ezharkov
PostPosted: Feb 24, 2012 - 01:11 AM
Let's say I have two files, foo.txt and foo.txt~. When I do "dir *.txt", it shows both. Is there any way to tell Windows not to show the one with tilde?
PostPosted: Feb 24, 2012 - 01:15 AM
del *.*~ then dir
ezharkov
PostPosted: Feb 24, 2012 - 01:23 AM
Smile - something a little bit more gentle, please!
zbaird
PostPosted: Feb 24, 2012 - 01:49 AM
Oh. Miralax, not Ex-Lax.
(some day you'll be old, too)
I think in many or most situations Uncle Bob's second asterisk will take precedence and the tilda will be ignored, and your dir command will feel quite lonely and unloved.
Chuck Baird
http://www.cbaird.org
zbaird
PostPosted: Feb 24, 2012 - 02:06 AM
Well, it appears to have to do with the tilda being the 4th character (and falling off into the extended name field). If you try it with files named foo.tx and foo.tx~ or foo.txtt and foo.txtt~ it works just fine.
Can you get the tilda out of the 4th position?
Chuck Baird
PostPosted: Feb 24, 2012 - 02:59 AM
maybe del *.???~
zbaird
PostPosted: Feb 24, 2012 - 03:08 AM
I don't think he wants to delete them, Uncle Bob, although that would make his life easier.
A pipe (that thing the internet is made out of), a grep, and a jug o' happiness.
Chuck Baird
PostPosted: Feb 24, 2012 - 03:23 AM
A Loaf of Bread, A Jug of Wine, And Thou beside me in the wilderness. Omar Kayyam "The Ruby Yacht". Guess that would be "The Red Boat" down here in Florida.
sbennett
PostPosted: Feb 24, 2012 - 03:52 AM
Pipe the dir output through the find command to NOT find the string ".txt~" or simply "~"
any lines containing the offending string will not be sent to the screen.
dir | find /V ".txt~"
zbaird
PostPosted: Feb 24, 2012 - 03:59 AM
Grep, find, toe-may-toe, toe-ma-toe. Bring on the jug o' happiness on the deck of the red boat.
Chuck Baird
PostPosted: Feb 24, 2012 - 09:50 AM
Which MS-DOS? When I do that in XP SP3 I get:
E:\avr>dir *.c?
 Volume in drive E is VBOX_windows
 Volume Serial Number is 0000-0805
 Directory of E:\avr
15/02/2012  11:47                39 add.c
24/02/2012  09:47                 0 foobar.c~
04/10/2011  09:48               365 bitstruct.c
02/11/2011  17:48               228 justtest.c
30/08/2011  08:00                 0 FlIbBlE.c
29/01/2012  17:51             3,272 foobar.c
29/09/2011  09:32             2,151 test_flags.c
07/11/2011  10:10                61 data.c
30/10/2011  15:02                 0 foo1.c
22/02/2012  15:52               609 test.c
06/11/2011  17:07            36,761 second.c
02/07/2011  19:45            12,873 fpbench32.c
29/07/2011  09:00               652 foo.c
24/02/2012  09:47                 0 bitstruct.c~
11/09/2011  16:11               356 astest.c
but when I do:
E:\avr>dir *.c
 Directory of E:\avr
No ~ entries listed with just "*.c" - I had to use "*.c~" in the first command to be sure the *~ files were listed.
PS of course if you have WinAVR on your machine you have access to "ls" Wink
steve17
PostPosted: Feb 24, 2012 - 11:11 AM
Yes, ls will do it right.
Dir works right for me if I run it from powershell instead of cmd.
ezharkov
PostPosted: Feb 24, 2012 - 11:14 AM
Well, tried ls.exe from WinAVR 20100110. It worked! ls.exe that I normally use, an older version, does not...
EDIT: And "WinAVR-20100110\utils\bin\grep.exe something *.txt" worked too (i.e., does not show stuff from files with tilde). That is why I started this thread in the first place. I guess it is really time for me to upgrade my UnxUtils set.
PostPosted: Feb 24, 2012 - 11:25 AM
But I do not think it matters
But you are saying you get a different result with "dir" in XP than I see? As I say if I use "dir *.c" I *only* see files with ".c" as an extension and none with ".c~". Perhaps they fixed it in SP3 (which I use)?
I thought it might be something to do with 3 character extensions rather than 1 character but I get the same with:
E:\avr>touch test.txt
E:\avr>touch test.txt~
E:\avr>dir *.txt
 Directory of E:\avr
24/02/2012  11:23                 0 test.txt
               1 File(s)              0 bytes
               0 Dir(s)  240,665,268,224 bytes free
E:\avr>dir *.txt*
 Directory of E:\avr
24/02/2012  11:23                 0 test.txt~
               2 File(s)              0 bytes
ezharkov
PostPosted: Feb 24, 2012 - 11:44 AM
Tried on SP3. No, still see the problem. But then again, perhaps they fixed it in some patches. On the other hand, I think I saw the same thing at work on Windows 7 ... I will double check and report back in an few hours. But WinAVR-20100110's grep.exe works fine, so I am good.
steve17
PostPosted: Feb 24, 2012 - 12:04 PM
The dir command has the problem on Win7 when it is run from the cmd shell. It is a built in command with this built in "feature".
Powershell implements dir differently and it works right.
Cygwin also has a dir.exe in /bin that works right.
And of course if you are running bash and have dir as an alias for ls, that works right too.
PostPosted: Feb 24, 2012 - 12:56 PM
Just checked in case I was using a different "dir" but it sure looks like I'm getting the one in CMD.EXE:
E:\avr[i386_vc]>which dir.exe
which: no dir.exe in (c:\Program Files\Microsoft Visual Studio 9.0\Common7\IDE;c:\Program Files\Microsoft Visual Studio
9.0\VC\BIN;c:\Program Files\Microsoft Visual Studio 9.0\Common7\Tools;c:\WINDOWS\Microsoft.NET\Framework\v3.5;c:\WINDOWS
\Microsoft.NET\Framework\v2.0.50727;c:\Program Files\Microsoft Visual Studio 9.0\VC\VCPackages;C:\Program Files\Microsof
t SDKs\Windows\v6.0A\bin;C:\asl\P2\components\..\..\tools\bin;C:\asl\P2\components\..\..\tools\cmake-2.8.2-win32-x86\bin
;C:\Qt\4.7.2\bin;C:\asl\P2\components\..\darc_externLib\OpenCV_1.1;C:\asl\P2\components\..\darc_externLib\OpenCV_1.1\bin
;C:\Program Files\Common Files\Microsoft Shared\Windows Live;E:\WinAVR-20100110\bin;E:\WinAVR-20100110\utils\bin;C:/Prog
ram Files/Texas Instruments/xdctools_3_22_01_21;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\syste
m32\WindowsPowerShell\v1.0;C:\Program Files\TortoiseSVN\bin;C:\Program Files\Graphviz2.26.3\bin;C:\Program Files\SciTool
s/bin/pc-win32;C:\Program Files\Support Tools\;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Fi
les\ATMEL Corporation\SAM-BA v2.10\drv\;C:\Program Files\ATMEL Corporation\SAM-BA v2.10;C:/Program Files/Texas Instrumen
ts/xdctools_3_22_01_21;C:\Program Files\OpenVPN\bin;C:\mingw\bin;E:\SysinternalsSuite;C:\Program Files\Common Files\Micr
osoft Shared\Windows Live;E:\WinAVR-20100110\bin;E:\WinAVR-20100110\utils\bin;C:/Program Files/Texas Instruments/xdctool
s_3_22_01_21;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\system32\WindowsPowerShell\v1.0;C:\Progr
am Files\TortoiseSVN\bin;C:\Program Files\Graphviz2.26.3\bin;C:\Program Files\SciTools/bin/pc-win32;C:\Program Files\Sup
port Tools\;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files\ATMEL Corporation\SAM-BA v2.10\
drv\;C:\Program Files\ATMEL Corporation\SAM-BA v2.10;C:/Program Files/Texas Instruments/xdctools_3_22_01_21;C:\Program F
iles\OpenVPN\bin;C:\mingw\bin;E:\SysinternalsSuite)
Oh and:
E:\avr[i386_vc]>set | grep -i comspec
ComSpec=C:\WINDOWS\system32\cmd.exe
steve17
PostPosted: Feb 24, 2012 - 01:41 PM
Cliff, you apparently have the only cmd prompt DIR in existance that works properly. Do you know someone in Redmond?
There are options that can be set in the DIRCMD environment variable, but as far as I know they are the same options you can give on the command line, and I can't find any that make it work right.
One difference I see is you use day/month/year format, but that would be weird if it affected this.
I even booted up ye olde XP SP3 and it doesn't work right. Here's what I got:
ezharkov
PostPosted: Feb 24, 2012 - 01:50 PM
Tried on Windows 7. Same issue. Cliff, where did you get your Windows from?
Tried this also:
#include <stdio.h>
#include <windows.h>
  static WIN32_FIND_DATA findData;
  HANDLE handle = FindFirstFile("*.txt", &findData);
  if (handle == INVALID_HANDLE_VALUE)
    printf("Error\n");
  else {
    do {
      printf("Name=<%s>\n", findData.cFileName);
    } while (FindNextFile(handle, &findData));
Same thing. I.e., it is in Win32 API.
dksmall
PostPosted: Feb 24, 2012 - 02:39 PM
Have you tried setting the hidden attribute?
