demonoR
PostPosted: Feb 09, 2012 - 01:51 PM
Wannabe
I am trying to play with that sensor. It uses i2c or so called sccb bus.
I was able to use i2c in many other sensors like accel, gyro and everything worked fine for me.
But the I trying to read with i2c the ov7670 sensor, I dont get the id number.
Maybe somebody has figured out, what is the main difference between standart i2c and sccb bus?
and what frequency I should use? Standart i2c uses 400kHz I think.
SCCB specification is located here:
http://www.ovt.com/download_document.ph ... amp;DID=63
Thank you
//Nikolaj
clawson
PostPosted: Feb 09, 2012 - 02:15 PM
10k+ Postman
Just to note that a search for "ov7670" hits 11 other threads beside this one. Maybe something in one of those?
demonoR
PostPosted: Apr 27, 2012 - 10:59 AM
Wannabe
Done.. Lots of mistakes, in code and in hardware..
seblovett
PostPosted: Jul 27, 2012 - 03:53 PM
Newbie
What was the end conclusion?
Can I2C be used straight off an AVR to communicate with the OV7670?
seblovett
PostPosted: Nov 04, 2012 - 10:08 PM
Newbie
Just to confirm for anyone reading this forum. I2C and SCCB are directly compatible. The difference's are you need pull-ups as with any I2C bus and the SCCB device won't NACK, only ACK. This doesn't cause any problems though.
