Posted: Feb 07, 2012 - 03:55 PM |
can anyone extend my program to a minimal setup
for monitoring frames ? At the moment it is sufficient
to catch at least 1 arbitrary frame.
I use STK600 and atmega128RFA1.
ISR(TRX24_RX_END_vect){
PORTB = 0xff;
reti();
DDRB = 0xff;
IRQ_MASK = 1 << RX_END;
TRX_STATE = TRX_OFF;
sei();
Best Regards
Thorsten |
Posted: Feb 07, 2012 - 04:14 PM |
You need at least:
1. Set channel.
2. Enable promiscuous mode or set addressing information.
3. Switch to one of RX modes.
There is no need to put reti() at the end of ISR(). Compiler will take care of this. |
Posted: Feb 07, 2012 - 04:45 PM |
now my program looks like this :
* AVRGCC4.c
* Created: 07.02.2012 15:41:43
* Author: thorsten
PORTB = 0xff;
DDRB = 0xff;
PHY_CC_CCA = 12 << CHANNEL0;
XAH_CTRL_1 = 1 << AACK_PROM_MODE;
TRX_STATE = 0x06 << TRX_CMD0;
sei();
Still no reaction.
Can it capture 802.11 frames, too ?
Regards
Thorsten |
Posted: Feb 07, 2012 - 04:55 PM |
It looks like promiscuous mode is only enabled for RX_AACK mode. Don't forget to disable ACKs in CSMA_SEED_1.
What is your source of frames? And what is your final goal?
This approach will allow you to implement a sniffer-like device, but is not usable for communications. |
Posted: Feb 07, 2012 - 08:58 PM |
That 0x06 command looks like RX_ON which is promiscuous by default I think. But I am not sure it will respond to any PAN in that mode. RX_AACK_ON is 22, and if you search for sniffer in the data sheet it tells how the other address registers have to be configured.
You may be fooling yourself that one packet was received. At a mimimum read the rssi and frame length, and back in foregound you can dump the frame in a wireshark import format if you have a serial link:
uint8_t frame_length, last_rssi,*rx_data,*rx_buffer;
last_rssi=hal_register_read(RG_PHY_ED_LEVEL);
frame_length = TST_RX_LENGTH; //frame length, not including lqi
rx_buffer=(uint8_t *)0x180; //start of fifo in i/o space
rx_data = &mybuffer;
do{
*rx_data++ = _SFR_MEM8(rx_buffer++);
} while (--frame_length > 0);
Posted: Feb 08, 2012 - 09:05 AM |
>Still no reaction.
Check if you are really in state RX_ON (TRX24_STATUS).
Check if you get a PLL lock IRQ. In order to verify your
programm, just run a periodic frame transmission on another
board. Feel free to checkout uracoli.nongnu.org, the project provides the basic functions to control the
Atmel transceivers with examples.
No way this way. But you can measure ED or RSSI
in state RX_ON. The ED measurement averages several RSSI values so it gives better results. With ED = 0 after a measurement it means that the receveived input power is at or below -90dBm. |
Posted: Feb 08, 2012 - 09:13 AM |
Exactly. In RX_ON mode, *any* frame is going to be received,
regardless of its addressing information (which can be completely
absent or not conforming to the IEEE 802.15.4 MAC addressing
conventions), and regardless of FCS failures. |
_________________ Jörg Wunsch
Posted: Feb 08, 2012 - 07:43 PM |
Totally offtopic and maybe a silly question but I wonder where "--" before frame_length stands for.
I couldn't find it on google and I am still a novice with C++ |
Posted: Feb 08, 2012 - 11:23 PM |
| Its a predecrement, equivalent to frame_length = frame_length -1 before the test. frame_length-- would do the decrement after the test. |
