himel1842
PostPosted: Jun 25, 2012 - 06:00 PM
Rookie
Did you write the code to turn on the LEDs?
Yes, I wrote the code.
Code:
 while (1) {
      USART0WriteChar(data);
      data = USART0ReadChar();
      if (data != sentchar) {
        DDRB =0xFF;
      PORTB=0xFF; // turn on good led
     } else {
         DDRC =0xFF;
       PORTC=0xFF;// turn on bad led
      _delay_ms(500);
I can see the output in proteus, still not in real hardware.Tried with common ground as well. But couldn't find where is the problem.
larryvc
PostPosted: Jun 25, 2012 - 06:14 PM
Have you programmed the fuses on the chips to use the 8MHz crystals? Do you have a schematic of your board?
Larry
Those afraid to embrace the future will quickly fade into the past. - larryvc
himel1842
PostPosted: Jun 26, 2012 - 02:57 PM
Rookie
Fuse setup is shown in the attached file.
I am using two breadboard for master and slave. Proteus schematic and connection is shown in the attached file.
himel1842
PostPosted: Jul 30, 2012 - 04:13 PM
Rookie
Typically, you would use a second UART. Somewhere. There ARE AVRs with several UARTS (some with 4, even).
I can get somthing out of my 2nd USART but problem is this is not always same what I transmit. If I contnously transmit 'A' from the transmitter I dont always get A in the receiver TX port. I checked this by Using interface to PC. Anyone has any idea why its happening?
JohanEkdahl
PostPosted: Jul 30, 2012 - 04:32 PM
10k+ Postman
Present a minimal program that builds, runs and displays the problem.
himel1842
PostPosted: Aug 07, 2012 - 06:19 PM
Rookie
I am sending A, but don't receive A all the time.I am interfacing laptop with Receiver Tx , and seeing the output using Realterm. If I see the output in Uint format I get 208,11 and sometimes 65 which is transmitted character A.
My question is why I get 208 and 11?
Code for TX
Code:
#define F_CPU 8000000UL
#include <util/delay.h>
void USARTInit(int ubrr_value);
void USARTWriteChar(char data);
#ifndef BAUDRATE
#define BAUDRATE 38400
#endif
#define BAUD_PRESCALE (((F_CPU/(BAUDRATE*16UL)))-1)
   USARTInit(BAUD_PRESCALE);
      USARTWriteChar('A'); // send the data to USART Tx for transmission
   //Set Baud rate
   UBRR0 = ubrr_value;
   //Enable The receiver and transmitter
   UCSR0B=(1<<RXEN0)|(1<<TXEN0);
   UCSR0C=(1<<USBS0)|(3<<UCSZ00);
   while(!(UCSR0A & (1<<UDRE0)))
  UDR0=data;
Code for Rx
Code:
#include <stdlib.h>
char USARTReadChar();
void USARTWriteChar( char data);
#ifndef BAUDRATE
#endif
int main()
   char data;
      data=USARTReadChar();
      USARTWriteChar(data);
   //Set Baud rate
   UBRR0 = ubrr_value;
   UBRR1 = ubrr_value;
   while(!(UCSR0A & (1<<RXC0)))
    return UDR0;
   UDR0=data;
