Posted: Feb 27, 2012 - 11:00 AM |
hi..
i am using avr atmega16 pu first time.
when i tried to debug my small code using AVR studio 4 i got this erroe:
Build failed... No build tools defined.
please suggest some solution...
thanx
sunil |
Posted: Feb 27, 2012 - 11:17 AM |
| Can you confirm that you have separately downloaded and installed either WinAVR20100110 or Atmel's "AVR Toolchain"? (the dialog says you have not). |
Posted: Mar 27, 2012 - 06:13 AM |
ya now i have downloaded WinAVR20100110 and installed sucesfully..
but i am still not able to build it...
the versions are as follows in avr studio 4:
AVR Studio 4.16.628
GUI Version 4, 16, 0, 626
Operating System
Major 6
Minor 1
PlatformID 2
Build 7600
Plugins:
AvrPluginAvrAsmObject 1, 0, 0, 47
AvrPluginavrgccplugin 1, 0, 0, 10
Stk500Dll 1, 0, 1, 11
Avr also consumes my 95% of processor...
Please suggest some solution |
Posted: Mar 27, 2012 - 09:24 AM |
But that picture shows no compilation error?
If you use math functions do you link with libm.a - that can easily save 2K. |
Posted: Mar 27, 2012 - 12:51 PM |
To me it seems, OP meant 95% of the processor of his PC. The status-line in the very top shows "AVR Studio - C:\... (Not Responding)"
As far I see, OP uses Win7. In which paths are WINAVR and AVRStudio installed? They should not contain any white spaces or special characters.
AVRStudio 4.16 is from 2009 - maybe it has some incompatibilities to Win7? |
_________________ /Martin.
Posted: Mar 27, 2012 - 03:03 PM |
thanx clawson and martin
@martin- yes u r right.. while i build any code, AVR studio hangs showing NOT RESPONDING on top. it doesnt respond till i kill it with my task manager..
the path of studio is as below..
C:\Program Files (x86)\Atmel\AVR Tools\AvrStudio4\AVRStudio.exe
while the path for WinAVR-20100110 is:
C:\Users\Sunil\AppData\Roaming\Microsoft\Windows\Start Menu\Programs |
Posted: Mar 27, 2012 - 05:26 PM |
Try to install WinAVR in it's default directory C:\WinAVR-20100110
As far as I remember, both - having WinAVR itself or the project (source) in a directory containing spaces (C:\...\Start Menu\...") or special characters can cause malfunction. |
Posted: Apr 09, 2012 - 06:14 PM |
Hey, I had similar problem and the compiler reported "Build failed... No build tools defined"
I deleted the System Variables :
"Path" where was "C:\Program Files (x86)\Atmel\AVR Tools\AVR Toolchain\bin;C:\Program Files (x86)\WinAVR-20100110\bin;C:\Program Files (x86)\WinAVR-20100110\utils\bin"
and "AVR32_HOME" just to make sure where was "C:\Program Files (x86)\WinAVR-20100110"
and after clicking on the build icon in AVR Studio V4.19, it told me that it will create the path itself or something like that and since then it's been working properly. |
