katochd46
PostPosted: Jul 09, 2012 - 01:09 PM
Can someone suggest what is the exact name of these cables used inside the panel box for power & connecting terminal block & relay Question
I have attached a file for it.
Please suggest,
Katoch
Kartman
PostPosted: Jul 09, 2012 - 03:38 PM
At a guess it is 0.75mm sq V90 rated wire. The terminals look like phoenix contact UK5
js
PostPosted: Jul 10, 2012 - 12:59 AM
10k+ Postman
Location: Sydney, Australia (Gum trees, Koalas and Kangaroos, No Edelweiss)
Katoch please try and reduce the size of photos before posting. I have reduced the size down to about 1/3.
katochd46
PostPosted: Jul 10, 2012 - 04:06 AM
Thanks for replying.
Thanks, I will take care about this next time.
katochd46
PostPosted: Jul 10, 2012 - 04:23 AM
http://www.diynot.com/pages/el/el003.php
This link tells about different dimension of cables.
http://www.renovateforum.com/f195/v90-75387/
What do we mean by term V-90, above link states it is temperature rating Question
Please tell about this term.
js
PostPosted: Jul 10, 2012 - 05:42 AM
10k+ Postman
Correct, usually you have something like 90 degrees or 105 degrees or other.
If you are working at room temperature then V90 is ok, if your equipment is running under the Sahara sun then you may want to think about using a higher grade wire.
