SwarfEye
PostPosted: Jul 19, 2012 - 08:46 PM
So, I've got my usart speaking modbus decently well thanks to the help of you all on the board.
But periodically the usart seems to hang. Here is my code...
void modbusSendOutputFrame ( cBuffer *buffer )
      PORTB |= (1 << PB0);  // Send RTS high
      while (outBuffer.datalength > 0 )
         //Wait for an empty transmit buffer
         while ( !(UCSR0A & (1 << UDRE0 )) );
         UDR0 = bufferGetFromFront( &outBuffer );
       //Spin for a bit until the USART is done transmitting
      while ( ! (UCSR0A & ( 1 << TXC0 ) ) );
      UCSR0A |= ( 1 << TXC0 );  // clear TXCO
      PORTB &= ~(1 << PB0);  // Transmission complete.  Send RTS low
For some reason the program gets stuck on this line...
The way I know this is that I run the program in debug mode with the jtag. It runs fine for a while, but then begins to hang completely. Once it is hung, I pause the program execution with the debugger, and we always end up on that line.
It appears that TXCO is not going high.
After I pause the program, I add a breakpoint to the next line, and start execution again, but we seem to stay forever stuck waiting on TXC0.
What am I doing wrong?
Bill
PostPosted: Jul 19, 2012 - 10:28 PM
Can the function ever be called when outBuffer.datalength is 0? If so, then you will be waiting for the UART to finish transmitting when you never transmitted anything to begin with.
SwarfEye
PostPosted: Jul 20, 2012 - 04:14 PM
Right on. Thank you.
I'm really never supposed to be calling that function when the buffer.datalength == 0, but I put in a little catch for that, and my hanging problem went away!
Now I've got to figure out why my function is getting called when I've got buffer.datalength == 0!
Thanks again.
Bill
