sorry I'm out, you are using simulation and a virtual scope and not the real hardware.
felipemirand
PostPosted: Aug 21, 2012 - 12:17 AM
Newbie
For the first test, yes. Testing everything on real world as a first step would take waaaay more time.
js
PostPosted: Aug 21, 2012 - 12:23 AM
10k+ Postman
Not for me as I have the real world at my disposal ie real hardware, real debugger (JTAG or DW) and real oscilloscope. Wink
jgmdesign
PostPosted: Aug 21, 2012 - 01:48 AM
From what I just read on the datasheet you have two registers to deal with and an address.
The address is 1001101b
The two registers are:
Config where only two bits are looked at, the STANDBY bit which you can read or write to, and by default is set to '0' or normal operation. And the DATA READY which tells you if there is valid data in the other register you have access to
The TEMP register which is read only.
If you look at Figure 3-1 on page 7 it shows the formats for a write operation and a read operation along with the data format the sensor outputs when a read command is sent.
All in all this is a relatively simple device to interface to. I do remember having some difficulty my first go around with I2C and js's help along with David's got things moving quite quickly.
Since you are using Proteus, I assume 'C' is the language so I am not much help there. Sad
Post the code as you have noted. I am sure it's something simple. Usually is.
EdIT: In Proteus, can you put a logic analyzer on the SCK and SDA lines and see what the lines do?
I have decided that I am no longer going to plan anything in advance. In a court of law this is called Pre-Meditated, and does not look good for the defense.....
Timer function not working properly? Check CLKDIV8 Fuse first Wink
ChenSong.Chaw
PostPosted: Aug 21, 2012 - 03:32 AM
Newbie
Look like he do not understand the I2C communication way, as the data pin can be input (receive data) then output (send data). The Atmel processor should be master as LM75 is not a controller so is a slave.
I2C is not as simple as SPI.
Geronimo
PostPosted: Aug 21, 2012 - 09:37 AM
Soo... A schematic would help!
And it would also be nice to have a look at your code that you can't get working!
- Brian
dbrion0606
PostPosted: Aug 21, 2012 - 10:35 AM
Posting Freak
Perhaps one would need two schematics and two codes, as there are two circuits (one temperature sensor + AVR as an I2C slave, another AVR being the I2C master)...
There is something which worries me : is there a cheap way to test only one circuit at the time with a PC (it already exists) which would function as a master (if one tests the slave part) , then as a slave (to test the master part). As PCs already preexist, this could be cheaper than a DSO or a logic analyser (and I feel/fear they test both circuits at the same time, which is complicated)....
Edited : if the structure temperature sensor + AVR is a slave, the AVR should be at the same time a master (to silently "speak" to the other AVR) and a slave (to "listen" to the LM75). But perhaps I guessed wrongly...
Geronimo
PostPosted: Aug 21, 2012 - 01:07 PM
Right, I didn't get that from the original post!
First he speaks about connecting a LM75 to the mega and I thought that was it, but then about connecting to megas together!
To Felipe: While it can certainly be done, it will complicate things slightly, why don't you just start by getting the mega to run as a master connecting it to your LM75. Once you have the master part running start working on the slave part!
felipemirand
PostPosted: Aug 24, 2012 - 02:56 AM
Newbie
It worked!
I adapted Peter Fleury's library in order to put it in just a file. First I used TC74 (which is almost same thing as LM75) and it worked perfectly (I don't have any TC74, I tested it on Proteus, if anyone can test it on real world, please share with us!). Here is the code:
Code:
#include <util/delay.h>
#include <stdlib.h>
#include <avr/interrupt.h>
#include <compat/twi.h>
#define TC74  0b1001101      // device address of TC74
/*uC Clock*/
#define uC_Clock 8000000L
/** defines the data direction (reading from I2C device) in i2c_start(),i2c_rep_start() */
#define I2C_READ    1
/** defines the data direction (writing to I2C device) in i2c_start(),i2c_rep_start() */
#define I2C_WRITE   0
/* I2C clock in Hz */
#define SCL_CLOCK  100000L
 Initialization of the I2C bus interface. Need to be called only once
void i2c_init(void)
  /* initialize TWI clock: 100 kHz clock, TWPS = 0 => prescaler = 1 */
  TWSR = 0;                         /* no prescaler */
  TWBR = ((uC_Clock/SCL_CLOCK)-16)/2;  /* must be > 10 for stable operation */
}/* i2c_init */
  Issues a start condition and sends address and transfer direction.
  return 0 = device accessible, 1= failed to access device
unsigned char i2c_start(unsigned char address)
    uint8_t   twst;
   // send START condition
   TWCR = (1<<TWINT) | (1<<TWSTA) | (1<<TWEN);
   // wait until transmission completed
   while(!(TWCR & (1<<TWINT)));
   // check value of TWI Status Register. Mask prescaler bits.
   twst = TW_STATUS & 0xF8;
   if ( (twst != TW_START) && (twst != TW_REP_START)) return 1;
   // send device address
   TWDR = address;
   TWCR = (1<<TWINT) | (1<<TWEN);
   // wail until transmission completed and ACK/NACK has been received
   if ( (twst != TW_MT_SLA_ACK) && (twst != TW_MR_SLA_ACK) ) return 1;
   return 0;
}/* i2c_start */
 If device is busy, use ack polling to wait until device is ready
 Input:   address and transfer direction of I2C device
void i2c_start_wait(unsigned char address)
    uint8_t   twst;
    while ( 1 )
       if ( (twst != TW_START) && (twst != TW_REP_START)) continue;
       TWDR = address;
       if ( (twst == TW_MT_SLA_NACK )||(twst ==TW_MR_DATA_NACK) )
           /* device busy, send stop condition to terminate write operation */
           TWCR = (1<<TWINT) | (1<<TWEN) | (1<<TWSTO);
           // wait until stop condition is executed and bus released
           while(TWCR & (1<<TWSTO));
           continue;
       //if( twst != TW_MT_SLA_ACK) return 1;
       break;
}/* i2c_start_wait */
 Issues a repeated start condition and sends address and transfer direction
 Return:  0 device accessible
          1 failed to access device
unsigned char i2c_rep_start(unsigned char address)
    return i2c_start( address );
}/* i2c_rep_start */
 Terminates the data transfer and releases the I2C bus
void i2c_stop(void)
    /* send stop condition */
}/* i2c_stop */
  Send one byte to I2C device
  Input:    byte to be transfered
  Return:   0 write successful
            1 write failed
unsigned char i2c_write( unsigned char data )
    uint8_t   twst;
   // send data to the previously addressed device
   TWDR = data;
   if( twst != TW_MT_DATA_ACK) return 1;
   return 0;
}/* i2c_write */
 Read one byte from the I2C device, request more data from device
 Return:  byte read from I2C device
unsigned char i2c_readAck(void)
   TWCR = (1<<TWINT) | (1<<TWEN) | (1<<TWEA);
    return TWDR;
}/* i2c_readAck */
 Read one byte from the I2C device, read is followed by a stop condition
unsigned char i2c_readNak(void)
    return TWDR;
}/* i2c_readNak */
    unsigned char ret;
    DDRB  = 0xff;               // use all pins on port B for output
    PORTB = 0xff;               // (active low LED's )
   _delay_ms(1000);
    i2c_init();                 // init I2C interface
    i2c_start(0x9A);             // set device address and write mode
   i2c_write(0x00);
   i2c_rep_start(0x9B);       // set device address and read mode
   PORTB = i2c_readNak();
   i2c_stop();
   for(;;)
   i2c_write(0x00);
   PORTB = i2c_readNak();      //Temperature can be read on PORTB pins
   i2c_stop();
   _delay_ms(1000);
The only thing that didn't work was:
Code:
i2c_start(TC74+I2C_WRITE);
so I had to put TC74's address + "0" on LSB (0x9A).
By the way, anyone knows if Atmega8 can use 100 khz TWI with its internal 1 Mhz osc?
