| Author |
Message |
Posted: Jun 18, 2012 - 01:59 PM |
im a beginer to avr
what is wrong with this code
Code:
#include <avr/interrupt.h>
#include <util/delay.h>
int adc_result=0;
int ch=0;
int main (void)
//set portC as input and enable the pull up resistor
DDRC=0x00;
PORTC=0xFF;
//set up port D 0-5 as output& C 6,7 as input
DDRD=0x3F;
// Set ADC prescaler to 128 - 125KHz sample rate @ 16MHz
ADCSRA |= (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0);
// Set ADC to Free-Running Mode
ADCSRB &=~((1<<ADTS2)|(1<<ADTS1)|(1<<ADTS0)) ;
// Enable ADC
ADCSRA |= (1 << ADEN);
// Enable ADC Interrupt
//ADCSRA |= (1 << ADIE);
// Enable Global Interrupts
//sei();
// Loop Forever
// Set ADC reference to AREF
// Left adjust ADC result to allow easy 10 bit reading
//select adc channel 1
ADMUX=0x00;
for(ch=0;ch<3;ch++)
// Start A2D Conversions
ADCSRA |= (1 << ADSC);
//Read the adc result
adc_result=ADCW;
_delay_ms(10);
if(adc_result>970)
if(ch==0)
PORTD1=1;
_delay_ms(50);
if(adc_result>970)
PORTB4=1;
else if(ch==1)
PORTD2=1;
_delay_ms(50);
if(adc_result>970)
PORTB4=1;
else(ch==2)
PORTD2=1;
_delay_ms(50);
if(adc_result>970)
PORTB4=1;
ADMUX++;
Posted: Jun 18, 2012 - 02:25 PM |
What AVR model are you working with?
What do you expect to happen?
What is happening?
How are you testing?
What problem(s) are you encountering?
The entire logic of the program is strange. The value is checked for 970--and then again checked. How can it change?
A conversion is started and the result taken--without waiting for the conversion to complete.
In free-running mode, you can easily be grabbing the result from the "previous" channel. |
Posted: Jun 18, 2012 - 02:34 PM |
Code:
adc_result=ADCW;
Did we perhaps forget to do something in the middle here? Contrary to popular belief the result in ADCW will not be available just a few cycles after you set the ADSC bit. Try putting a:
Code:
while(ADCSRA & (1<<ADSC)));
between those lines to sit and wait while ADSC remains high - it will return to 0 and hence end the while() loop when the conversion is complete.
Code:
PORTD1=1;
I'd be interested to see the definition of "PORTD1". True, if you use something like Peter Danegger's sbit.h then something like this might be valid syntax but I see no such #include of the necessary .h file. |
Posted: Jun 18, 2012 - 02:42 PM |
Code:
PORTD1=1;
lol -- I missed that in my first read-through. Wouldn't you get something like a "not an lvalue" error?
Error: C:\AtmelC\TestProgs\M88t.c(15): the expression must be a modifiable lvalue
Posted: Jun 18, 2012 - 05:45 PM |
clawson wrote:
Code:
PORTD1=1;
You will find that in .inc files for inclusion in an assembly source though it is equated as a bit number exactly the same as PD1 is. Definitely a non-working piece of code here. |
_________________ Larry
Those afraid to embrace the future will quickly fade into the past. - larryvc
Posted: Jun 18, 2012 - 05:49 PM |
Two pints of whatever you are smoking. How are .inc files involved in the use of avr-gcc? |
Posted: Jun 18, 2012 - 07:09 PM |
They're not, but since you asked, I pointed out where they "are" defined.  |
Posted: Jun 18, 2012 - 09:14 PM |
OT:
LOL! A really crap day can always be saved by something like this. |
Posted: Jun 18, 2012 - 10:24 PM |
OT:
Try "I'll have what she's having", from "When Harry Met Sally".
http://www.youtube.com/watch?v=F-bsf2x-aeE
Start at about 1:30. |
Posted: Jun 18, 2012 - 10:30 PM |
Posted: Jun 18, 2012 - 10:49 PM |
I just want to know how you two got soooo OT from Johan's previous post.  |
Posted: Jun 18, 2012 - 11:15 PM |
It was >>Cliff's fault<< for mixing his metaphors.
No, wait--the root cause was >>you<< -- inserting [the low-level programming technique that shall not be mentioned] into a high-brow C thread. |
Posted: Jun 19, 2012 - 05:32 AM |
theusch wrote
Code:
AVR Studio 4, GCC compiler
Code:
actually i want to convert three analog signal into digtal simultaneously(with max speed) and compare it with threashold and if any one it is greater than the threashold then a led must glow corresponding to that signal.Moreover if the condition stable for a particular time then there must be get an o/p on a port pin at a particular pin.
Code:
build error,i know the code is not completed
i think now you got it. can you help me?[/code] |
Posted: Jun 19, 2012 - 06:58 AM |
Did you read clawson's post two posts ater your first post?
http://www.avrfreaks.net/index.php?name ... 434#966434
What does PORTD1=1; do?
Have you written any code to just blink an LED yet? |
Posted: Jun 19, 2012 - 08:47 AM |
Thanks for telling us the tool-chain, but what does this have to do with the AVR model (=the chip on which your program is intended to run)? |
_________________ /Martin.
Posted: Jun 19, 2012 - 09:21 AM |
That rang a bell. So I digged through earlier threads by the OP, and:
http://www.avrfreaks.net/index.php?name ... 571#962571
http://www.avrfreaks.net/index.php?name ... 310#964310
Hey Justin! Please stay in one thread with your work on these ADC-and-threshold questions.
MODERATOR: Perhaps the other two threads should be locked? [done - clawson] |
Posted: Jun 19, 2012 - 12:45 PM |
| I asked if the signals were AC or DC. You said the signals were 50Hz AC. I assume you want to read the peak or the average amplitude of these signals, which will require either some digital signal processing to determine the peak or average of a group of samples, or a diode and an RC low pass filter to 'catch' the signal for 20ms so the a/d converter can read it. I felt sort of miffed that you didn't mention that you had read my suggestion and understood it. |
_________________ Imagecraft compiler user
Posted: Jun 19, 2012 - 01:26 PM |
atmega168
the following code shows error in avr studio, avr gcc compiler.
Code:
#include <stdio.h>
//system clock @16MHz
#define F_CPU 16000000
//Global variable
int adc_result[2]={0,0,0};
uint8_t ch=0;
/* PORT INIT */
void port_init (void)
//set portB.1 as output
DDRB |=(1<<PB1);
PORTB&=~(1<<PB1);
//set portC0,1,2, as input and enable the pull up resistor
DDRC &=~(1<<PC0)|~(1<<PC1)|~(1<<PC2);
PORTC |=(1<<PC0)|(1<<PC1)|(1<<PC2);
//set up port D 0-2 as output& D6,7 as input with pull up resistor
DDRD &=~(1<<PC0)|~(1<<PC1)|~(1<<PC2);
DDRD &=~(1<<PD6)|~(1<<PD7);
PORTD |=(1<<PD6)|(1<<PD6);
void init_adc(void)
//ADCSRB &=~((1<<ADTS2)|(1<<ADTS1)|(1<<ADTS0)) ;
//select adc channel 0
//ADMUX=ch;
// Enable ADC
sei();
//Start first conversion
ADCSRA |= (1<<ADSC);
/* Interrupt service routines */
ISR(ADC_vect)
//delay for discarding first conversion result
//_delay_ms(10);
switch(ch)
case 0:
adc_result[0]=ADCW;
if(adc_result[0]>862)
do
PORTD|=(1<<PD0);//glow the led corresponding to signal 1
//Start next conversion with same channel
_delay_ms(3);
adc_result[0]=ADCW;
if(adc_result[0]>887)
do
adc_result[0]=ADCW;
PORTB|=(1<<PB0);// o/p drive if the state at adc0 exist for a particular time
}while (adc_result[0]<970)
}while(adc_result[0]<862)
else if (adc_result[0]<754)
PORTD|=(1<<PD3);//glow the led corresponding to UV indication
if(ch<3)
ch++;
ADMUX=ch;
ch=0;
ADMUX=ch;
break;
case 1:
adc_result[1]=ADCW;
if(adc_result[1]>862)
do
PORTD|=(1<<PD1);//glow the led corresponding to signal 2
_delay_ms(3);
adc_result[0]=ADCW;
do
adc_result[0]=ADCW;
PORTB|=(1<<PB0);// o/p drive if the state at adc1 exist for a particular time
}while (adc_result[1]<862)
}while(adc_result[1]<862)
else if(adc_result[1]<754)
if(ch<2)
ch++;
ADMUX=ch;
ch=0;
ADMUX=ch;
break;
case 2:
adc_result[2]=ADCW;
if(adc_result[2]>862)
do
PORTD|=(1<<PD2);//glow the led corresponding to signal 3
_delay_ms(3);
adc_result[0]=ADCW;
if(adc_result[2]>887)
do
adc_result[0]=ADCW;
PORTB|=(1<<PB0);// o/p drive if the state at adc2 exist for a particular time
}while (adc_result[2]<862)
}while(adc_result[2]<862)
else if(adc_result[2]<754)
if(ch<3)
ch++;
ADMUX=ch;
ch=0;
ADMUX=ch;
break;
void main()
port_init();
// Loop Forever
ADMUX=ch;
init_adc();
Posted: Jun 19, 2012 - 01:28 PM |
Saying what the error is would help as then we wouldn't have to compile it ourselves (I'm not in a position to do so in my current location).
BTW you do know that warnings/errors include both the filename and the line number (test.c:109 is line 109 of test.c) so you should be able to identify the exact line where the error is located. |
Posted: Jun 19, 2012 - 01:40 PM |
Code:
int adc_result[3]={0,0,0};
instead of
Code:
Code:
DDRC &=~((1<<PC0)|(1<<PC1)|(1<<PC2));
instead of
Code:
(replace on all occurances).
Code:
Are you sure, that you are running on 16 MHz and not on the internal 1 MHz ( 8 MHz / 8 ) as this is default?
Put all stuff from your ISR outside since you do it in polling-mode and all this stuff including the delays should never be done inside an ISR.
I suggest you to read the tutorial on bit-manipulation |
