501-q
PostPosted: Jul 19, 2012 - 11:35 AM
Hi!
I use (with -O2 option) GCC from WinAVR 20090313 version 4.3.2.
Code:
      unsigned char *p;
      unsigned short pp;
      cli();
 34e:   f8 94          cli
      p = RingPointer;
 350:   f2 01          movw   r30, r4
      *p ++ = 0xFF;
 352:   d2 01          movw   r26, r4
 354:   8f ef          ldi   r24, 0xFF   ; 255
 356:   8d 93          st   X+, r24
      *p ++ = 0x04;
 358:   84 e0          ldi   r24, 0x04   ; 4
 35a:   81 83          std   Z+1, r24   ; 0x01
 35c:   fd 01          movw   r30, r26
 35e:   31 96          adiw   r30, 0x01   ; 1
      *p ++ = from;
 360:   11 96          adiw   r26, 0x01   ; 1
 362:   2c 93          st   X, r18
      *p ++ = to;
 364:   61 83          std   Z+1, r22   ; 0x01
 366:   32 96          adiw   r30, 0x02   ; 2
      pp = (unsigned short)p;
      if ( (pp >> 8) == ((RAM_END - 0x100) >> 8) ) p = ring_start;
      RingPointer = p;
 368:   2f 01          movw   r4, r30
      sei();
 36a:   78 94          sei
Code:
register unsigned char * RingPointer asm( "r4" );
unsigned char * volatile ring_start = (unsigned char*) RAM_START;
Where is
Code:
Does it work in new version of GCC? What with register variables in newer version of GCC?
Ilya
ps: This is work:
Code:
if ( (pp & 0xFF00) == ((RAM_END - 0x100) & 0xFF00) ) p = ring_start;
clawson
PostPosted: Jul 19, 2012 - 11:37 AM
10k+ Postman
You haven't shown enough context - the code could easily have been moved to before or after the sequence you posted. Post more of the .lss and note that I'm going to edit your thread title.
501-q
PostPosted: Jul 19, 2012 - 11:57 AM
Hi, clawson!
No, I checked it.
Ok.
Code:
   WaitForReply = 0;
 304:   10 92 04 01    sts   0x0104, r1
 308:   08 95          ret
[skiped]
      unsigned char *p;
      unsigned short pp;
      cli();
 34e:   f8 94          cli
      p = RingPointer;
      *p ++ = 0xFF;
      *p ++ = 0x04;
      *p ++ = from;
      *p ++ = to;
      RingPointer = p;
      sei();
 36a:   78 94          sei
 36c:   cb cf          rjmp   .-106       ; 0x304 <ProcTel+0x30>
Code:
#define RAM_START   0x1100
#define RAM_END      (RAM_START + 0x7FFF)
void ProcTel( unsigned char from, unsigned char to, unsigned char fc );
If RAM_END redefine as 'RAM_START + 0x8000' then it work fine.
And this is work too:
Code:
#if defined(__ASSEMBLER__)
#else
#define RAM_START   0x1100u
#define RAM_END      (RAM_START + 0x7FFFu)
#endif
But I don't like double define same constants for asm and C...
Ok, no matter Wink
Ilya
SprinterSB
PostPosted: Jul 19, 2012 - 12:13 PM
Posting Freak
[quote="501-q"]Where is
Code:
Make sure you don't compare unsigned against signed. Enable warnings and fix them.
Yes, you can use R2..R7 as global registers.
Compile every module with -ffixed2 -ffixed-3 ... including modules contributing to libraries or make otherwise sure that no module unintentionally uses one of your global regs.
Moreover, notice that GCC can optimize global registers: global registers cannot be volatile; volatile only applies to memory storage classes, not to register.
This can lead to problems if you share a global reg between different IRQ levels.
501-q
PostPosted: Jul 19, 2012 - 12:17 PM
Code:
if ( (pp >> 8) == ((RAM_END - 0x100u) >> 8) ) p = ring_start;
With this:
Code:
Problem was with compare between signed and unsigned shorts. But I don't undestand GCC's logic in this case.
WBR, Ilya.
501-q
PostPosted: Jul 19, 2012 - 12:28 PM
Hi, SprinterSB!
SprinterSB wrote:
501-q wrote:
Where is
Code:
Yes, there is warning in this line:
Code:
pb.c:143: warning: integer overflow in expression
But this warning exist in both cases: when it work and when it isn't work.
To fix this warning I have to double define same constants (but I don't like it):
Code:
#else
#endif
Ilya
SprinterSB
PostPosted: Jul 19, 2012 - 12:34 PM
Posting Freak
Isn't RAMEND defined in avr/io.h?
avr-gcc NewsABIOptions4.8-WindowsInline Asm
501-q
PostPosted: Jul 19, 2012 - 12:48 PM
I use RAM_END as end of external RAM. All of external ram I use as ring buffer (in this case).
(ring_start need too: I wait for some event and then save part of ring buffer, change ring_start and wait same event again).
Ilya
