Posted: May 31, 2012 - 06:33 AM |
I was working on a project and suddenly I can't read/write/anything via ISP. I've been at this for hours and I've boiled this bloody thing down to its bare nuts and it still won't work.
- I've confirmed the programmer is fine - I can operate with other targets just fine
- To rule out the connections, I've re-done them about a thousand times. I now have very short wires soldered directly to the AVR's pins and it still doesn't work
- Fine, so the Mega is toast... so I removed it and replaced it with a fresh virgin right out of the package... still nothing
What can possibly be wrong with a circuit that prevents it uC connecting when I have direct connections to the appropriate pins??? Could a faulty cap (or??) down a line somehow cause this problem? If the crystal was damaged? That shouldn't matter for a virgin chip, should it?
I'm so pissed off right now... and dead tired. I've been fighting with this all day and now I'm behind and for nothing!
I'm going to bed, but if you have any tips for me to look at in the morning... appreciated.
BTW: what's the bare minimum circuitry needed for ISP programming? I've never tried it, but can you hook an ISP directly to an AVR with zero other components? If so, I suppose I could begin cutting traces in a deductive effort.
ISP = USBasp (purchased. Confirmed working)
Target = Atmega128 fresh from the package
Circuit = Chinese r/c radio controller (schematic) |
Posted: May 31, 2012 - 06:49 AM |
is there any other stuff connected to the ISP/SPI lines? I have had this problem in the past where i connected a display to the SPI lines(used as GPIO) that would sometimes keep one of the lines low making programming impossible.
As you have already soldered wires directly to the AVR pins, perhaps you can lift the pins and then connect the ISP and see what happens. If it then works, put a 1K resistor in series with the lines after the programming pads, so even when the other stuff pulls the line low the programmer sees a 1K load. (just see you have 200 Ohms with a 100nf(???) cap that will probably kill the signal.)
what happens if you remove the 200R? |
2)tutorial forum
3)Newbie start here
Posted: May 31, 2012 - 06:50 AM |
I don't know who was the ixxxt (sorry ) who designed that board but it shows ALL electrolytics REVERSED.
A HUGE 47uF (also reversed) on the reset line MUST NOT be there, 47nF to 100nF max.
Extremely small resistors on the ISP pins, so if anything drives those pins it will kill the ISP signals. |
Posted: May 31, 2012 - 07:38 AM |
John, try not to get caught up on the design. Hundreds of thousands of these (literally) are on the market and work just fine, and tens of thousands of us regularly flash them the same way I've been doing with this exact unit for a couple of years. Something is damaged... has to be... its not a design flaw that's causing the problems.
Meslomp, there's nothing serial connected (UART, etc) if that's what you mean, but the MOSI, MISO, and SCK lines all pull dual-duty as GPIO (switches).
If you remove the 200R then the cap screws with the ISP (I tried that in the past for some unrelated reason - when everything was working fine). The caps are there, supposedly, for RF noise supression.
Thanks John... that gives me something to look for in the morning. Perhaps one of the switches sharing those pins is stuck and driving to ground. I kinda don't think so because I tested for shorts, but I wasn't looking specifically at that. |
Posted: May 31, 2012 - 07:44 AM |
Nevermind, that was easy to check - took me 20 seconds. Not the issue.
ps. The tant caps are correct. I'm gathering its just poor (or at least ambiguous) notation. |
Posted: May 31, 2012 - 07:47 AM |
Are the electrolytics connected backwards ?
Or is it just the schematic?
I presume that ISP lines are shared with push buttons.
A stuck button will kill your ISP. If those series resistors were 1k or so, ISP could co-exist with stuck buttons.
Observing the ISP signals with a logic analyser or scope would help.
Likewise checking that you actually have a 16MHz clock. Does any existing firmware run ?
Posted: May 31, 2012 - 07:51 AM |
Hi David. See (cross?) post above for answers to some Q's.
I wish I had a scope - I don't.
I am curious if the problem is the crystal... but as I asked originally... should it matter with a virgin chip? The fuses aren't even set yet.
No, there's no firmware at all... its a fresh chip. Before I placed the fresh chip in, the answer would still be "no" because it crapped out on me after an erase. I thought I just fuse bricked it, but I couldn't get it working again so I resorted to swapping for a fresh uC. Here we are. |
Posted: May 31, 2012 - 08:05 AM |
If it is a virgin chip, it starts in M103C compatibility mode. i.e. guaranteed to fail all mega128 programs.
And the virgin starts off with 1MHz RC, so you have to ISP very slowly. e.g. avrdude -B5
If you post the actual avrdude command and response, it would be helpful.
All the same, my money is on poor soldering.
Posted: May 31, 2012 - 09:51 AM |
Are you sure, that you have it connected right
The ISP connection differs on the 64 pin case from all other AVRs
64 pinners are:
ATmega64, ATmega128, ATmega1281, ATmega2561, AT90CAN128
Peter |
Posted: May 31, 2012 - 02:40 PM |
Yes, I know I have to program it slowly... I used B300 and it still failed. Poor soldering? Possibly, but that statement is hardly helpful without some tips on what else to look for. I've confirmed good continuity and no cross-continuity (shorts/bridges) on all ISP lines and all vcc/gnd pins on the mega.
Peter... Yes, I know the 64 uses odd-ball ISP. Again, I've successfully flashed this exact device hundreds of times. It *suddenly* stopped working and I've ruled out (I believe) the programmer, my connections, and the chip. It has to be something else in-circuit that is fine by design, but has failed.
usbasp output is useless... target doesn't respond. But I'll -vvv it and post it later today. |
Posted: May 31, 2012 - 03:18 PM |
Then I would wire a small DIP-AVR (e.g. ATtiny25, ATmega8) on a breadboard and check,
if the programmer was still alive.
Peter |
Posted: May 31, 2012 - 03:29 PM |
I see on the schematic some faults:
On reset you should use 0.1µF, but never 47µF.
On MISO, MOSI and SCK I see 0.1µF, that's too big.
No wonder, that nothing works.
Remove all caps on the switches and debounce in software.
It make programming easier and cost no noticeable resources (CPU-load, Flash).
http://www.avrfreaks.net/index.php?modu ... em_id=1801
Peter |
Posted: May 31, 2012 - 03:35 PM |
Come on Peter! You obviously didn't read what I wrote.
1) its not the programmer. As I *already said*, I confirmed it works.
2) As I *already said* this problem has nothing to do with the design. This is a commercial product with hundreds of thousands of units on the market AND I've been using this exact unit for years. |
Posted: May 31, 2012 - 03:47 PM |
A design fault must not cause malfunction immediately.
And these caps on the 4 lines are design faults.
It should be very easy to remove them and look, if it works.
Instead removing the caps on the switches, you can increase the 200R e.g. to 4.7k,
so the caps no longer short circuit the signals on the SPI lines.
Peter |
Posted: May 31, 2012 - 03:54 PM |
| I usually program a newly-soldered board with just AVR, power bypass caps and reset R/C installed, to pre-test it before continuing. Given what you seem to have ruled out so far, I'd look for problems with power or ground. |
Posted: May 31, 2012 - 04:20 PM |
| thoughts on what to look for? I've confirmed 5v across each a/vcc pin and GND, and continuity of GND points between ISP and target board. |
Posted: May 31, 2012 - 04:32 PM |
Hmmm, you need to buy a scope. And a cheap stereo microscope (you'd be amazed what some "good" solder joints look like up close!).
If you have power to all power pins
and ground to all ground pins
and power bypass caps
and proper reset R/C values
and programmer ground connected to AVR ground
and programmer signals connected to AVR ISP pins
and AVR ISP pins are not interfered with
and programmer works
and AVR is not trashed
and programmer speed is slow enough
then it should work. |
Posted: May 31, 2012 - 05:06 PM |
agreed.
Have one. And the solder joints are fine. Not perfect... too much solder on some so I'm not going to enter it in a "how to solder" photo contest... but that's not the issue
Check.
check.
You mean that they're there? Or that they're getting power.
again, the design works
check
check
still to confirm
check
what are the odds? I guess I can take it out of circuit and program in a simple breakout board.
can't get any slower... check.
hence the "SO FRUSTRATED" portion of the post title.
Someone asked for avrdude command and output:
avrdude -p m128 -c usbasp -U flash:r:test.bin:r -vvv
yields
avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "e:\WinAVR-20100110\bin\avrdude.conf"
Using Port : lpt1
Using Programmer : usbasp
avrdude: seen device from vendor ->www.fischl.de<-
avrdude: seen product ->USBasp<-
AVR Part : ATMEGA128
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 4 12 64 0 no 4096 8 0 9000 9000 0xff 0xff
flash 33 6 128 0 yes 131072 256 512 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : usbasp
Description : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
Note above example I forgot the -B switch, but same result. |
Posted: May 31, 2012 - 05:35 PM |
Well, I got lucky. I decided to go at it one pin at a time. I started with the most obvious culprit - RST - and I cut the trace at the pin and added my own 10k resistor and .1uF cap... and it worked.
So then I remove the 47uF cap they used and put it in place of my .1uF cap... and it still worked.
So then I figure it must be their 10k res... but it measures 10k pretty well on the dot so I doubt it. I remove it from the board and replace my 10k with that one. Still worked.
So then I temporarily conceed that everything was fine and I must have screwed up somewhere, so I bridge the knifed trace and put the components back the way they were...
AND IT DOESN'T WORK!
What in the world is going on???
If I had a scope, would that really help here? What would I even take readings of?
Looking at the schematic again, could it somehow be that inductor @ L1? Its marked 10u... 10uH I suppose? I don't have anything here that low to replace it with. 220uH is the smallest I have on hand. Any chance that's causing my grief? Should I bother ordering up a 10uH? |
Posted: May 31, 2012 - 06:38 PM |
Just short out the L1. It won't hurt. It just adds a bit of 'quality' to the Avcc pin.
In my avr designs, I don't use a resistor or a cap on /RST .....and I program with AVRISP MkII no problem.
Just my 2p in this frustrating saga.
Are you in the UK ? Where ? |
