pdelprat
PostPosted: Feb 17, 2012 - 09:57 PM
Rookie
Sometime my projet works and sometime not. After a low search, I'm facing with a strange behavior, and I don't know how it can happen.
Look at my screenshop, after two simple instructions :
Code:
mov r0, lo(0x78)
orh r0, hi(0x78)
My register r0 value is 0x00010078 and not 0x00000078. It doesn't happen all times, but when it happen, my program crash due to a overflow later.
How it can be possible ?
Thanks for your help,
Pascal
Heihopp
PostPosted: Feb 17, 2012 - 11:27 PM
If you want to put a 32bit constant to a register:
mov r0, LWRD(0x12345678)
orh r0, HWRD(0x12345678)
pdelprat
PostPosted: Feb 17, 2012 - 11:41 PM
Rookie
thanks for your reply, but it seems that not a syntax issue, the disassembly show correct values :
Code:
mov r0, lo(0x78) -> mov r0, 120
orh r0, hi(0x78) -> orh r0, 0x0000
Kind regards,
Pascal
pdelprat
PostPosted: Feb 18, 2012 - 11:42 AM
Rookie
I need to check my clock configuration, because when I switch to 12 Mhz instead of 66 Mhz, all woks fine in any times. It probably comes from a instability due to a wrong clock configuration,
Make sense ?
Kind regards,
Pascal
digitalDan
PostPosted: Feb 18, 2012 - 11:53 AM
Did you set the flash for 1 wait state when operating above 33 Mhz? Neglecting to do so can cause all sorts of weird issues.
pdelprat
PostPosted: Feb 18, 2012 - 01:11 PM
Rookie
Many thanks, it seems that you right ...
I forgot this point,
Kind regards,
Pascal
