charon
PostPosted: Apr 24, 2012 - 10:14 PM
Newbie
Does anyone know what should be in the 13 byte "OtherData" field when sending a Check MAC packet to an ATSHA204 IC? The datasheet specifies it's "Remaining constant data needed for response calculation" but that's all the information I can find.
I created a MAC using the part and I wanted to check it with the original challenge using Check MAC, but I get an unsuccessful comparison return code (0x01). I've tried both zeros and NULL, but neither changes the result.
Adez_CC
PostPosted: Apr 25, 2012 - 07:06 AM
Rookie
Hello charon,
Are you using the library provided by Atmel? If not, you can download the library here
http://www.atmel.com/tools/CRYPTOAUTHENTICATIONATSHA204DEVELOPMENTLIBRARY.aspx
Regarding your question, you can check the datasheet page 37 and 46. The message that will be hashed by CheckMac must match with the message hashed by Mac command. So, "OtherData" should be filled so that the two messages are identical.
Adez
charon
PostPosted: Apr 25, 2012 - 07:51 PM
Newbie
Hi Adez,
I am using the library provided by Atmel.
I did as you suggested and made the messages identical with OtherData, and the comparison is successful. It makes sense that the messages need to be identical, I just didn't make that connection before...
Thanks for your help!
kakaxi
PostPosted: Sep 27, 2012 - 07:00 AM
Newbie
dear boys,the checkmac is serve to check the mac coommad right or not?
if so ,Prior to running this mac, the Nonce commands I have been optionally run.THEN Prior to running CHECKMAC command, the Nonce commands also have been optionally run ?like this the result will be different,because the nounce command result is diffent twice.so what should i do ?please ,thank you .
Adez_CC
PostPosted: Dec 12, 2012 - 01:10 AM
Rookie
To use CheckMac command, you need to run Nonce command in Passthrough mode. So, the Nonce will be the same for the Mac command and CheckMac command.
