robbinvandamme
PostPosted: Feb 14, 2012 - 04:14 PM
I have an Atmega128 operating in Atmega103 compatibility mode. It is running Assembly code, i would like to step through it and and set some breakpoints. Is it possible to do this with a JTAG interface and how is this done?
Thx in advance!
Robbin
PostPosted: Feb 14, 2012 - 04:29 PM
In the 128 datasheet look at the section "ATmega103 compatibility mode" (my copy has this on page 5). In that it says:
Port F serves as digital input only in addition to analog input to the ADC.
I read that to mean that the JTAG (which is on PORTF) is not available in 103 mode.
robbinvandamme
PostPosted: Feb 15, 2012 - 09:08 AM
Is there an other way to debug an Atmega128 operation in 103 mode (running Assembly)?
I really would like to set some breakpoints.
MBedder
PostPosted: Feb 15, 2012 - 09:10 AM
Why on Earth would one use the M103 compatibility mode in 21st century?
wdkimpe
PostPosted: Feb 15, 2012 - 09:30 AM
because of legacy?
wdkimpe
PostPosted: Feb 15, 2012 - 09:37 AM
On that note:
in the case of a project completely written in assembler on an Atmega103, which was then run on an Atmega128 because the 103 was made obsolete, and one would want to not use the Atmega103C fuse, what would need to be changed to the assembler code?
Or is it software compatible and would one just need to rebuild with a different device?
