koutote
PostPosted: Feb 15, 2012 - 09:02 AM
Hi everybody,
I want to translate RS232 to 3.3V signals(got
the MAX3232 chip)
However for proper operation datasheet states that
0.1μF=100nF capacitors needed, polarized or non polarized.
Can I use non-polarized caps or you think will be a problem....(according to schematic of MAX3232 polarised are used)...
Sailing towards channel capacity
MBedder
PostPosted: Feb 15, 2012 - 09:13 AM
Use ceramic capacitors - they are non-polarized by nature, small, cheap and reliable.
haker_fox
PostPosted: Feb 15, 2012 - 09:18 AM
Hello there!
The datasheet says
C
What's wrong? Smile
koutote
PostPosted: Feb 15, 2012 - 09:24 AM
Haker_fox the schematic (inside datasheet) shows +(plus) and -(minus) connections for capacitors, thats why I was confused (....not Iam a newbie still...Smile).
Thanks guys, I will go for ceramic.
Rgds
DO1THL
PostPosted: Feb 15, 2012 - 09:58 AM
The schematic you're referring to just wants to make sure that, if you are using polarized caps, you connect them as shown. Of course, if you don't use polarized caps, the way you connect them is about as important as the pope's balls...
Einstein was right: "Two things are unlimited: the universe and the human stupidity. But i'm not quite sure about the former..."
