| Author |
Message |
Posted: Jun 15, 2012 - 05:35 PM |
I want to write a program in avr studio .
and I want to use switch as interrupt if the switch=1 the led will turn on if it 0 then the led will turn off so I connect switch to (INT0) but i don't know how to write the code.
please I need help  |
Posted: Jun 15, 2012 - 08:16 PM |
Hello, Losiana -
Welcome to the forum. interrupt not needed.
First question: assembler or c or BASIC?
Metacode might look like this
Code:
MAIN:
if switch_pin = low
LED = off
GOTO Main
LED = on
GOTO Main
How this is implemented depends on the environment you use.
By the way, nobody will supply code for you. You need to try SOMETHING, then show us what you have tried. Suggestions will then be offered. Be sure to use the code tags (buttons) when you post your code.
Jim |
_________________ Jim Wagner
Oregon Research Electronics, Consulting Div.
Tangent, OR, USA
"The only thing standing between us and victory is defeat" P.G.Wodhouse in Wooster & Jeeves series
Posted: Jun 15, 2012 - 08:22 PM |
please I need help
Yes, you do need help.
I recommend that you use switch polling with a proper debounce routine instead of interrupts. |
_________________ Larry
Those afraid to embrace the future will quickly fade into the past. - larryvc
Posted: Jun 15, 2012 - 08:53 PM |
If the OP is simply turning an LED on or off, then debounce is not (yet) needed. It will soon be, but not yet.
Jim |
Tangent, OR, USA
Posted: Jun 15, 2012 - 09:54 PM |
Though that is true, I was mainly concerned with the "switch as interrupt" and "(INT0)" in the OPs post. |
Posted: Jun 15, 2012 - 10:40 PM |
| my code was
Code:
#include <avr/interrupt.h>
enum {led_off,led_on};
int current = led_off;
ISR (INT0_vect)
if (current == led_off)
current =led_on ;
else current=led_off;
void main ()
DDRB = 0xFF;
GICR = 0x40;
MCUCR = 0x03;
sei ();
while (1)
{ switch (current)
{case led_off:
PORTB = 0b00000000; break;
case led_on:
PORTB = 0b11111111; break;
$ Fixed code tags - JS $ |
Posted: Jun 15, 2012 - 11:19 PM |
Code:
This needs to be
Code:
volatile int current = led_off;
Search for 'volatile' here for uncountable explanations of this, and why it is needed. Or read up on ity in your favourite textbook on the C programming language.
Code:
ISR (INT0_vect)
current =led_on ;
This is exactly the situation where the "switch bounce" mentioned above comes into play. Your switch will open and close several times during a few milliseconds when you press the button once. Search here at AVRfreaks for "switch bounce", "debounce", "de-bounce" etc for many previous discussions on what this is and what you can do to avoid it. |
Posted: Jun 16, 2012 - 01:14 AM |
If you must use an interrupt, you will have to contend with switch bounce, later.
Reason? The switch really switches on and off many times each time you activate the switch and every time it is released. This will cause many interrupts on each push and release. You won't see them in THIS experiment because they happen so fast. But, when you start counting key pushes, you will get really bizarre results.
Jim |
Tangent, OR, USA
Posted: Jun 16, 2012 - 11:23 AM |
On the contrary, IMO. When the switch bounces an odd number of times for one press of the button, the LED will be seen to toggle. When the switch bounces an even number of times for one press of the button, it will not. |
